Everything posted by ords
VRS 245 - Buzzing (mooing) noise on Overrun
Does it do it when stationary and you rev the engine and let it fall to idle?
Tpms on board infotainment has no “Ser” option to reset dash warning light
Do you have an Octavia? I'm guessing not. The instructions given in the link are completely false.
Facelift LED tail lights
If you search Hollowmanvid on youtube you may find the clip you're looking for.
Sat Nav issues on Octavia VRS estate
Try and find a Briskoda member local to you who can scan for fault codes.
- Help
Probably the Best Car I Have Ever Had
Such a simple job. Mine was blocked for a few years. A few days soaking in vinegar did the trick for me.
2016 VRS Diesel, rough grinding sound when switching engine off
Can you post a file with the noise?
How much oil goes in my engine?
5.2 litres I think.
Alarm going off after locking
Suggest you post this in the MK2 forum.
Vrs tsi dsg lumpy idle and stalling
That could be a coincidence as the system will have to reset itself after the battery has been disconnected. I'd give it a few days to settle down and then re-scan.
- Am I missing a fuse?
Windscreen washer not working // with rear wiper
Does it work in both directions when you reverse the polarity?
Vibrations at specific RPM range
Engine mounts?
can some body help with rear fogs lights and rain close
Is the bulb or led in place?
Bolero to Amundsen switch
You'll need an antenna as well for the GPS.
Idle RPM Octavia 1.5TSI MK3 2020
Ok. Didn't know you were in Sweden. We have something similar. Cars here inspected after 3 years from registration and then every year after that.
What inspection?
Exactly. I'm surprised this topic has generated 3 pages. Nobody with a 1.5 has contributed, so the OP hasn't got his answer yet.
Radiator fan
Mine does not run all the time whenever the a/c is on. I don't know what the parameters are for it to kick in.
nickytheshaft's profile states a VRS
You've both got different engines. You're not comparing like for like. My 1.6 TDI idles at 750/800 RPM regardless of what load the engine has. It only goes to 1000 RPM when it's doing a regen.
I've read the original post and OP says the windsceen washer isn't working along with the rear wiper Are you saying the pump doesn't work for either front and rear?
Retrofitting cruise control
- Idle RPM Octavia 1.5TSI MK3 2020
You're talking about the heater fan? I thought you were talking about the engine cooling fan. - Idle RPM Octavia 1.5TSI MK3 2020
