Everything posted by ords
Cold first start problems -octavia 2017
Sounds like the glow plugs are not working properly, hence the smoke. How are you checking for codes?
Mysterious connector....!!
Can you take an image of all the writing on the label?
How does it sound whilst warming up?
- Hot and cold air
You could try this first- Start-stop error with engine light
Get it checked for code errors. Garage receipts should detail what was done and replaced How does the car run when the light is on?- SOC Indication is not Showing up !
What make is it? Mines a Varta AGM from Jan 2013- 1.4tsi DSG - replacing accumulator in mechatronics. Possible without removing unit?
- How to identify Head Unit
I also do that. You can either just delete everything on the card or re-format it. The CID file mentioned by @langers2k will not be deleted which either method you use.- How to identify Head Unit
Support for MIB1 map updates has been discontinued. The latest and final update is "ECE 2020/21"- 1.4tsi DSG - replacing accumulator in mechatronics. Possible without removing unit?
If he fixed the sump for what you must have thought a fair price and its been problem free, why don't you trust him? Could be many reasons why he couldn't show you the old parts. Did you say beforehand you want to see the old parts? Did he say how he would fix the sump? As you're not experiencing any problems with the gearbox or getting any fault codes, I'd go with the £120 repair.- 1.4tsi DSG - replacing accumulator in mechatronics. Possible without removing unit?
- What is this oil leaking?
Maybe you can contact this OP for info- What is this oil leaking?
Probably something like this https://kinergo.eu/product/dsg-7-03-dsg-7-dq200-repair-kit/- Both heated seats not working
Where did you get the idea that there was a seperate controller, when @ApertureS suggests they maybe controlled by the bcm?- Starting Problems
Good that it was a simple fix. Surprised no error codes showed up.- Starting Problems
How full was the tank before refuelling?- Starting Problems
If it's bad fuel, how can changing the filter make a difference? It will be the same "bad" fuel going thru the new filter. Had you just refuelled? Get it scanned for error codes.- Ball cap for towing hitch
Go to the local store and try before you buy.- ECO mode not staying engaged
When I used to use ECO, mine never came out of coasting mode going downhill and I had to shift to lower gears manually to take advantage of enging braking.- Issues with coding a second key
There must be fault codes logged for the supposed corruption? If the ECU is corrupted how is the engine even running?- Octavia Mk3 Cruise Control
Agree. Mine only has basic cc but the 1mph increments are very useful. Maybe yours could be adjusted with vcd's coding.- Octavia Mk3 Cruise Control
What happens after the car slows down?- Car hot and fans running
You need to find out why s/s is working when it's doing a regen. That's not right. - Hot and cold air
