JR RS
Everything posted by JR RS
  1. Large drop!?!? If u have DCC, the drop is only 20-25mm. If don't, then the drop is 30-35mm. Anything more that 40mm is starting to get "large drop" and will affect other suspension components. This is mine on Eibach Pro-kit Springs.
  2. Earlier MIB3 units in the facelift Superbs did not have wireless Android Auto. They only had wireless CarPlay. Unfortunately I don't know the associated part numbers.
  3. i had issues with my (MY17) memory seats in 2019 - they (Skoda Service Centre) ended up replacing the seat controller module as the software update didn't fix the issue. it has been good ever since. Old: SW: 5Q0 959 760 B / 0021 HW: 5Q0 959 760 B / H08 New: SW: 5Q0 959 760 C / 0024 HW: 5Q0 959 760 C / H09
  4. I disagree - the Bi-Xenon lights on the mk3 Superb r great, provided they r correctly aimed. U can swap out the D3S xenon bulbs for better ones, but either way - it still needs to b aimed properly, just like other cars. I've got the Phillips xTremeVision Gen2 in mine.
  5. @chris1949 - u definitely have a pre-facelift, that was registered in 2020, not built in 2020. As already mentioned above - u can't adjust the high beam separately to the low beam because Bi-Xenon. That said, I have a pre-facelift Superb myself and the high beams r good. Here is a video of my high beams in action... https://youtu.be/v3BgUfsupkM?si=OyWtyZkNmWSTLdAU
  6. +1 to remove the A-pillar trim and run the dashcam wiring along the existing wiring loom. It is easy to tuck it under the A-pillar trim and just run it down to the side of the glovebox fuse panel, but that will likely fowl the curtain airbags from deploying properly. The A-pillar trim is a pain in the behind to get back in but it's the proper method. This is mine, in the process of cable tieing the dashcam wiring to the existing wiring loom next to the windscreen, away from the airbag (white).
  7. @chris1949 - post a pic of the front of ur car, that will clarify things. In 2020 Skoda was rolling out the Facelift Superb out of its production lines. Here is pic of the two. Top is facelift, thinner headlights, thinner fogs and wider grille. Bottom is pre-facelift.
  8. Pretty sure the 2020 Superb doesn't have Bi-Xenons, and has LEDs. The pre-facelift used Bi-Xenons.
  9. The rear parking sensors r located on the lower diffuser section. U can easily remove this bit alone without removing the entire rear bumper. It's got 4x torx screws underneath, and then clips across the top, and either end.
  10. Have u done the mirror position store procedure? It's all there in the manual. Putting it in L or R, or Reverse will do nothing unless u've performed the initial procedure. Once it's set, then just leave sure ur mirror toggle switch to the passenger one, so each time u put the car in reverse, the mirror will drop.
  11. @komoornik - oh, that's interesting. maybe u got the "non-chip shortage version" of the Canton system. or maybe it was just the iV Superb that has the dumbed down Canton System?
  12. U need to b within 3m of the car for KESSY.
  13. That's because they changed the Canton system with the facelift Superb. If I remember correctly, there is also no longer a large Sub in the left side of the boot. A shame they went backwards with the facelift Superb. In fact they went backwards on a few things.
  14. @dimushor - have a read of my TPMS retrofit discussion, hopefully u can follow the coding steps, and U can resolve the issue. As for ur traffic sign recognition and navigation not working - can't help u there. With regards to uploading the TPMS parameter set, this can only b done via VCP or ODIS. U can't use "car scanner pro", or VCDS or OBDeleven. That would explain why u have an error. When u do such retrofits u need to b exactly sure of the changes u make, and use the correct methods/tools. U say u followed the instructions in the links, yet u have no idea of wat u did!?!?! If ur not sure or confident, u need to get someone who does know wat they're doing, otherwise u get into situations like this.
