Danoid
Everything posted by Danoid
  1. At the very minimum the serial number (BEM code, which aftermarket batteries won’t have) needs changing so the car knows it’s a new battery, but I’ll do the lot and the ah most likely 68 to 70 if you have agm
  2. I’m literally doing mine on Saturday, battery was cheap enough but VCDS was £299 (10 car vin) But as my cars getting on now and no plans of getting rid, VCDS will come handy going forward. I can let you know if I lose anything but I’m only suspecting trip counter tbh, if there’s anything else it’s easy to set back up again anyway
  3. I replied saying I’ll change it next time I get 12v, I lied a little as it’s done it a few times since. Happened today so I’ve ordered a 10vin vcds (can finally use that to get tmc working again too woohoo) Also new Varta AGM A7 battery ordered So my battery has lasted longer than I thought and if I used my car properly could have lasted longer (only use it once a week for around 8 miles) Car was registered in April 2016 so battery probably at least from late 2015/early 2016, so almost 9 years old not too bad
  4. I wish there was some indication because then I’d drive a little further. Only way I can tell is auto gears hold longer and revs higher than normal, time I’ve noticed I’m usually just about to get on my drive 🤦
  5. Jeez yeah that’ll do if not excessive but cheap enough
  6. What happens when you press the button on/off which disables rear sensors? It’s next to gear stick I’ve never used it but I’d imagine it only disables it until next restart, but might be worth pressing it harder than usual to see if anything happens
  7. Much better doing an Italian tune up now and again. Engine flush is good for countries which crap fuel and oil or the more politically correct way “countries with high dust” I believe the term is. Depending on your annual mileage you could always opt for bi annual oil change, instead of once every 12-24 months
  8. Dirty buggers My first car was a K reg Audi 100 (year or so later got renamed to A6) and my insurance then was like £800 20 years ago or so and I was 19 ish, but I remember looking a Peugeot 306’s and was double what my 2l Audi was to insure. But yeah when you change alloys deffo declare it, it “shouldn’t” increase it by anything in theory especially if you get OE ones but make sure you tell them it’s genuine Škoda Superb alloys, just different style
  9. £3k for insurance? Jeez! I might just stick with my current insurance company, I got in a grump because it’s going up £40 this year to £320 Guessing you’re a relatively new driver?
  10. Oh result, clearing the code in code readers should have sufficed though. BTW is your car still on original battery? If so might be time to replace in the near future
  11. Fairly certain it won’t be compatible, if it has a make then check their own website and see if they sell two different versions, if they do then nope won’t fit
  12. If it’s mostly down by where the DRL’s are that’s normal because of poor design, basically LEDs don’t produce as much heat so get condensation. You should see that your actual main beam the condensation isn’t there because it’s warmer
  13. Hmm, can’t work out your badge if it’s black or not, if it isn’t then you could do. These badges are black but with the background of your paint colour, looks good on white cars https://www.kopacek.com/skoda/superb-iii/superb-iii-original-skoda-emblem-int-version-front https://www.kopacek.com/skoda/superb-iii/superb-iii-original-skoda-emblem-int-version-rear and rear superb wording in black https://www.kopacek.com/skoda/superb-iii/genuine-skoda-autoas-rear-emblem-superb-sportline-black-version Then I would change wind mirrors to be black BUT!! You will need to declare these mods including alloys to your insurance company, I had a hell of a time trying to explain to my insurance company about my want in changing the wing mirror covers to a different colour (business grey to hyper green) and I gave up on the end as they seemed thick as hell (probably need to revisit) So might be worth ringing them up and see if they will continue to insure you or how much your insurance premiums will go up. You could always just do it but run the risk of the insurance thieves seeing it as an easy way out should the worst happen, up to you ultimately
  14. Hmm there isn’t a way to disable the fob from opening so that suggests the actual key is at fault, try the spare key and see if you get the same. Hold down boot opening button for a few seconds. As for virtual pedal not sure, reading some peoples stories on here it’s hit and miss I believe, but one thing at a time and start with fob
  15. Does yours have electric boot? Being SEL it should. For the key, I take it you held the button down and not just pressed it once, and tried on spare key? What happens when you open it manually by pressing the button on the actual boot? Could be motors failed but after 3 years seems unlikely
  16. Okay so next up either get something like vcds, obd11 quite pricey, find someone on here who has vcds or take your car to a VAG specialist (most likely will use vcds anyway). The problem taking it to a non specialist garage is they’ll most likely use generic code readers, but you’ll need to make a point that it seems to come on after 17 miles. This is why buying vcds yourself will be better because you can do all the logging yourself, but tbh I wouldn’t know exactly what live data you’ll need to log but I guess they’ll be one for abs sensors
  17. I believe you said it was the front left which shows the error? is this the one with the odd tyre? You can always move the wheel from front left to rear left and see if the issue follows
  18. Why are you considering an EV when everything is fine with your car? For me there isn’t any benefit to go EV, especially now EV’s will be paying hundreds in tax, you’d think the government would have kept it free but Labour hate us “rich” people who own cars so hardly surprised
  19. So I’m a bit clueless but had to look again and it was spinning, I also turned it down to LO from 23 and set it to max for windscreen I think the car is getting a bit dictator like. I’ll ignore it for now as I don’t want the stress again and hopefully when things heat up in a few months it’s still cold inside and fan spinning. Still convinced I have a really really slow leak though because of the pipe being oily and tape around headlight cables looks damp but could be from when previous issues. Does VCDS show refrigerant weight? Hopefully getting vcds soon and would be great if it did, I suppose worst case it’ll say if there’s low refrigerant when the high pressure sensor notices
  20. So long story short I believe I have a leak on my a/c pipe by the back of the headlights It went into Skoda who said the leak was at the joint where the pipe joins behind coolant tank (thin pipe goes to thicker one) back in 2023 at some point I was adamant I saw the leak (ended in a hospital visit) on the thin pipe by headlight, had two dealers look at it and said it wasn’t leaking, but if I put my finger at the bottom of the pipe it’s oily and smells a bit like refrigerant, so I’m convinced I have a leak there Anywau it’s been fine for ages (probably a year at least) getting nice cold air, today I got in my car and had condensation and put the blower onto the windscreen and took a while to go I lifted the bonnet to check the fans and neither are spinning, so question is when a/c is activated should one of the fans be spinning all the time? To me it should be Outside temp is 5oC at the moment which I believe means a/c should be running and fan spinning. I’ve got a horrible feeling all the refrigerant has gone so a/c won’t kick in because it’s effectively empty, I suppose if I had vcds I could see the coolant grams or at least an error? thanks
  21. At least with the non 4x4 you don’t have to do Haldex oil changes and filter cleaning (I believe dealers don’t clean the filter but should). Even though the 4x4 would be better for towing if it didn’t have factory fitted tow bar then the car could overheat when towing because factory fitted then means bigger fans I believe
  22. What’s the recommended approach to changing the diesel fuel filter Is it always suck out diesel in the housing, clean then part fill housing with fresh diesel, put in new filter then top it up? or suck out diesel, clean up, put new filter in and use like vcds to pump new diesel in?
  23. Most likely failing battery, how old is the car and is it still on original battery? No way for certain to prove if it’s the battery which came with it but have a look for a sticker which says BEM then some numbers, if you see that it’s likely to be original because most people will unlikely get a replacement from Škoda
  24. I had this several times, then replaced rear discs and pads and never had the issue since. Guess it wasn’t releasing pads quick enough but not really sure. As it sounds silly cold where you are what’s the general battery condition like? Anything over 5 years old it might be worth getting a new one
