- AGM Battery replaced guidance needed please
I believe the G12 Evo coolant does not require the silikat additive - in any case, it is recommended to replace coolant at certain intervals to preserve anti-freeze and anti-corrosion levels.. My understanding of having the silikat bag in the expansion tank pre G12 Evo, was to serve in extending the coolant change periods.
My original suggestion for syringing out the expansion tank with a turkey baster was simply for eliminating any spillage onto engine bay paint (I'm not really that mean to save on 250mls of antifreeze 😄) But I do strongly recommend investing in a proper pair (inexpensive) of hose clip pliers.
Glove Box Removal
I found the most difficult bit was getting damper arm to stay in the correct angle while getting compartment into position. I think I resorted to using a strip of gaffa tape over the pivot in the end.
Crack in the sunroof plastic chassis - MK3 2016
Hello, welcome to the forum. I'd suggest a through clean of the full length, then a quality flexible, adhesive sealant - making sure to get it right up into the corners beneath the flexible seals.
Don’tcha just love a Skoda on a cold morning
Wow, 26.5 degrees - welcome to my sauna.😃
Problems, problems after battery change - Kodiaq 2018 5-seater 20 TSi 4x4
Yes, there is a current monitor tagged (small plug-in) on the battery neg. terminal.
My lovely Octavia Estate phev petrol estate is due for first MOT May..Re buying/ordering new model
Unfortunately this is a fairly common 'cash generator' for unscrupulous garages.
Could the loud alarm sound have been from the onboard security system activating? Possibly not connected to that new fault code.
Lane assist - does anyone actually like it?
I believe more pilots (and passengers) have died by ignoring usual procedure of continuing straight out after suffering power loss during departure, by attempting to return to runway, then stalling into the ground.
I've never had to do this operation, but I'd suspect none - apart from the alarm system (which has own battery) all circuits lose voltage when the battery is disconnected. Hopefully other forum members will be able to better advise. I'd suggest killing the infotainment system first, as this apparently can cause this type of issue. Remember to always leave sufficient time for live modules to enter sleep mode after switching off.
The only way I have seen is to systematically pull the fuse on the various modules - first making sure that the vehicle has entered 'sleep mode' to eliminate false readings from control modules that are still active. Opening a door to access interior fuse panel will, of course, wake them up again - so it may be a prolonged process. Good luck.
Ideally yes - but this shouldn't give rise to the apparent current drain issue.
Wipers not working
I'm taking a bit of guess here as I have not seen a wiring diagram for your vehicle - but I think there should probably be two 12 V connections on the motor - 1 permanent and one switchable (live when the stalk is operated) As Pete says, check the relay.
Rear wiper motor
Likely to be an internal fault with the self-parking contact. Does the wiper restart immediately when you push the stalk forward?
You have taken most of the depreciation hit on a new vehicle, why subject yourself to that again?
Tyre compressor included with vehicle
I have asked several tyre fitters about this, the consensus was that they would not consider repairing a tyre that had been sealed with 'gunk' because of the sheer messiness and difficulty in getting the puncture area sufficiently clean. I guess it's bad enough just getting the old tyre off the rim.
Or temporarily disable systems that appear unable to properly handle prevailing conditions.
Weird line around areas on my sat nav
I seem to recall another forum user asking a similar question - 'greyed-out' area around indicated location. If I recall correctly, it was due to poor satellite reception, but I don't remember if it was due to a signal reception issue (antenna) or temporary satellite triangulation errors.
knocking when accelerating
I guess that is a slight possibility, but from the little I know about Diesels, it's extremely difficult to hear detonation even if it does occur - unlike a petrol.
I prefer to think of most of the driver assistance functions as a generally useful tool - but not for full reliance, as an assistance only - there will be occasions where the technology will get confused or misused, a case in point being the Tesla recall. Post crash mitigation braking is likely to be, potentially, the biggest life-saver. Seemingly, I am one of a very few who rate automatic idle stop as a useful feature, fag-packet calcs tell me that even a 10 second stop with engine idling makes a small but measurable increase in fuel consumption, not to mention the unnecessary emissions.
updating digital service history when servicing at independent workshop?
Hello, welcome to the forum. It's very likely that a VAG independent will have access - ask them for a confirmation.
Phil69
Good morning Phil, I don't know what you were driving before, but I suggest taking a couple of test drives in likely-looking vehicles in dealers near you first. I think you will be pleasantly surprised with the performance and economy of even a lowly 1.4 TSI.
Hello Peter, welcome to the forum. A metallic knocking sound could suggest excessive wear in the connecting rod bearings (aka big end), are you getting low oil pressure warnings at idle speed?
Central locking
The cell phone reminder is shown on the main infotainment display - the safelock message is displayed on the multifunction display.
