Breezy_Pete
Sponsor
  1. No. Brown is earth Black/green is from/to right window switch White/black is from/to left window switch Grey/blue is illumination The switches ground/earth their respective 'output' wires via different resistances. The differing voltages that arise at the motor module pins 4 and 6 cause the different functions.
  2. I can probably find you the right part number if you PM me your VIN. The above tips look very handy though. 🙂
  3. Certainly worth a look at the wiring before spending any money on switches, I'd say.
  4. More likely a broken wire in the bellows between driver's door and A-pillar; it's almost compulsory on a mk2. What year is the car?
  5. Probably rainwater out of the longitudinal chassis member under there. It has drain holes which may have been blocked, then not. Or it may have come from higher up, there's an area under the brake fluid reservoir that drains into there, I think.
  6. 1K0 927 903 B, I think, but different if the car has 'gas discharge bulb' for some reason. I guess that means xenon headlights? In that case it would be a suffix -J at the end of the same core number. The first of those numbers has been superseded by 1K0 927 903 R, £55 +VAT. Doubt you'll find anything new anywhere other than a Skoda dealer.
  7. Possible new aftermarket candidate 6Q2 423 893F AIC Hydraulic hose, Steering system cheap â–· AUTODOC online shop Don't usually like recommending autodoc cos of awkwardness of returning to Berlin or wherever in case of mis-supply or faulty goods, but options may be limited for something with such end fittings.
  8. Seems to me that this is a relatively rare problem, so scrapyard sourcing may be the (only) economical fix. You should be able to judge candidates for soundness at that point by visual inspection prior to removal.
  9. Is there any chance that oil is getting there from somewhere else, and actually isn't PAS fluid?
  10. The 6q1 bit of that part number suggests LHDiness, PM your VIN to me and I can probably look up the right number.
  11. I think we've been here before @J.R. but I don't think there is a bearing between crank and input shaft on the 02T.
  12. The one with the bigger hub diameter almost certainly, but you know what, phone them and ask.
  13. I suggest repair the cables shown in figure 3 before doing anything else. I think fig 1 looks normal/OK. Freedom membership enables indefinite editing, and many other enhancements. Membership Options (Freedom) - BRISKODA
  14. Adds risk (of shearing one off for example) to change ones that aren't faulty, I wouldn't.
  15. What year car is the replacement cluster from?
  16. Major differences, pre-facelift are CAN, for starters. As per PM, I haven't found a match for what you need, unfortunately. If I think hard about it I may be able to build one out of bits and pieces of others; that has the right chirality and function. The thinking hard bit of that intimidates me a bit though.
  17. Sadly that's a pre-facelift motor module you've acquired, and won't play nicely in your car. You need 6Y2959801. I may have one...
  18. Pass side wiring, annotated Driver's side, not as annotated: The only connection between the two is the LIN data wire which goes from pin 3 of each 8 way to the other, and nowhere else.
  19. Does driver's side window work OK? Part number of unit in pass door? Will add some wiring diags next time I get up and go to the big Internet.
  20. Only the vRS has the bigger M10 ones I think.
  21. What makes you think M10 x 52? I'd expect M8 x 48 Part number N91108201 (12.9 grade High Tensile)
  22. Spot on. There will be minor differences between these NBW, LHY etc boxes but all are 0AJ family boxes. If you PM me your VIN I may be able to find some part numbers of the specific bits you're after.
  23. A handy reference document for all PR codes is downloadable in 3 format options here: VAG Option Codes (vag-codes.info)
