langers2k
  1. From factory, only the drivers side rear fog light should work. It feels like someone may have messed about with the cars coding or something to get this behaviour... - Any history or previous work done to the car? - Have you had it long? - Have you got any error lights/bulb out warnings etc?
  2. The 'bluer' the light typically means the useful light output decreases. I wouldn't bother with the CBB, the CBI is probably better but I used Night Breaker Unlimited and was very happy with them.
  3. Aren't the Osram kits only designed to replace halogen H7 bulbs? So won't fit or help the OP with xenon (D3s?) bulbs...
  4. Yes, having the wrong light source in your headlight should fail the UK MOT as "4.1.4c light source and lamp not compatible". The guidance is aimed towards the more common HID/LED in a halogen headlamps but should apply equally to LED in HID headlamps as the headlamps will only be type approved for HID light sources Not that it relevant to the OP as they are in Spain...
  5. Just depends where you source the parts from... Just as an example, this shop charges £650 for the parts on a similar aged Golf: https://www.vw-retrofit.co.uk/product/golf-mk7-heated-mfsw-complete-set/
  6. The handbook is wrong - it's definitely a P21W SLL (super long life) and not a PY21W...
  7. I'd stick with xenon bulbs... The optics are designed for a xenon bulb so a drop-in LED won't give the same light distribution. You also have the issue of cooling the LED, an OEM LED setup use something like this with a massive heatink to keep heat under control: The drop-in kits are limited in size to fit in the same space as the original lamp so have much smaller heatsinks:
  8. Assuming the key is removed properly by a dealer or decent independent/auto-locksmith: - the remote fob will not unlock car - the immobiliser chip will not start the car - the key blade will still unlock the drivers door and likely unlock the steering lock I believe that using the key blade to unlock the car will cause the alarm to sound after 30s but I'm not 100% sure If you get a new key from a dealer, the old key should be removed during the programming. Basically the car gets put in to a learning mode and needs each key presenting in turn to learn. As the old one is missing, it won't be present and impossible to learn
  9. I used to use an expired credit card They are P21W but ideally use a long life variant if possible. The 'normal' life ones don't tend to last well.
  10. Pretty sure that'll be MIB3
  11. langers2k replied to adb55's topic in Skoda Yeti
    The quadlock connector changed from a 40 to 52 pin version, if that's your headunit, you'll have the 52 pin variant. It might be worth adding which Kenwood you're hoping to fit? There is a good chance your car supports Smartlink so you might also be able to get maps via CarPlay or Android Auto too.
  12. All depends where you're likely to be driving I'd probably choose ECE5 give it covers the UK and a good chunk of Europe. - If you need Spain and Portugal, choose ECE1 - If you need Denmark, Finland and Sweden, choose ECE6 If it's just the UK, then they will all be fine
  13. You could try following the instructions I wrote a while back: As per the warning, the latest full Europe maps no longer fit on a 16GB card regardless of how you format it. You'll need to remove files as per the post I've linked
  14. Or choose a smaller map pack with fewer countries...
  15. I would suggest you contact whoever did the ODIS work and tell them they missed something Otherwise, you could try contacting Ross-tech for help assuming your VCDS cable is genuine and you install the latest software...
  16. I wonder if your wife might have seen something about "Trained Parking" mentioned back in 2015 regarding the e-Golf... No idea if it made it to market though 😕
  17. Park assist is pretty well covered in the owners manual from page 141 onwards: https://ws.skoda-auto.com/OwnersManualService/Data/en/Superb_3V/05-2016/Manual/Superb/B8_Superb_OwnersManual.pdf I'm not too sure what you mean by that or expect to happen? Can you add some more detail?
  18. There are plenty of OE/OEM stuff on aliexpress so there is a good chance it's "genuine" although possibly grey market. I've had a few modules from various aliexpress sellers, including the RVC on my MK3 Octavia, without any issues Just remember that on a MK4, you'll need a SFD unlock code before you can code the camera in...
  19. I'd be very surprised if the wires were already fitted. Much like the tutorial you've seen, I'd expect you'd need to add the required wiring. The wiring you've described if for a highline kit with moving guidelines which would need wiring similar to this: https://www.cars-equipment.com/en/shop/cameras-parts/wiring-camera-cable-for-the-skoda/
  20. Even with the VAQ diff, my 245 can easily spin up it's tyres in cold, damp conditions Being aware of grip levels and applying less throttle will help, as will ensuring your tyres are decent quality and suited for the conditions. If you want to know more about have the VAQ compares to a LSD, this might help: https://www.golfmk7.com/forums/index.php?threads/how-the-vw-golf-gti-performance-pack-pp-“front-differential-lock”-vaq-works.351185/ As to retrofitting a VAQ, from that link: Is it easy to retro-fit the FDL unit? No! You have to take apart your gearbox case to remove your existing open diff, remove the diff cage & fit the one with the “tube” which the FDL unit locks onto. Then you need to remove the seal on that side of the gearbox case & replace with the one to accept the FDL unit hollow shaft. Then fit the FDL unit & the respective shorter driveshaft on this side. Then you have to wire the unit (5 wires) to the car loom & carry out VCDS coding etc. Considering you are adding more weight & complexity to the car & yet still retain a basic "open" diff in the gearbox case, there is no point. You would be better off spending less time removing the existing "open" diff & fitting a proper LSD like a Quaife or Wavetrac.
  21. I'm pretty sure a 2016 car with xenons will use module 55 for the headlight range. Much like this examples: - https://forums.ross-tech.com/index.php?threads/8375/ - https://forums.ross-tech.com/index.php?threads/28100/ As a starting point, the LED matrix lights will need 55 removing and module 4B adding instead. You will also need to make wiring changes to get D6 and D7 showing, as per this autoscan: - https://forums.ross-tech.com/index.php?threads/30074/ You may also need to change the BCM, CAN gateway or other modules... I would suggest you use erwin to get some factory wiring diagrams if you're serious about this retrofit
  22. langers2k replied to EJB's topic in Škoda Kamiq
    I'm pretty sure you'll have airbags in the A-pillars... Curtain airbags run along the sides of the vehicle and drop from the ceiling:
  23. Without seeing the scans, it's impossible to know as it'll depends how your car is configured...
  24. That's very optimistic of you... Did you check the wiring diagram to see if any of the pins have changed function? There is a good chance the matrix lights use modules D6, D7 and 4B which may control the indicators etc. Depending which lights you previously had, you may need to change some other modules to get this working.
  25. Welcome Have you got any VCDS autoscans? Ideally one before you changed anything and one from the car in it's current state...
