Warrior193
  1. Just a thought, isn't the paint code also listed in the full build code? Could @ApertureS confirm?
  2. What is this 'heating element' that your dealer is referring to? I don't see any reference to this in your previous posts.
  3. What a load of nonsense! - so they are now calling the HB control stalk (which every vehicle with twin-beam lights must have as standard) 'HBA'?
  4. But I believe a guaranteed 350 to 400 mile range, all weather, no jiggery-pokery, is a useful figure for EV manufacturers to aim at.
  5. Steel wheel rims are generally a fair bit lighter than alloys and are often used for mounting winter tyres if using only seasonally. Most tyre websites will give information on fitment suitability for given rim sizes. Wheel diameter is rigid - tyres will usually have a range for max-min recommended wheel width.
  6. I can give an unreserved +++ for the Alpin 5s if the later 6s are not available for you.
  7. @BogdanDDB In your original post you omitted any reference to 'Diesel' and incorrectly referred to 'spark plugs' - if you have diesel, you actually have glow (not spark) plugs.
  8. Interesting that the recess in the dash appears to exactly match the switch bezel - is there normally some other switch in that position?
  9. It sounds as if your energy provider is throttling-back your charging rate at some point (load clipping), then failing to restore normal charge rate after event. What time of night has this been happening? Ask Ovo reason why this might be occurring - and if your charging protocol can be changed.
  10. Unfortunately that will not make any difference - as suggested above, get the battery tested first. I assume this 'shuddering' is while engine is running in gear - not while shutting down?
  11. From the limited information I have found for the P0400 (injector4) fault, it appears faulty wiring (ground return) can be possible cause - perhaps possible the ECM fault is also connected. It appears that the injectors are fed a live 12V supply, with the trigger going to ground to operate it.
  12. When this breakdown happened, did the 'check engine' (MIL) indicator light up also?
  13. As far as I'm aware, the glow plugs are only heating on a start up, especially on cold start - they should not affect engine operation once it is running, I think you should be looking at the injector fault for your breakdown.
  14. Hello Alonso, welcome to the forum. Most likely the connector failure was caused by nothing more than a loose female socket - or dirty male pin.
  15. I've always been a fan of NGK plugs from my karting days - with US made Champion plugs second. Home-grown (NZ) Champions were always prone to chronic fouling.
  16. Are those consumption figures you mention litres per 100KM?
  17. Welcome to the forum. The engine has a 'soft limiter' - If you are attempting to rev engine while not in gear, this will limit engine speed - or are you having this issue while driving? What gearbox does your car have?
  18. I'm still really impressed with my PFL (MY16) 1.4 TSI.
  19. Are you certain you don't have a charge cooler? AFAIK, modern turbos usually have one.
  20. Hello Eddie, welcome to the forum. That symbol is, as you thought, an indication that you may be too close to the vehicle in front - this indication is from the front assist radar system, the same sensor that performs emergency avoidance braking if the system thinks a collision is imminent. Retrofitting ACC when you have standard CC will require (at least) a replacement control stalk - and possibly other hardware changes.
  21. Can you post a picture showing deformation of the springs?
  22. The 'Drop test' (usually called high rate discharge test) your garage mentioned will be good enough for a reasonable condition assessment - but needs to be done on a fully charged battery to be accurate.
  23. If your car has automatic idle stop and the original battery was EFB (likely) your battery management needs to be adapted (coded) to the new battery. When fitted with a smart alternator, the BMS will control the alternator to charge the battery to around 75% - the remaining capacity will be via energy recuperative charging.
  24. I'd take a guess at using 'Dynamic' - which I'd think will reduce assistance as vehicle speed increases. I know almost everyone does it to an extent - but it's not especially good to wind on wheel lock while the vehicle is stationary.
  25. It is due to the tyre tread pattern rather that the wheel rim itself - asymmetric tyres must be rotated in the correct direction.
