OBDeleven "Lane Assistant" vs "Lane Change Assistance" in Dashboard Control Unit?
It might be handy if you can confirm if it's an adaption channel or part of the lcode. If it's the former, the byte/bit would also help narrow it down. At least for lcodes, the label files are generated by the tool manufacture so there may be mistakes. Assuming the car works and there are no fault codes, feel free to try changing it. If you get a fault code (missing message) then it probably doesn't need enabling
Passenger mirror dip in reverse - sorted
Pretty sure on newer cars you need a 'memory mirror motor' to get reverse dipping working properly. The difference is that standard motors have 3 wires to move it, a memory motor has an extra 4 so the door controller can see where it's pointing. Typically, they are only standard with electric seats. For reverse dip to work, it needs to be enabled in the infotainment and the mirror selector should be in the passenger mirror position. That'll be L for the UK and R for Spain. When in reverse, only the passenger mirror will dip, you can set the position whilst in reverse and it should pop back up when moving forwards.
Tire Pressure Monitoring System - any user interface other than "set now as good" and "idiot light"?
Direct systems using sensors should have a control module at address 65. If there is no control module, you definitely have in-direct ABS based TPMS.
vRS 245 Performance Gauges In Infotainment
The compass is normally built into the satnav so without nav, you won't have one
Playback from SD Card - MP3's first track missing from album
Completely normal after a software update Look through the adaption channels for "Confirmation of installation change" which should be a 4 digit code, you'll need to XOR it with C9D2 and re-enter the new code. You might need to put a space between the first two and last two digits. Random online helper: http://mib-helper.com/im-so-xory/
Smart link enable
No, you cannot apply the key yourself!!! As an example, take a look at 000054830A. It's a MIB2 Standard (Bolero/Amundsen) Smartlink activation kit which clearly states it will require ODIS. It also needs online access to update the Skoda servers to show your VIN now has Smartlink activated. This part number will not work for you as I think you have MIB2 Entry (Stream) headunit. At least in the UK, typical prices for Smartlink at a Skoda dealer are £135-170. I assume you're in Europe but I'd expect a similar price in €. You might find a independent garage with the right equipment but as the monthly subscription costs are high, most don't use ODIS.
OBDeleven Long Coding options disagree with physical configuration? (I know, I should just step AWAY from the toys...)
Yeah, I'd agree with the above, don't start messing with things until you have: - made a backup (long coding + adaptions) - understand how to compare the current coding/adaptions to the backup - find the history of changes - are happy you're able to revert things I've never used OBDeleven so I can't give any specifics. If you can figure it out, it might be worth making a short guide? Something like 'OBDeleven first steps before you change anything' If you're new to coding (which it seems like you are), l'd very much suggest looking at some of the common tweaks and seeing which, if any, you'd like and trying those first. You'll soon release there are a great many options, some of which may seem almost identical in both German and may miss certain nuances when translated to English.
Smart link enable
Pretty sure activation can only be done using ODIS (dealer software). The smartlink enablement codes need to be added against your VIN on the Skoda servers. Your headunit can then be updated with the new activations.
Smart link enable
You need an activation code and then a dealer can enable smartlink for you. It'll be around £150 if I recall
Factory Alarm? & OBD Eleven Coding!
The alarm siren has a non-replaceable battery to ensure it can sound if the main battery has been disconnected. At least on a MK2, it has a 'service life' of 6 years (if I remember correctly) but this doesn't mean they fail at immediately at 6 years - mine lasted 9 years. Most people won't notice the battery is flat as I don't think there are any symptoms but it should throw an error code on a scan. Maybe the MQB sirens last longer but it's still just a matter of time before they are likely to fail
Non starter after messing with aftermarket stereo upgrade.
Read the fitting instructions for your headunit? I expect it'll need: - power (permanent for settings etc) - switched (to turn on/off with the ignition) - ground Where these will attach, is completely down to the headunit manufacturer... It might help if you confirm exactly what you're trying to fit and add some pictures so we can see what you're doing/have done so far. The CAN simulator connects to permanent power, ground and the two CAN-bus wires. It'll create a switched ignition live based on the CAN-bus messages it sees. Assuming the new live you ran from the fusebox is switched, there is no need for it
There is no ignition switched live for the stock Skoda radio. It only has permanent power and ground, on/off etc is done over CAN-bus. You'll either need to run a new feed from the fusebox or use a CAN simulator to create one
Virtual Cockpit Install?
