Kenny R
Everything posted by Kenny R
  1. My 2022 Kodiaq came with a printed owners manual.
  2. Glad not to be the only one that cleans / de- stones etc winter/ summer wheels at change overs.
  3. Not so, changes in parameters of fuelling, boost etc are still logged and easily seen by any tech worth their salt. As above best getting a remap from a reputable tuner and declaring it.
  4. Kenny R replied to gs800's topic in Skoda Yeti
    I believe the yeti was available from launch with the 1.8 tsi engine. I had a 2010 1.8 tsi 160hp 4x4 elegance and a 2013 1.8 tsi 160hp 4x4 L&K
  5. Button mentioned switches on/off interior lights coming on when doors are opened function.
  6. I received my documents to sign electronically from Skoda Financial Services one week before delivery was due, and the they were confirmed almost immediately.
  7. From the workshop manuals in the Kodiaq Guides section, looks like you need to remove door card.
  8. Kenny R replied to XVolvo's topic in Skoda Karoq
    On my Kodiaq it’s on the fuel flap..
  9. 17” wheels fit fine over 340mm discs just fine on my Kodiaq
  10. Here is the part number if anyone interested in finding an alternative 3V0905217AWHS
  11. I ordered my first Kodiaq at the end of January 2018 and it was delivered mid April and I got 2 free services. Can’t say I’ve ever seen a 3 free service offer.
  12. I would be wary removing airbag fuse to fit piggyback, as it could lead to airbag warning light on dash that requires dealer to reset. In all the Skoda cars I’ve had I’ve used the well recommended on here, rear wiper fuse as a ignition controlled supply for dash cam.
  13. It shows the KW output of the engine. 0-110 kw for the 1.5.
  14. Try the free online Arnold Shark value my car. If your not happy, try WBAC or Motorway and see what they offer.
  15. When my son had his Karoq, he used my old Yeti 16” winter wheels instead of his standard 19” wheels during the winter months.
  16. That’s exactly what it is, a pen holder. The clip can be used to secure breakdown card, documents etc in place.
  17. Yeah, will drop to idle, don’t know why I’ve put zero.
  18. You have to lift your foot completely off the accelerator to engage coasting. It work seamlessly and not easily detected. As above if you are in eco mode the gear indicator will just show E with no gear number and revs will drop to zero. Your late 21 model may well coast in normal mode and will show D with no gear number when you lift off going downhill.
  19. Can’t answer specifically on Superb, but my previous Kodiaq would only coast when in eco mode. My current Kodiaq coasts in normal and eco mode when going downhill with foot lifted off accelerator pedal. To re engage drive either press accelerator, touch the brake pedal or use steering wheel paddle or gear selector to select lower gear when going down steep hill. Or select sports mode and it won’t coast.
  20. There has to be an alternative Kph speed reading as there are no Kph markings on the speedometer dial.
  21. Fold in before getting out using mirror switch on door, and they won’t unfold when unlocking.
  22. I believe the S spec only has front speakers.
  23. There is apparently an issue with the engine cover on 2.0 TSI engines where the cover can become detached and slip down the back of the engine onto hot components.
  24. The cornering light will come on at speeds below 25mph on the side that the wheel are turned to, or when indicating. As you have found, they both come on whe reverse is selected. Fog lights are not clever enough to know it’s foggy and it’s down to the driver to turn them on manually. If the wiper stalk is in the first position up, then they will indeed operate when the screen gets wet. The sensitivity can be adjusted with the switch on top of wiper stalk.
