After market Led rear lights fitted .
You need the BCM reconfiguring using VCP or ODIS-e. Unfortunately it's not something VCDS can do as you need to tweak the lighting configuration directly in the EEPROM...
A quick question
That adapter appears to let you charge a phone and use wired headphones at the same time. I'm not quite sure what you're trying to do? Are you wanting to use the cars USB socket to connect a phone for Android Auto (which will charge) and also a wireless charger for something else? In which case, I'd just use the 12v socket for the wireless charger...
Direct download links for ECE 2018/2019 maps
Try here:
Octavia 5E / Amundsen Sat Nav Update Query
I assume you have a MIB2 or MIB2.5 Amundsen? In which case, you need "ROW 3" from here: If you don't know how to use the map update, try this:
AFS issue - any ideas?!
From the Octavia workshop manual... Parking module: As for the headlight range module, it just describes the position as "The control unit is located on the right side of the brake pedal". Headlight range module (no bracket): Headlight range module (with bracket): As I say, it should be similar for the Superb but the correct workshop manual will probably help you more... It's less than a tenner to get an hours access to erwin including wiring diagrams etc...
Headlight levelling sensor
As in a hex-v2? Then yes, post your autoscan so we can see what your car is made of and any error codes etc...
Got your autoscan from VCDS or similar?
At least in a RHD Octavia, it's up towards the right of the brake pedal, the Superb is probably the same. Might be worth getting the Superb workshop manual from erwin to confirm
rear led fog light
It'll share a fuse with other light functions so if it's the only light that's not working, the fuses are fine. If there is no dash warning for a bulb out, then the most likely causes are a bad light switch or the BCM being miscoded. It could be a wiring or failed light but I'd expect a bulb out warning. If I were you, I'd use VCDS to check the light switch works. If it does, I'd then be checking the BCM pin and wire to the rear cluster with a multimeter.
Changing the sidelight bulb in 2005 Octavia
Just pop the headlight out, replace the bulb and refit it. Assuming it's currently correctly fitted and you refit it correctly, it shouldn't make any real difference to the headlight alignment. It's super easy given the headlights are trivial to remove Just for example:
Upgrade infotainment?
Good question, TBH I'm not super sure but I don't think there is much in it... MIB2.5 came on MY18 cars (iirc) so adds a few things: - virtual cockpit support - skoda connect (won't work on retrofitted units) - few UI tweaks including supporting colour changes with ambient lighting etc - removing physical buttons for the 'glass' screens @pab567 will be able to explain the differences in more detail. He can probably supply an appropriate screen and might even be able to 'rework' your MIB2 into a MIB2.5 if needed. Happy to be corrected as I've only really experienced the MIB2.5 Amundsen
Roof bars for my hatchback
Few options here: https://www.thule.com/en-gb/buyers-guide?c=roof+racks&q=rKzhVyo6H
The bottom picture is a MIB2.5 Columbus unit, this runs at a different resolution to other units so you would also need to replace the 'brains' in the glovebox and deal with component protection, FeC/SWaP, coding etc... The MIB2 Amundsen, MIB2 Columbus and MIB2.5 Amundsen all run at the same resolution and I believe the displays are a direct swap. Based on that, you could swap the existing display for a MIB2.5 Amundsen display to give you something that looks like this without coding etc: Obviously you should double check before buying The MIB3 units seem to be full of bugs and I don't believe they are compatible with older cars so I'd skip that for now...
Updating Amundsen satnav in Octavia MkII 2013
I've never used a MIB1 headunit but it feels like it should only take a few minutes. Maybe go for a drive and see if it figures itself out. I always format my card for map updates but as long as everything has been deleted, it's not 'necessary'...
How many miles should I get out of Michelin CrossClimates (and/or other tyres)?
17k seems very low to me, have you checked the tyre tread depth yourself? For comparison, I put four crossclimates on my MK2 Octavia at ~64k: - replaced two at ~102k (puncture on one) - replaced two at ~138k (worn out) - replace all four at 188k (worn out) They were rotated occasionally but that's an average of ~62k miles per tyre despite the puncture causing lost usage from one pair... I'm of the opinion you should have more grip on the back to reduce the chance of oversteer given it's harder to control. This seems to be backed up by most tyre companies, The problem with mixing summer/all season/winter tyres is the grippy end can change depending on the weather/season. I'd very much suggest sticking to one variety on all four corners for a more predictable (and safe) experience
I assume you actually have a MK3 Octavia as the MK2 never got MIB headunits Skoda MIB headunits use the SD CID (card ID) for identification. This cannot be wiped by formatting so it's safe to format...
lowline or highline
Experience...? 😉
Skoda Octavia mk3 2014 VRS 2.0 TDI AC not working
Assuming your VCDS is genuine, it might be worth asking Rosstech 👍
lowline or highline
Pretty sure that's a maxidot cluster so I imagine it counts as a highline
There are no fault codes shown in your picture... There is a similar car here which shows the exact same output for the HVAC: https://forums.ross-tech.com/index.php?threads/17803/#post-158094 Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb Part No SW: 5E0 907 044 E HW: 5E0 907 044 E Component: Climatronic H02 0805 Revision: 00001K06 Coding: 01110104000100011005000000100000 Shop #: WSC 73430 031 00063 ASAM Dataset: EV_ACClimaBHBVW37X 003017 ROD: EV_ACClimaBHBVW37X_003_SK37.rod VCID: 2708F398EF65ECDFFF7-8072 Fresh Air Blower Front: Refrigerant Pressure And Temperature Sender: Air quality sensor: No fault code found.
Retrofit heated windscreen
The picture is perfectly readable here... Click on it once and it appears with a black border. Click it again, it'll open in a new page. Click it again and it zooms in so the text is clear
Can ABS fault cause flat battery ?
You have electromechanic power steering so there is no power steering fluid or pump You should get the car checked for fault codes and perform a parasitic current draw test to confirm what, if anything, is consuming power when it's turned off.
Rear door filled with water
Check and clear the drain holes along the bottom of the door
Infotainment System.
It's possible it's been miscoded... I certainly agree a C rev should be DAB capable. Might be worth finding a local VCDS user to take a look for you 🤔
Skoda Octavia mk2 facelift halogen to xenon headlight conversion guide
It's completely different between the pre-FL and FL. The pre-FL uses 10 pin connectors and a headlight range module. I think it reuses the same headlight motors that the halogens use..? The FL uses 14 pin connectors and each headlight gains a AFS slave module. These communicate via the AFS CAN-bus with the AFS master which controls both the headlight range (up/down) and cornering (left/right) motors. If you want to add xenon's on a pre-FL, I'd suggest grabbing the wiring diagrams for both halogen and xenon based cars from Erwin 👍