Pretty sure that's correct. It might just be a lack of VC settings but I think it's map display too, @pab567 can correct me if I'm mistaken. Some MIB2 units can be reworked into MIB2.5 units but that's definitely a question for pab... May not work out that cheap given shipping/taxes both ways from Australia...
Which Amundsen is this?
F is a MY15 which is typically August 2014 to July 2015 build dates. I guess it could have been one of the very last pre-MIB2 style headunit cars
Yup. The RNS-310 style doesn't have any internal storage for maps so it always needs a map CD or SD fitted to show maps. The RNS-315 style does have in internal storage for maps so it's very likely this is what you have
Welcome! That could be either an Amundsen (RNS-310) or Amundsen+ (RNS-315) which look identical but take different maps. It might help if you turn it on and grab a picture from the system information/versions page showing it's part number to confirm which edit: If it can display maps without an SD or CD inserted, it's a RNS-315
Do late mk3 2018ish rear lights fit an earlier mk3 2014
I think you'll also need a wiring adapter along with coding to get the newer rear clusters to work
Virtual Cockpit Retrofit with Columbus and Canton
Have you got an autoscan from VCDS and the adaptation map from 5F you can post?
What bulbs are fitted to the S3 & upgraded bulb recommendations
I completely agree, I would never fit them! It was taken from newbie link where they ordered H8 leds. This is what they received: But I don't think the left bulb is a H8/H11/H16 version, if it was, I'd expect it to look like this: The design you posted: Is exactly what I fitted to my FL MK2 Octaiva. However, rather than being a genuine Philips version, it was a cloned Chinese thing that was significantly cheaper
Can anyone help decipher B14A612 error - superb 2018?
It's very hard to tell from the test you posted, as far as I can tell, there are 7 potential codes: Raw code: 904F12 Raw code: 000035 Skoda: B10AE38: High pressure sensor Skoda: B152613: Lower convert. top compart. cover switch Skoda: B118F12: Convertible top open position switch Skoda: B10C929: Left side vent motor Skoda: B11C911: Solen.val. for bleeding lumbar support 1 However, most don't seem to be obviously google-able so I'm concerned the scanner isn't being completely helpful with them. For instance, I'm pretty sure you don't have a convertible Superb 11.4v is a very low battery voltage so they could be related to a failing battery.
Well that's quite a chunk of text! No idea how many codes that's suppose to be? Can I suggest you clear everything and see which, if any, come back? As for your SOS error, this seems a obvious starting point: 2021: B14A612: Emergency call speaker Short circuit to B
Traffic Sign Recognition Issue
The fusion mode is a setting in the A5 front facing camera rather than the headunit It also worked as expected with a MIB STD2 PQ Amundsen (from a Yeti) with an appropriate camera in my MK2 Octavia. I think it's only the Bolero and below (non satnav) that can't deal with fusion mode.
I don't think they sent a H8 It could be a 9006 (HB4?) based on the listing? I think the H8/H11 version should look like these:
The 'essential' versions are slightly cheaper on eBay at ~£65 https://www.ebay.co.uk/itm/224314963244 the fan might put you off though. There used to be cloned versions of the Philips X-treme Ultinon which were fanless and cheap. I had a set on my FL MK2 Octavia which were great, think they are sat in the garage somewhere now... H8, H11 and H16 are basically the same bulb with different wattages. The three tangs are slightly different shapes but with a quick trim can be made to fit in either fitting
@newbie69 - how much would you like to spend Powerbulbs have a selection of branded bulbs: - https://www.powerbulbs.com/product/osram-ledriving-fl-led-h8-h11-h16-twin - https://www.powerbulbs.com/product/philips-ultinon-essential-led-h11-twin - https://www.powerbulbs.com/eu/product/x-tremeultinon-gen2-led-fog-lights-h8-h11-h16-twin - https://www.powerbulbs.com/product/philips-ultinon-pro9000-led-h8-h11-h16-twin
