travs
Everything posted by travs
  1. What's the model and year? Depends if you have MIB 2, 2.5 or 3. This is no connection at all as opposed to connecting and dropping? From memory, I think Wireless Carplay connects via Bluetooth initially and then hands over to Wi-fi. If its failing to connect in the first place, it might be a bluetooth thing. Having said that the BT connection and hand-off might be quicker than noticeable and the wifi card isn't picking it up. Have you changed the car's wifi SSID? (I changed it to my number plate and that was silly). Or allowed the car to connect to home Wifi? I found doing that meant issues like driving away from home connected to carplay and then dropping the home network and be stranded without an internet connection until the car asks if you want to use the phone's mobile signal etc. I have MIB3 I have found dropping started with with v330 and v332. It happens momentarily once in a blue moon with the cable - that'll do for me.
  2. Good work. You can get barrel brushes to clean the barrels and wheel mitt to run round the inside of the spokes, but that spoke count doesn’t make it easy - those aesthetics come at a price.
  3. What’s your budget @gav_is_con ? Blue one This is interesting as it is a partial facelift - SKODA written on the back, but it has MIB2.5 as there are SD card slots in the glove box. Leather looks like it could do with a bit more of a clean too but don’t let that put you off. Low miles for the age. No sunroof. Lucky at that point to get digital dash too. Grey one Costs more and higher miles but will be a full facelift with the EA888.4 DNFE engine with the decent Continental turbo. Can’t see a sunroof and none mentioned so should be good for that too. Will have MIB3 but money is on the firmware needing updating.
  4. Products depend on dilution ratios as well as pH. Neat HCL Acid is about pH1 and would melt your eyeballs. But diluted 99:1 (99 parts water) is pH1.4 so not much weaker as an acid but you could happily wash your face in it. What you’ve found is that acids are much better at breaking bonds between dirt and wheel than either pH neutral or alkali wheel cleaners. Iron Fallout Remover uses ThioGlycolic Acid which, for the Iron particles in your paint, combine to create ferric thioglycolate which is (a) reddy-purple and (b) water soluble (easy to remove by jet wash). What you’re finding washing wheels is picking up the iron coming off the brake discs, and the acid is a more effective cleaner. So - depending on what acid is being used and its dilution ratio depends on how effective it is and how careful a consumer needs to be (as opposed to a commercial valet/detailer). Erring on the side of caution is definitely the better tack to take but no hazmat suits are needed. Autoglym Clean Wheels has HCL in whereas Turtle Wax Wheel Cleaner has Sulfuric, Oxalic and Phosphoric Acids in. Sound terrible but are in small doses and consumer friendly. HCL will attack aluminium whereas other acids won’t so much. The one acid you want to watch out for is HydroFluoric. It’s a contact poison that gets into your skin and causes damage well after you think you’ve washed it off. Some cheaper manufacturers use it for waterspot removers but that’s generally it. That is the only acid that will attack chrome. All factory finish alloys are clear coated though so won’t have any issue withe these products. Long story short - acids are better at cleaning but more aggressive comparatively. You can also get wheel mitts which allow you to contact wash behind the spokes just to be sure.
  5. I googled to be sure: Part number 3V0035411J is a genuine Skoda/Volkswagen Group bass loudspeaker(woofer) used across several current vehicle models. Product Specifications Part Type: Bass Loudspeaker / Woofer. Driver Type: Midrange/Bass. Impedance: 4 Ω. Weight: Approximately 0.66 kg to 1.08 kg depending on packaging. Placement: Suitable for both front and rear door installations. Vehicle Compatibility This speaker is specifically designed for vehicles equipped with upgraded audio packages, such as the Canton Sound System. It is compatible with: Skoda Superb MK3 (3V): Models from 2015 through 2024. Skoda Karoq (ND/NU7): Models from 2018 onwards. Skoda Kamiq (NW): Models from 2019 onwards. Skoda Scala (NW): Models from 2019 onwards. Seat Ateca (5FP): Models from 2016 onwards. Key Differences from 3V0035411K While both parts are woofers for similar vehicle platforms: 3V0035411J is often listed as the standard bass speaker for a wider range of models including the Kamiq and Scala. 3V0035411K (mentioned previously) is more specifically associated with the high-performance Canton setups in the Superb and Karoq. The "J" version may be interchangeable with the "A" version (3V0035411A) in some catalogs. I think that K is Canton and J is standard. J is updated version of A. As an aside L looks to be rear door so that’s irrelevant. I’m putting my money on J if yours is non-Canton.
