- DIY ABS warning Fix
Motecarlo, 1.2TSI 105hp 2014 Timing chain tensioner failed
Please let us know the outcome. 🙂
I guess that looks encouraging, but if the check engine light was on, a code should have been stored. What made you think the tensioner failed? I could lend you the timing tool kit and potentially some help to use it if you're not too far from Highworth. Shall I start a PM chat with you?
I think a single-tooth skip might not be catastrophic on that, but I'm not sure. Whereabouts are you based? There's an inexpensive timing tool kit that could be used to check the current situation, but it needs a little effort and raising the car a bit off the deck to fit the crank tool.
Chain engines can usually be distinguished fairly readily by the chain cover being sealed (because it has to keep oil inside). Belt engines have looser fitting, unsealed timing covers.
Engine code is often on a sticker on the upper cambelt cover (for belt engines anyway). Also on V5. See: Engine code and why it's useful to know - Handy Topics & Guides - BRISKODA
Windshield from the VIN number - help needed
The description of the windscreen for the provided VIN, of a car with heated windscreen is: "Heat insulating windshield". To me, that didn't sound like a convincing description of a heated windscreen, so I suggested that you might be able to confirm. PR code was 4GW. I have (paid) access to partslink24, but not always much knowledge about what I'm looking at.
EGR error after replacement
Maybe measure the 5V supply that goes to both the EGR valve potentiometer and the MAP/IAT sensor. Red/green wire at each of those connectors, measure relative to the brown wire at MAP sensor, and relative to the brown/blue wire at EGR connector. Ignition/contact on, or engine running when measuring.
- S44
- EGR error after replacement
ODB port not connecting to scanner
Yes, it causes owners in RHD countries plenty of head-scratching. Cost saving.
- ODB port not connecting to scanner
No, you just have a RHD car instead of the LHD the manual pictures. Fuesbox is just rotated 180°, in the factory.- EGR error after replacement
Another possibility, I guess, is that the catalytic converter is blocked to some extent, causing the exhaust pressure entering the EGR valve to be higher than mapped. The feedback system for EGR opening is based only on physical distance, via a potentiometer in the top part of the valve. So more gas could be flowing through EGR into inlet manifold than expected, causing higher intake temps and poor combustion. How many kilometres has the car driven?- EGR error after replacement
- S44
It's in the front half of the airbox, the section that does not need to be removed to change the filter. Wedging the flap in the cold air only position is probably the easiest solution, which can be done with a screw. Do the experiment first (running without airbox), I might be completely wrong about why the engine is having trouble.- EGR error after replacement
- Jam Nuts Issue (Track Rod End)
Or the bearing didn't go quite fully in on that side. @joeninho is the problem on the first side you did? - ODB port not connecting to scanner
