JR RS
Everything posted by JR RS
  1. U'll need to recalibrate the DCC if u increase or decrease the spring height. This requires OBDEleven or VCDS, and all 4 wheels suspended in the air.
  2. i take it you didn't make a backup before u went made all those changes?!?! also, for the DRL stripes to work, u need version B bi-xenon headlights, not version A. u can tell by the part number on top of each headlight.
  3. Wat's a lower spec radio? I have the MIB2 Columbus "high" unit, and I have the button on the B-pillar.
  4. @Bap33 - sadly that didn't make a difference. I believe something changed from MY17 to MY18. Hence why it's not working on pre-MY18. Would b interesting to see how @Karlc28 got it going working on their MY17. Probably it's a 2017 build MY18, which would explain why it's working.
  5. There is a button on the B-pillar to turn off the interior monitoring.
  6. @Danoid - why is it a requirement that u want the foglight to dim?
  7. i don't have a tow bar either, so my bikes go on the bicycle rack on the roof bar.
  8. Awesome. Looks OEM. Well done.
  9. Ur link doesn't work - can't see the pic. As for lift kit, here is one I took earlier of Gandalf pretending....
  10. Nice holder u've created for the front area view camera But please tell me ur going to paint it black......
  11. given u have no Comfort mode, that is an indication u don't have DCC. visually, u can physically have a look at the shock absorber to see if there is protruding small cylinder bit, as shown by the red arrow in the pics below. if it does, u have DCC. if it doesn't, u don't have DCC. via the MIB unit - without DCC via the MIB unit - with DCC
  12. If u have the facelift Superb with Matrix Crystal lighting, then that bit lights up as the "Side Light". This is in addition to the fog lights cornering light function. This video explains and shows it clearly.
  13. Just change. No need to code or recalibrate, provided u haven't changed the DCC controller/module.
  14. Agreed, the Leyo paddle shifter extensions r next level in terms of fit, finish & feel. I got the silver ones on mine.
  15. All good. Just to b clear, the jacking points, and axle stand points r easily accessible and visible on the mk3 Superb.
  16. Kopacek is ur place, if u want genuine and good quality. Shipping is not cheap though. If u want cheap, AliExpress.
  17. I've driven 30km when the Range was showing zero. I drove a total of 981 km on that single tank!!! I've got a 220 (162TSi). The Superb comes with 2 different tank sizes - standard 66L size and a larger 75-78L size. PR codes:- - 0M4 = standard fuel tank - 1Z2 = Increase in initial standard fuel filling Hence if u have both PR codes, u have the larger tank. The larger tank is only available in certain markets. I regularly fill up 66 to 71L each time. Most I've put in is 74.8L.
  18. After 6.5 years, decided to change Gandalf's personality. Really pleased with how these turned out, and the fitment is spot on. Rotiform LAS-R 19x8.5 ET35 Matte Black finish.
  19. I like Rotis. Gandalf likes Rotis. Together, they make a good form!! 😂 Really pleased with how these turned out, and the fitment is spot on. Rotiform LAS-R 19x8.5 ET35 Matte Black
  20. I have an Aussie Superb - only the outer rear seats have Isofix points, and rear tether points. The middle seat only has an upper tether point.
  21. correct, the option is there from MY21 onwards, on a number of new models. Optional USB-C port above the rear-view mirror - Å koda Storyboard (skoda-storyboard.com) that is certainly handy to have.
  22. Simple answer - no. The interior lights turn on/off based on varying conditions, which is not good for a dashcam.
  23. yes, definitely fixed - no moving bits. they r used as "cornering lights", but unlike the headlights, they don't swivel. it just turns on the individual fog light on the turning side/direction.
  24. sounds like u r referring to either the additional USB port, or light. the USB port is not standard, and usually there is a blanking plate there if its not factory fitted.
