Battery discharge - fuse 39?
How old is the battery? If you have confirmed that the battery is 'goosed' you are possibly looking in the wrong direction by looking for parasitic draw. How was the battery tested? The overnight terminal voltage drop you are seeing is probably no more than you could expect - especially with a suspect battery.
What is this camera for?
I stand to be corrected but believe that is referred to as a 'low level' camera along with rain and automatic headlight sensor - AFAIK it is incompatible for TSR.
Battery issue or something more serious?
AFAIK, park mode can be sufficient to prevent control modules from entering sleep mode - it is on my Octavia.
OP says dashcam is left on in park mode - this will draw a small but constant current.
Skoda Octavia 1.8t vrs
A little hard to read that gauge due to scale and parallax - but that looks about 1 to 1.5 bar. Another post on this forum, for a 2012 1.8t gives 1.8 bar on low setting and 3.3 bar on high.
I think I have seen a figure quoted of around 2 to 3 bar at high rate if fitted with dual pressure oil pump, bit I don't know if that applies to 1.8
Issue with swapped headlight 2022.
Flickering Xenon (HID) can be lamp at end of life or faulty ballast.
Important note, leaving the dashcam on can prevent control modules from entering sleep mode when the vehicle attempts to shut down - combined with short trips, this can result in low battery SOC. Does your automatic idle stop operate normally?
Can you post another image with the extraneous bits on a sheet of white paper?
Hello, welcome to the forum. I'd consider a failed oil pump as the first suspect, depending on how long the engine was run after the oil pressure failure indicator lit, it is likely that your engine has suffered significant damage. All vehicle instructions I have seen mandate immediate engine stop and recovery if oil pressure fails. Highly probable that turbo seizure is the result of oil pressure failure - not vice-versa.
Can you post what type of headlight you have fitted? If lamp is faulty, very unlikely to be still under warranty after 3 years.
Replacement engine required Skoda Super 2016 2.00 TDI
Be aware that the majority of 'reconditioned' engines being touted will be no such thing - almost invariably pulled out of a wreak, steam-cleaned and plonked on a pallet (pallet optional)
VRS Battery drain
Is the infotainment system in the centre of the dash panel the original, factory-fitted system? I have seen reports from a number of owners who have experienced parasitic battery drain issues when after market systems had been installed.
VRS Battery drain
Could you be more specific - was this a dedicated alternator output test device?
Dodgy fuel filler pipe
@Cherry_140 Have you succeeded in removing the offending object?
Octavia Mk2 VRS Coolant problems
It is likely that your cooling system has an airlock, this may eventually clear by itself, in which case the coolant will require topping up - or it may require to have a recommended bleeding process of the cooling system carried out. NB. this air purging process should have been carried out by the mechanics who replaced the EGR.
VRS Battery drain
Recheck that the alternator (battery) indicator light operates correctly - on with ignition, extinguishes immediately on engine start.
VRS Battery drain
13.8 volts, dropping to 12.9 volts on load appears to be a reasonable output for the alternator - what indication was given for assuming a charging fault?
1.2TSI Gearbox Damage
Looking at the drawing, it appears to be just a cap, there does not appear to be anything actually on the lower part of the shift tower retained by it.
VRS Battery drain
Does the red alternator charge (battery) light illuminate when the ignition is first switched on - then extinguish as soon as the engine starts?
From the images you posted, you will only need to remove the single remaining bolt to completely remove the cap. Unless there was a spring fitted inside the cap - which doesn't appear to be the case from looking at the schematic drawing, the shift tower may work ok with the cap simply removed. Removing the sheared-off stub will probably require drilling to accept an extractor.
I've had a look at an exploded view of the part online - I'd suggest first trying to realign the end cap to its correct position, then check if the missing gears select correctly - you may need to slightly loosen the single remaining bolt first - looks like a spline type bolt. From the diagram, the bottom section of the shift tower may project down into this endcap, with movement being restricted or pinched by the displacement of the cap.
Modified vrs value
A belated welcome to the forum. A note that you need to join Freedom to sell on the forum.
Modified vrs value
And possible restricted choice of insurers and / or increased premiums.
It certainly appears to have allowed the gearbox to dump all its oil. Do you know if the vehicle was driven after the damage - how bad was other damage, if any?
