Electric windows problem.
No problem. Hopefully others in the same/similar boat can gain from reading of your experience. I quite like Parkside stuff, is that in the shops now?
Well done mate. 🙂
1.3 MPI (175 miles to a tank)
Did you have anything to measure old or new gaps? I'm no expert but I would think very large gaps will not be efficient. Late ignition/combustion start? I think you will soon see if there is a difference.
Keeping and skimming discs when replacing pads. On car, off car?
Current part number for genuine appears to be 5Q0615301G (previously 1K0615301AD) if that helps you to cross-reference something.
If fuel filter was recently changed, check the area for leaks. You'd probably have smelt any such problem though. Do this inspection without a lit cigarette. 🙂
Post photos of the plugs if possible. Don't think I'd mess about with anything else at this stage unless plugs came out looking great.
Skoda Fabia Mk2 - 1.2HTP - BBM - Poor Iddling / Cylinder 1 Missfire
I think BBM only has simple lambda sensors, FWIW.
Semi-catastrophic rear axle / shock failure
REAR AXLE SKODA FABIA MK2 FL Typ 5J 2007 TO 2014 SE 12V 5DR HATCH AXLE ASSEMBLY | eBay ? Would need to be sure it's a definite match, not sure 100% myself.
Definitely something wrong, should be much better.
If you move coil connectors around the sparks will not fire at the correct times. If the ECU detects a problem with cyl 1 it may actively shut down fuelling/sparking to that cylinder. Check that the black wire has 12V relative to earth (engine metalwork) with ignition on.
Do a compression test to see if cylinder 1 has much lower compression than cyls 2 & 3.
Which engine do you really have? I don't think there's any Fabia with a 1.3 engine.
VCDS
https://www.briskoda.net/forums/topic/498514-anyone-use-vcds-lite-on-their-early-mk2/
What's seeing off all the Fabias?
Maybe just that the youngest are 16 years old this year? Youngsters today like new and shiny, not solid and reliable, for some reason.
VCDS
Or use the freeware version VCDS Lite, downloaded from Ross-tech and a £20 third-party cable... I wrote a thread about doing this on pre-facelift mk2s a while back.
Car battery 77AH 780A on Fabia 1.9 SDI Diesel?
I think there will be no advantage from having larger battery.
New timing belt at 5 years
I think timing covers only have oil seals when they contain timing chains, not belts.
How long between timing belt change and MOT? If they were done on same visit to dealers, they ought to have spotted the leak during the belt change and asked you to approve repair. If there was any time gap then you'll struggle to prove that the leak didn't happen separately, unrelatedly. Also need to be sure which seal is affected, you mention crankshaft and camshaft.
vrs mk1 wipers always on even when key removed
Relay contacts for low speed welded together by the sound of it. How-to thread for wiper relay replacement in Fabia guides section. Soldering reqd. Or replace control unit.
Screw it back on with some self-tappers, make sure they're not stainless so they rust and blend in to be invisible before next MOT. HTH. 😁
fabia vrs o'ring sizes for intercooler pipes
Not sure how much this helps? LLLParts
Interior door release
If slackening the XZN screws helps, you could possibly slide some spacing material in from outside rear door edge, if you're lucky?
Yes, was just about to try to find the photo. Posted by @raky a week or two back.
Maybe try going the other way with the outside handle adjustment? Another member recently found that after changing a lock module he had similar strife, eventually blamed on not transferring across or replacing the rubber gasket between lock and aft edge of door. See if loosening the two main lock holding bolts helps? (As an investigation not an ongoing fix).
Was the lock removed with carrier panel, or left behind?
