Warrior193
  1. What mileage has this vehicle recorded? Your mention of it having had 'plenty of tyres' might possibly be of some concern. Check .gov website for recorded mileages at MOTs for past 5 years.
  2. For the rear demister, check the loop of wiring between body and hatch for broken connections - for the washers, is there any sign of water ingress in the trunk?
  3. The fault could be something as simple as a sticking turbo actuator arm, wait and see what the investigation shows before considering rejection.
  4. Good morning Jamie, what is your mileage? Are you beginning to have issues with the pump?
  5. @Junips99 Has there been any progress on DTC scan?
  6. If hazards were flashing with no audible alarm sounding, it's possible that the alarm was triggered by falling battery voltage or something else and the internal alarm unit battery is faulty.
  7. The 5x4mm is presumably 3-phase, 400V.
  8. 6.0mm flexible cable is rated at around 32A/7.4KW - but voltage drop can become a factor on longer lengths.
  9. Thanks, I must have been thinking 'granny' cable.
  10. What is the max. Amps output of a type 2 charger - 13A?
  11. ...or transmission position sensor?
  12. Is this a Manual or DSG box? Is there any indication showing on instrument cluster when it won't crank?
  13. Is it correct gauge (mm2) for the current used while charging? Length of connecting cable can become an issue if its cross-section is too small, problem becomes worse in longer cables through increased volt drop.
  14. Is this an extension cable you are using? If so, what gauge (mm2) are the cores?
  15. ...but it does look as if the shells are clamped-together with some type of rivet nut.
  16. I assume price reduction of AGM batteries is due to economy of scale rule. Prices of them a few years back was disproportionately high, I thought.
  17. Unless a fault is actually still present. Is GPS working correctly?
  18. What is your present fault reader, does it not have fault reset capability?
  19. Welcome to the forum. I believe you need to clear the fault manually by plugging a suitable device into the vehicles OBD port.
  20. A few trips only of the length you describe may very well not restore the battery charge sufficiently, given the predominant use. Unfortunately, the smart charging alternator strategy does not appear to recognise intermittent vehicle use and adapt the strategy to bring battery SOC to a higher level - overriding strategy seems to be fuel saving. IMO, current VAG smart-charge strategy can lead to increased plate sulphation through persistent low SOC unless the vehicle gets regular long runs along with substantial energy micro-recuperation. My Octavia has a similar use to yours and I use a Ring smart charger occasionally to maintain battery health. I do this at 2-monthly intervals during winter - and approx. 4 to 6-monthly intervals during warmer part of the year (whenever SS stops operating consistently) Works for me as my 10-year old Moll EFB still tests at almost 90% healthy.
  21. Ask what device was used for test and request they show you the test printout.
  22. Provided that all vehicle modules are in sleep mode, 12.1 V standing voltage is about 55% SOC - I'd be very surprised if a genuine battery condition test, properly applied, would give a 'good condition' health report on a battery in that state!
  23. Be very cautious if spraying any inflammable engine cleaner near the induction system - don't use it on a running engine!
  24. For two functions missing on the same stalk, I'd suggest checking the stalk itself first.
  25. Even with regular long trips, the battery will frequently not get charged to 100% due to the Smart Charging system reserving battery capacity for regenerative charging.
