Everything posted by Gizmo
- Octavia 3 vrs recoding
Poor headlight range MK3 Superb
Never had ANY issues with mine, apart from the Matrix LEDs we now have on both of our cars they were the best headlights I have had. 50% of my driving is done at night on poorly lit roads.
What trim level? "Superb 3 Executive" I assume you mean the SE L with bi xenons?
Looking for help with my audi a4 b7 stereo
Unfortunately VCDS cannot get a radio code
Superb II - Enable rear DRL's
It’s possible, I have done it but I’m in Folkestone
I broke my fob
No you will need the transponder inside the case to start he car.
Kodiaq
DSG and Haldex are not done under normal services, they are an extra. IF you dealer says either doesn’t need doing then find a good independent VAG garage to do it.
Kodiaq
Every 40k miles worth doing the Haldex at the same time (oil change and filter clean)
Wheel spacer opinions?
It's a declarable modification. It will put extra stress on the wheel bearings.
Engine off, but trip info remains
The maxi dot stays powered up for around 30 seconds after the car is locked. It then powers back up once unlocked.
VCDS options on Superb III
09 Access permission: 31347 Adaptation Leuchte16BLK SLB35BLK SL KC9 (Front left eyelashes) Light function C16 put on "Daytime running lights" Dimming value CD 16 Put on "100" Leuchte17TFL RLK SRB3TFL R BLK SR KC3 (Front right eyelashes) Light function C17 Put on "Daytime running lights" Dimming value CD 17 Put on "100" This encoding will work only for the vehicles which already shine "Eyelashes" in light by the work have. If no lashes out at the park light light, the corresponding lamps are not installed. That you can easily check if they are installed: Is available in the channel Light 16BLK SLB35BLK SL KC9 Light function A16 "Inactive" in it, then the eyelashes are not installed.
Wheels & Tyres: Bridgestone Potenza S001 225/40 R18 92Y XL
View Advert Bridgestone Potenza S001 225/40 R18 92Y XL 1x Bridgestone Potenza S001 225/40 R18 92Y XL 6.2mm of tread remaining. MAY be able to drop off en-route between: Folkestone (CT18) to Burntwood (WS7) via M20 / M26 / M25 south / M40 / M42 Advertiser Gizmo Date 04/09/21 Price £50 Category Wheels & Tyres Wheel Size R18 Tyre Season Summer Shipping Estimate £0
The 'new' green numberplates.
Correct only the middle ones are legal, the other two were under consideration. You can still have the GB etc in the green band.
EV Insurance cost, servicing, how to spot a dud etc.
The ID.3 is 7 seconds 0-60, so hardly what you would call slow, yes is limited to (IIRC) 100 mph, but who really drives quicker in the UK? I also got a quote for a Polestar 2 (0-60 in 4.5 seconds was still £250 ish.
40 kWh Leaf and now ID.3 Tour. No dearer than a 170CR 4x4 Yeti L&K (£247)
Eibach or H&R Lowering Springs 2.0D 190bhp Hatch
Eibach every time for me. Only had them combined with a B12 kit though, it transformed both cars.
Skoda Members' opinion is required
@Agalalh https://www.briskoda.net/forums/guidelines/ All posts should be made in English. The use of other languages, or "txt speak" is not permitted and will lead to posts being removed.
Relay Attack - mitigating the risk
Yes it’s something I coded for the person who wanted my Superb (but then messed me about and didn’t view it): Disable KESSY door locking / unlocking 05: Acc/Start Auth. Coding Byte1 Tick Bit0 Passive entry driver door handle, not activated Passive entry frt.pass door handle,not activated
Variables
Some brands are far better than others for getting close to their claimed range. heated seats use less power than heating the whole car. A/C has next to no effect. Speed is the biggest killer of range, if you can stay below 60mph they you may even beat the claimed range. The weather is the next, rain and the cold are really bad, warm weather is good. Our Nissan Leaf had a claimed range of just over 160 miles IIRC, in summer we could get close, but in winter 100 miles was more realistic, BUT that is driving at NSL and as warm as we wanted to be comfortable (21° for me and 23+° for my wife.)
Rear windscreen wiper switch
In the 5 ½ years I owned my MK3 not once did I think ‘I wish it had a rear wiper’ but mine was ceramic coated (windows also treated).
If was a free option.
Usually you push the stalk away from you.
Battery maintainer/charger/support unit/LiON jump starter when coding with VCDS
The first thing I code is the option to turn the DRL's on and off in the infotainment so you can minimise the power draw whilst coding. Personally I have never hooked a car up whilst charging as the car will tell you when the power has dropped to a critical level (I then run the engine). That said I have since bought a smart CTEK battery charger, which I am very impressed with. My mom has a car that hasn't been driven for 7 years, a couple of chargers failed to charge the 'new' (unused) but 7 year old battery, my CTEK bought it back to life.
Superb MKIII owners register
Ideal time to retrofit a flat bottom or heated wheel with flappy paddles then.
Bilstein B6
Let’s hope they are in stock! Had a B13 kit on order for about 8 weeks now and it will be an estimated 5 more weeks before they are made.
