Everything posted by Prezafab
Is the touchscreen covered under the used warranty?
I think just ask the dealer those questions directly. If you don't , you are going off what people *think* should happen on here ! For what it's worth, our Dec 2017's screen's touchyness went on the left side a couple of months ago. I have an aftermarket warranty but that looked unclear on the stereo, a repairer wanted £200 plus sending the whole unit to them. So, using the advice on here, I bought a new screen digitizer for £26 and a couple of the right screwdriver type for another £5 and fitted myself after watching a good YouTube video. The only thing I did wrong was not quite seat the SD card reader board into its slot the first time. Otherwise, easy to do.
Black grille surround advice
You did amazingly well - maybe post a decent YouTube video for other people if you ever do it again ! I did start cutting and twisting the chrome clips off, but gave up after an hour because the black tabs on the grille itself were getting damaged as well in the process. That's why I went for a new grille as everything was incredibly tight on my car. Getting the new assembly of grille and black surround back onto the car needed two people to line up all the tabs into the front bumper moulding, otherwise it kept springing off before you could get the back edge of the lip of the flat 'bonnet lock gap' cover into its retaining groove.
tyres - ratings?
Well, "you pays your money and makes your choice". As a backup, we've had Goodyear Vector 4 Seasons as well as (current) Cross Climate 2s on our Yetis. I don't think there's very much difference at all between them, both good.
tyres - ratings?
I would normally say 'they're fine' but the way insurers are these days on claims, I'd phone them and get a note on your file. Kwik fit show both W and Y rating in stock?
Done at last. One of the fiddliest jobs I've done on a car. Very simple on paper but glad I gave up trying to remove the chrome trim from the original grille. The copy pattern grille was £65.
To anyone attempting this, don't bother on what are 7-12 year old cars now. I got the whole grille off eventually, but separating the chrome from the backing grille so I can replace with the gloss black is a nightmare. Buying another black grille .
- Dashcam Installation
I can do the top 'chrome' plastic ones but it's the ones at the corners and lower down that I can't work out / don't want to break. (The trim arrived massively packaged from Czech, by the way !)
Gave up in the rain today - dry day required! I don't see how you can prise the clips apart behind the grille without breaking the fittings on the standard black radiator grille that the chrome frame mounts to ? Anyone have a video as the only one I found wasn't much use on what to press and hold without breaking. I had screw drivers and credit cards at the ready !
How big a job is removing lower rear bumper 2012 Yeti?
If you mean just the silver bit, it's easy as just screws. We had ours painted body colour. This video is of an Octavia mk2 which will be very similar, so a good idea of what's involved. Worth a go I think. https://m.youtube.com/watch?v=JIHUiHgBRTU&pp=ygUeU2tvZGEgeWV0aSByZWFyIHBhcmtpbmcgc2Vuc29y
Anyone had their diamond cut Origamis powder coated?
We have Origamis and they are still ok. Not sure how longer power coating would last. I had diamond cut black and silver wheels repaired last year (for bleed under the lacquer and a couple of edge scrapes) on my Volvo after doing my 'due diligence' to find someone who knew what they were doing. Cost £105 a wheel but totally as new and lots of dealers used them to get used cars up to standard. I'd be inclined to do your research locally and get one wheel done to see how they do.
1.2 TSi DSG Reliability
And still very good on economy compared with a regular autobox of the same age. If you have been happy with the 1.2 in the Roomster, the DSG makes good use of that engine's low down torque and power delivery. If you search enough on here there will be lots of opinions on changing gearbox oil or leaving it well alone. If it's smooth now, then enjoy.
Make sure it drives well and has had some Skoda dealer services at some stage in its life that would have caught any issues before it went out of the dealer network. We have had 7 x DSG Yetis and one manual. Half and half petrol and 4x4 diesel which have different DSG boxes. Highest mileage in two were over 100,000. Never had an issue (so far) except one was slightly jerky when cold.
Yeti radio repairs
Look up screen digitizer ? If you are pressing the left hand side of the touch screen and it isn't responding...
Yeti radio repairs
You can change your own screen digitizer for £25. See ebay and You Tube. Maybe you do that first and see how it is ?
Friction noise over 40mph
Glad you're sorting. (My old Audi allroad started like yours at a similar mileage).
Ok, will do, thanks. OEM black grille:- 69.99 + postage. Black Mirror caps:- Failed on Amazon ones even though they should have fitted. Eventually bought from a UK eBay company that supplies and paints. One needed a line of glue to hold onto a clip, but good. Have painted stuff myself but were fairly reasonable. Front and rear grey plastic in bumpers:- it was cheaper to buy scrap yard extra grey bits and leave them with a friendly local body shop for a few weeks to fit in around other work, for cash. Called me when ready to fit the painted ones (2 hours).
Everything on our 2017 Yeti is now de-greyed (bumpers & mirrors) apart from the chrome grille surround, so it's all metallic blue or black. Its Monte Carlo ish with the right wheels on it. I understand that you need to push in the tabs on the old grille frame to release it and I've read that cutting up old credit cards works well (in more ways than one). Anyone changed it themselves and have a better idea before I have a go ?
Wheel bearing ?
Hard wired dash cam.
If you want it hassle free, buy a Black Vue model with the switched cable that plugs into the diagnostics port. I got a factory reconditioned set off eBay with 2 cameras and a years warranty and fitted to my Audi. No hard wiring required but acts exactly like it is. Big thumbs up.
Amundsen sat navin a 2017 yeti
So not plugged in properly after you'd put the Amundsen back in after its screen repair ?😉 (My SD card wouldn't work at first after I replaced the screen myself because it wasn't quite seated).
Ok, last time I'm going to ask. Have you read the owners manual on satellite reception?🤔
Er, that's what I said above. The Octavia owner read the handbook and found out if and how many satellites it could see...