  6. Knew I’d seen something’s about speakers recently. I am pretty sure it has been said that there was no difference in the speakers between standard and Canton - just the DSP and amp/sub. Part numbers
  7. So it’s had no service in 2020, 2021 or 2024? In UK, it’s the done thing to have an annual service irrespective of mileage - may seem over the top in some cases but it never hurts to at least change the oil and give the car a once over. It might be fine but personally, unless that’s a standard scenario where you are to service every other year I’d walk away. One of the key things that stops us in UK from looking in other countries is the RHD/LHD thing. If prices are better in other countries can you go over a border and check out options there?
  8. travs replied to travs's topic in Tyres & Wheels
    Thanks for that - think I’d just spotted a post with you mentioning them and was going to ask what you thought of them. That sort of price for sub-9kg flow-formed seems better than my expectation at least.
  9. Hate to tag the man in again but @JR RS has done this but it may have been to the rear one. He’ll likely have a part or a how to or knowledge either way
  10. Try also long coding. There is one section where you can select different steering wheel models. I did it and accidentally stopped my heated steering wheel button altogether. It’s one of the last bytes in the chain (if that makes sense) but I cannot remember which section offhand - be it HVAC, Central Electrics etc
  11. Best of luck 👍🏼 Let us know how you get on
  12. @seanw I think this is the light under the door mirror that shines down as another puddle-light type.
  13. Thanks for correcting as ever 😁
  14. It’s not the lights turning, it’s the little triangular corner section underneath which comes on under a certain speed for manoeuvring - well def for facelift versions but think they’re there for pre-FL too
  15. Depends which year your car is and whether you want Android Auto or CarPlay. If you have MIB3 then yes it’s built in. If not, then it’s a bit more year-dependent. If all else fails, you can get something like an Ottocast and use that as a link.
  16. Ok that’s very very old software. 332 is the current (and possibly won’t be updated past that tbh) but it went (I think from what I’ve seen) 156 236 270 276 278 306 308 330 332. The one you’ll absolutely need is 308 but you may need something before. The other thing is there’ll be FEC codes needed too. Tbh whilst you can do it, I’d say best to get it to a dealer, explain the situation and ask them so they do all the associated work to it as well.
  17. Does look fantastic. My 2021 L&K has passenger memory so it must be that trim basically. Certainly looks it from the spec you put in the original although if it’s an official import and demo it may well have had options. Interesting it’s 200kw in 2021. That would mean it was the EA888.3 GPF model (DNUA engine code). Are you sure that’s the case? By 2021 they should have changed over to the EA888.4 but different models and markets may have had a different changeover date. Easiest way if not sure is pop the bonnet and look at the engine cover.
  18. What firmware version do you have?
  19. Yes - weird name change but they’re and the same. Plenty of bits on there to look at for sure!
  20. Look at Skoda update portal and see the map download - I’m guessing it’s a different part of the world map.
  21. Superskoda/Kopacek are the place to go for black badges. They get a local dealer to spray to match your body colour. Match that to wrapping of the window surrounds. Aluminium pedals? Ottocast for wireless AA/Carplay? Cool white interior led bulb set?
  22. On the basis of USB-C being mentioned in the front, then this sounds like a facelift and the SD slots aren't there. I could be wrong and there could be a changeover/crossover period but otherwise see if OP confirms trim and year
  23. Not compared to the what I've been reading - with the engine up to temp and more steady-state throttle its better than frequent accelerations when the car is cold. If you've got a sensor out somewhere the mixture may be rich hence increased fuel, and therefore soot. Did the garage run a diagnostic on it and see if there were any fault codes?
  24. You shouldn't have any reduction in ground clearance with different wheels - all that happens is that as you reduce the wheel diameter, the right tyre for the car has a higher side wall. The overall diameter of the wheel & tyre should remain the same. If not, the circumference changes and the speedometer is rendered less accurate. On the flip side, this does mean tyre pressure affects the ride more as a lower pressure will result in the tyre compressing more to absorb more bumps. Depending on whether the tyre pressures are low (or on the lower side of correct) could mean there's been a little more overall travel (tyre and suspension) than if the tyre was set for a fully loaded vehicle. Its not going to be much but it could have made the difference. I'm not spotting anything showing the panel gaps are woefully different but it does sound like something happened if you're getting a different sound. I think there are mounting points for the bonnet which may need adjusting. If nothing else, get yourself to a good independent and see if they can look it over with a little more of an experienced eye. A 4-wheel alignment may also be worth it in case any suspension components have taken a little more energy than imagined.
