Everything posted by tetley
K0diaq 190 overheating
"Hydrometer" - used for measuring density of liquids the specific gravity. You could also use a "Refractometer". Does the same thing but by differently.
Intake Air System Leak P2279 / EPC Error
Have you tried pushing the tube on further? There should not be any loose tubing. Have you seen this? https://www.youtube.com/watch?v=IN32XePLHdk
Warning light, not fully illuminated
Not strickly true. It depends on the LED and the circuit. However I do agree, ensure the vehicle interior is completely dried out and free of any condensation before appying a fix. If the OP can, take the instrument cluster out and store it somewhere dry and humidity free for a day or two. On top of a desktop computer/server would be my best option but an airing cuboard or some place like that would do.
No. The replacement would need coding with the mileage and the immobiliser code otherwise the car will not start. LED replacement is cheaper.
Front passenger door permanently locked
Hi @JamezF Keep me updated as at some point I will be dissembling the drivers door. Do you have the link to this manual you can share. Thanks, Kev.
Scout clutch - what else should I do?
Not being a mechanic I don't know much of these things but the very small "tin pot" vehicle repair garage behind my wifes business dug out an inspection pit. Is that a reasonable alternative? Maybe @J.R. could comment.
Bluetooth Phone Module Upgrade
No idea. I have a 350GB HDD connected to the MDI and play mp3 files from that.
Skoda Octavia MkII maintenance & service
Brake fluid change - I think every 4 years. Check/Change coolant Aircon recharge - Every 2 years Oil filter replace - When doing the oil change. Cabin filter Car alarm replace - I think every 7 years. Serpentine belt - If you have one. If not in the UK then an annual MOT style check.
Hunting and surging engine
It would be a good idea to state what engine you have. Some car history would also be a good idea, mileage, servicing how long the problem has occured, when it first appeared. How long have you owned the car. Kev. Edit:- Also forgot to say - Have you carried out any diagnostics such as with VCDS.
Returning octavia owner 1.8t L&K
It's already been replaced. How do I know? There's a project thread here:- Kev.
Brake fluid change.
Are you from the future?😄
Coolant Temp Gauge Reading 50 - 55 Degrees
The Laurin + Klement all came with the maxidot as standard. So yes it will have a maxidot.
changing vehicles Insurance tax etc
Yes It is instant. I know your question does not involve MOTs but my son was able to advise my car passed it's MOT before I collected the car within half an hour of the test centre phoning me by using an app on his phone. The V5C is not proof of onership anyway. It just names the person responsible for taxing the vehicle. Insurance wise, the insurance companies deal with this all day long. They will take your money. Lastly, I should wait for others to confirm (or refute) what i have said.
stream(non mp3) bluetooth module install
Is there an AUX socket in the armrest? If so I would take power from the cigarette lighter socket and use the aux in socket in the armrest by changing the connections on the bluetooth dongle to: Ebay 12V Male Car Cigarette Lighter Socket Plug Ebay 3.5MM jack Male Female Audio Cable Aux connector That way it can be unpluged and kept for later use.
intermittent battery drain & ESP fault Laurin & Klement
Heated seats and the telephone module is bolted to the floor under the plastic cover below the drivers seat.
Battery earth strap corroded?
My recently aquired 1.8tsi octavia brakes
To wind me up apparently. It's the one add on I desire the most. When new they cars did come with a plastic accessory lighter blanking plug in the socket unless the "Smokers Pack" add on was ordered as an upgrade. Engine wise, there are a lot of scare stories. But also it's a desired good engine when looked after. Good quality engine oil is your friend (so I've read). I am going to upgrade the timing chain tensioner that is an issue on the second generation EA888 engines next spring. ~£30 for the part. I have already bought the timing chain tool kit. Good luck with the MOT and report back please. Kev.
The mechanic is correct. My car has been like this since it left the factory. I suspect that now the brakes have been bled you have only just noticed this happening. When the car is in motion the brakes operate correctly but at a standstill there is extra travel if you apply more pressure to the pedal. As this is a thing you never normally do you have never noticed before. Take the car out on a quiet road and perform an emergency stop checking no one is behind you before hand. All should be well. The other thing to check is with the engine stopped the pedal should be rock solid when pressed and no travel. Kev.
Trolley jack reccomendations and ones to avoid.
@SuperbTWM Sorry.... I didn't ask. How are you finding your new jack? Also, Machine Mart Leeds has become my new favorite shop. Very friendly staff who are willing to accomodate me with my questions.
Whats the lift height? The one I ordered was delivered today with an extended lift height of 535mm and not the standard lift height 465mm that I suspect is the varient that both @J.R. and @StevesTruck must have purchased when they have mentioned that my purchase is available cheaper elsewhere.
2008 Mk2 1.2 HTP - Reviving help
Skoda Fabia II Relay Removal.pdf PDF with all the required pages 113, 132, 133 and page 136.
Give me a moment .....
https://cardiagn.com/2007-2014-fabia-electrical-system/ Scroll to page 136. I think this is what you are looking for.
- Octavia Scout Engine Swap
- Rear Window Wiper Repair
