Neily03
Everything posted by Neily03
  1. That won't stop it getting stolen and i really wouldn't want my car back if it was stolen. Hopefully they'd wrap themselves a tree and explode.
  2. First two years are unlimited mileage, then 60k for the third year.
  3. Mine flashes red when close to the car, pretty sure it's normal as the key and car can see each other.
  4. No one put too much oil, the OP state it's a mixture of oil & diesel due to DPF regens and short journeys.
  5. I use the rear wiper fuse for the switched live and the boot 12v socket fuse for the permanent live.
  6. Mine worked fine formatted exFAT.
  7. No, don't try and pull that off, that's the screen itself.
  8. No, that’s complete nonsense .
  9. I thought this had been superseded by the MySkoda app a while back anyway. They've probably shut it down now.
  10. CEL has come on mine today, ODB11 comes up with "P02D300 Cylinder 4 Fuel Injector Offset Learning At Max Limit", so possibly a dodgy injector. Booked it in with with dealer to investigate, luckily it still drives fine.
  11. I wouldn't be having holes drilled in the roof, no matter how well done it's asking for trouble later....
  12. Have you checked in the carplay setting in your phone, that's where you select what apps you want available. There should be settings for each car.
  13. Both were FWD UK cars.
  14. That's incorrect, I had two pre-facelift vRS diesels, a 2013 with the 340mm discs and a 2016 with the 312mm discs.
  15. Got mine brand new October last year and it's been flawless. None of the issues anyone else has reported.
  16. An easier way to download it would be great
  17. That’s correct, just D when in drive. If you put the gearbox into sport then it’s will show the gear, S1, S2…. etc.
  18. I've had several cars with speedo's like that, quite common i think.
  19. 999 calls go through any network, if you don't have signal on your own network it will just go through any network that there is a signal on.
  20. Just added 0.5L to my vRS last night as it was down to 1/4 above minimum at 6k miles, seems pretty normal to me. Anything up 0.5L per 1000km is usually considered normal by most manufacturers though I'd be surprised to see anything as high as that.
  21. I think it was the same in the June ‘23 brochure too
  22. You’ll find it pretty much the same place on any car as regulations state it must be within 2 feet of the steering wheel.
  23. Minor issue and it's been like this since new but 99% of the time when I start the car spotify doesn't continue where it left off and just shows "Not Playing" in the app window. To get it to play I need to tap on that window which opens it full screen and then shows where it last was and I press play then all is fine. Anyone else have this or am I missing something? Infotainment is all up to date etc.... Cheers.
  24. Yes, though if it needs adjusting they need to wait for the engine cool so can be 2 hours. Mine was in this morning and the heat mat was fine so I was only there about 15 minutes.
  25. I thought the whole point of being keyless is the key can stay in your pocket, that's where mine stays....