  15. assuming u bought a TPMS that wasn't preloaded with a dataset, how did u upload the dataset yourself? why did u reverse the changes? if anything that would make it worse if the TPMS hardware is still installed/connected. if i were u, i would take it back to the "service man" and tell them to fix the things they have broken. if the TPMS was installed and coded correctly, it shouldn't cause the issues u r seeing.
  16. That's good news, and thanks for ur prompt response @ApertureS If I do go ahead with the VC upgrade, I will also swap out the MIB2 unit for a MIB2.5 unit. That being the case, I believe a MOST Cable and Splitter will b required too. Now I just need to figure out the correct part numbers for the 9.2" screen, the MIB2.5 unit, the VC + surround trim, MOST Cable and Splitter.
  17. @ApertureS, @langers2k - I'm considering my options about doing a VC upgrade on Gandalf (MY17 Superb 220). I currently have a MIB2 Columbus unit, with Canton. However a couple of questions before I contemplate going down this path, hence seeking your advice/thoughts. 1. I recently changed my steering wheel to a flat-bottomed version, 309458999AQF-AA (DSG, non-heated). It doesn't have the VIEW button. Instead of replacing the whole steering wheel to one with, can I replace just the buttons, to the version with the button - specifically 3V0 919 719 F? 2. My current Gateway is:- 3Q0907530AA / 5366 (Software); 3Q0907530C / 515 (Hardware) It was recently upgraded (flashed) when I had the DCC mod done. This meet requirements? 3. My current 5F Infotainment is:- 3V0035045D / 1433 (Software); 3V0035045 / H50 (Hardware) This meet requirements? 4. My current 09 Central Electrics is:- 5Q0937084CG / 0236 (Software); 5Q0937084CG / H34 (Hardware) This meet requirements? Thanks in advance.
  18. The wing mirrors on my MY17 Superb open when the car is unlocked, not on ignition.
  19. @WanderingDutch - there r multiple versions of "Columbus". Wat is critical is the MIB unit. Sounds like u have MIB3 unit, which was introduced with the facelift Superbs. U'll find most the people with issues have the MIB3 (Columbus) unit. U'll also find it's not just Android Auto issues, but broader infotainment issues. The issues r also found in other models such as the Octavia, Kodiaq etc. etc. with the same MIB3 Columbus unit. Those with MIB2 (Columbus) or MIB2.5 (Columbus) do not have issues with Android Auto, usually. If they do, it's cable or phone related. It is also important to realise that only MIB3 units r capable of wireless Android Auto and CarPlay, built-in. The MIB2/2.5 units can only do wired Android Auto and CarPlay. However adding a dongle such as AAWireless, Motorola MA1, OttoCast etc. etc. will allow wireless connectivity. I have been using AAWireless with my MIB2 Columbus unit for many years now with no issues with connectivity or quality.
  20. Provided they've performed the procedure to store/save the memory position.
  21. Yes, wet clutch DSG needs regular servicing - every 60,000kms. dry clutch DSG is sealed, and hence not serviced.
  22. The later Superbs use the Wet DSG-7, which is reliable and different to the troublesome Dry DSG-7, used in lower power engines. Before that, the Wet DSG-6 was used, which is also reliable.
  23. thanks for the write-up and sharing the amazing mission impossible work u've done to ur Superb!!! the Area-360 has my attention, but the complexity of all is not something i'm keen on tackling myself, so i'll just leave that on my "ur dreaming" list. i have however keen on how u go with the additional USB ports retrofit. i've researched on this a few years back, and i think i have a good understanding - i just haven't prioritised this retrofit as its not critical. if u do get around to doing it, i'd like to know the details, so i can then pull my finger out and actually do it. good luck with the rest of the stuff.
  24. @chli @vegarz @ace_finland with the B201A error, u need to generate a code, using an XOR Calculator. This is generated based on your existing adaption value (Step #1), in combination with the decryption key, which in turn generates a new Key (Step #2) for you to enter (Step #3). below is a screenshot from a how-to document i created, which contains the steps to fix the B201A error.
  25. It's a small cut out of the plastic trim - easy to do. There is enough room in the wheel well to fit a 19" wheel.
