Everything posted by pab567
- CarPlay crackling issue, software update fix?
5E0919605M removal
As far as I remember it's really not required but I can check in reality later when I am back home. See the slots in the picture below.
5E0919605M removal
Exactly, below the screen but above the plastic trim there are two holes to insert the removal keys. There is NO need to remove the plastic trim.
Firmware 6276 source
I've sent you link to download 6276 but I'm afraid this might be a hardware, not firmware problem. If firmware reflash doesn't help then you can try to have it repaired locally, start with resoldering chip i marked red in the picture below.
2018 Fabia Radio Software Update
Link to MST2_EU_SK_ZR_P0480T sent in PM
SKODA FABIA III 6V0 035 869J car radio: black FAKRA input ??
What tool did you use? What is part number of unit you broke?
DAB antenna input
Skoda Superb MK3 retrofit help – 5Q0035840B to 565035020A MIB2.5 Columbus + 9.2 screen
I'm currently hardly available due to health / family issues. MIB2 High toolbox is your friend
- MIB2/Apple CarPlay upgrade
Answering your doubts and questions: Is 565 035 020 A a suitable retrofit into a Superb MK3 that originally had 5Q0 035 840 B? => Yes, it is Which connector is usually different between these two setups? => LVDS HSD video connector is pink in Bolero and grey in Columbus. Do I need an adapter cable, repinning, or only a small modification to the connector keying? => Small modification is enough as they are electrically the same, just take the sharp knife and cut out from the pink plug an excessive platic trim that prevents it from being plugged into grey socket. After fitting the hardware, what exactly is needed next: Component Protection removal => yes, online or patching coding/adaptations in 5F => yes, usually done by uploading raw data adaptation channel maps with VCDS and then modifying channels that were not updated automatically FEC/SWaP activation for navigation / voice / SmartLink => yes, usually done by patching and loading new FEC container Can any of this be done with ODIS + VCX SE, or is dealer online access still required for some parts? => All can be done by patching and ODIS / VCP / VCDS / VC Tool / OBD Eleven
RNS510 Dead. Replacement options
Well, I can't give any advice for aftermarket units (especially chinese ones based on Android) but if you would like to get MIB STD2 PQ unit you can contact me. It should also be possible to repair your Columbus, this seems like a typical failure of PowerPIC that requires just resoldering.
Updating 2015/2016 Fabia software to include smartlink
It's not possible to update your unit to enable smartlink - you have to replace infotainment reader, either to Bolero 5Q0035842x / 565035842, or Amundsen 5Q0035874x / 565035874 (x - any letter A, B or C). New unit must be patched to disable component protection and have new features enabled. I can deliver such unit in Plug&Play version if required.
Can I add tv to my Columbus head unit in my2014 Elegance estate?
OEM solutions do not support current TV standards (DVBT) so all you can do is to find some aftermarket ones.
Latest Infotainment version Bolero
Sent in PM
Sent in PM
Skoda Swing Firmware Update - MU 8755
link to MEN2_EU_SKGPx_P0080L_8755 sent in PM
All check your PMs. For the future pls make sure to use @ when you want to ping anyone - @pab567 will work but if you miss @ then I don't get notification and unfortunately due to family and health issues I am not able to read all the threads.
This is NOT EU unit - this is US unit. It will NOT work with EU firmware unless it is reworked...
5708? I have NEVER heard about such firmware, could you pls post the picture of label from upper case? 6270 neither 6276 will work in your unit for sure, don't even try
Adding Aux-In to Swing Infotainment system
Should be possible. You will need new plastic trim with both AUX and USB to replace the current one with USB only, AUX port number 5Q0035724, harness to connect it to infotainment unit, and finally some OBD diagnostics tool to have it enabled in infotainment unit.
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
- Rearview camera 6V0 035 869H
