2010 fabia tsi bcm issue
Seems almost like a connector or two is unplugged from the stalks? Has steering wheel been removed recently?
?Estate rear door window outer trim?
Want to sell me the short ones?
G28 and G40 sensor issues
Any recent work done? E.g. cambelt change.
https://www.lllparts.co.uk/catalogs/skoda/CZ/FAB/225/8/839/839060 Item 13 'Normal' ones have part numbers beginning 6y6 and ending suffix A. Combi (estate) versions have part numbers for these parts starting 6y9 and having suffix B In all cases the part with 7 before the suffix is for left side, 8 for right. Clear?
1.0 CHZB woes
Only thing to do is fill to a good level then monitor over the next few months. Anything else is guesswork.
Scala 1.0TSi (2023) for short trips?
Most petrol engines in the last 15-20 years accomplish the effect of recirculation by intake and exhaust valve timing overlap rather than external pipes and valves, so not much to cause trouble @Aldfort.
- Electric Window and door lock problem related?
1.2 TSI CBZA Oil Pump Bolt Torque
I'm seeing 14Nm + 90 degrees. Workshop manual says to use new screws.
Some images (with connector removed to see beneath it) here: Not an easy DIY fix. Secondhand prices aren't too bad currently, but be careful matching part numbers, including the one that starts SK, beneath the main 6Q1.... number. https://www.briskoda.net/forums/topic/537822-front-window-going-mental/#findComment-5996104
Tsi 1.2 Timing chain rattle worsening, or something else..?
Another thing that can apparently make a nasty noise is wear to the HPFP's cam follower. At your mileage I guess that may be a candidate.
P0101 MAF No Limp
Possibly an indirect effect of EGR malfunction. I believe @mac11irl has experienced something like this.
Airbag Control Unit Location
Does your car have a key operated switch for disabling passenger airbag? Does it have side airbags? The brown earth to pin 46 joins a splice in the loom, described as "Connection 1 (airbag), in main wiring harness". That could be anywhere. What pin number and wire colour are you measuring a permanent 12V on? I'm surprised you're finding such a thing.
Are you certain that your probe is getting in there properly, they're probably very thin pins that go into the loom socket? May need a thin stiff bit of wire to get in there, or pierce the insulation with a pin and measure to that?
- Pin assignment
Central locking problem
Microswitch or cracked joints on the lock module circuit board. Have you seen my photo and video of this?
- Pin assignment
- Pin assignment
2009 FII fuel gauge not working
If your cluster shows outside temperature somehow, see if that is working. I faintly remember that the supply within the cluster that feeds that NTC sensor is shared with the fuel gauge supply. So if something was pulling that down - like water ingress into outside temp sensor/connector - it might affect both functions.
- Pin assignment
Pin assignment
It'll vary a bit with year, and what equipment options are in the doors. Official wiring diagrams don't tend to give a pinout for these connectors I think, you just have to piece it all together from all the pages that cover all the door-located electricals. Which aren't all conveniently together.
Engine Cover/Air Box 03E129607
A fair number of 9n/9n3 Polos would have the same thing with a VW emblem instead. Probably a bunch of Seat Ibizas too, all from same era.
The Skoda emblem has its own number, 06A 103 940K, but the silvery bit it sits in doesn't seem to, even though it comes off easily. I binned mine years ago when it seemed to be rattling. Scrapyard seems the obvious choice to find a cheap replacement.
- Electrical problems
how to remove this Clip
