New Croatian VRS 236hp 19inches
did you not close off in the corner next to inner wing?
  • Replies 1.2k
  • Views 180.8k
  • Tom from sem motorsport decided to make some more  of his big port passenger side (LHD) intakes for me after seen my build thread. At first he rejected me,and after few days me being desperate and con
  • Pay attention to fine precission tools and protein drink
No,that's why we put some rubber there also, but is sits so close you don't need it,and otherwise ProRam Large filter wont fit. All done on 3d scan model on comp-all simullations
Edited by davojuri
love the level of geek , looks great and waiting on my delivery 😛
I am completely disfunctional😂😂😂😂
Back to Denso IK20TT from NGK BKR7EIX-11
Edited by davojuri
any reason why ?????
I recently had error code for missfire in cylinder 1,3 and 4.
Bought them immediatelly and when I was replacing them found loosened all 4 NGKs. They were ok but due to the fact I already bought new ones I replaced them. Why they were loosened I have no clue.
Edited by davojuri
makes sense if you already purchased (ps i will find the Neuspeed power steering cap hopefully this weekend) and i need to order an intake box
Great, I;ve already sent you in DM contact info long ago for air intake box 🙂
Need help
Can't fond this part
1U0 837 994 47H
front right tweeters cover on front right door.
can you fond used one
INwill send you PayPal money in advance no problem
On 12/01/2024 at 10:39, davojuri said:
Need help
1U0 837 994 47H
i will have a look , are they not available from skoda still?
i may have one but need to work through about 20 boxes first
Please ASAP
They are discontinued and can't find them anywhere and on 12. February I have scheduled music installation.
Please help me with that.
My has one clip broken so it doesn't sit flat
Finally today on my 54th birthday I installed my new custom brake discs DBA T3 5000 series discs, with custom full floating hat 6081alu, black hard anodised and AP Racing H bobbins with McLaren anti rattling clips, all together balanced to 0,1 and 0,3g by www.elmet.hr -balanced part on disc I painted with blsck thermo paint up to 800C for rust protection.
Fit is perfect in one hundred of mm in the very center of the calipers espetially when the measurements were taken from already machined old discs from 34 to 32mm but you newer know which side was more machined than other, so to find equal ET is little experience magic. We did it perfectly, but my friend didn't take on count 21mm spacer and outer thicker part for bobbins starts to raise little to soon over 45degree angle and when we used grease on the backside of spacer it was obvious that it sits only on that conus-grease Mark only there, hat completely clean-so for first aid we machined spacers to 130mm to accomodate them,and new spare hats will be 142mm before conus raise for thicker outer part.
Raining outside so I can't perform EBC reccomended brake in procedure as they suggest (has one more step than for yellow ones).
Happy as a kid
Edited by davojuri
Have you looked for that tweeter cover? Please do so ASAP. I need it
Bought new KW camber plates
19000702
time to replace good old Ground Control camber/castor plates.
Thing I don't Like is doing doing sound while turning steering wheel and noise over bumpers from ball bearings. Good thing is wide range of adjustement.
I expect German  quality and closed seal system-long lasting and due to the fact www.gepfeffert.com installs them on large scale on very expensive cars so they must be quality improvement over my old ones. More pics to come
So new 21mm spacers are done with conus on backside to accomodate existing center hat which has 130mm contact surface. They are 140mm front  with 128mm back spacers made of 6082alu.
Hubcentric 72mm without any centering rings.
Same pattern as wheel so they are extra light.
Design borrowed from 42draft design.
In plan to make new center hat (drawing already corrected) with 140mm contact surface for new flat 140mm spacers and one more spare pair of discs that should also be drilled from 6,4x9mm to 9 mm to have them aside as spare parts now when I have drawings,materials and possibillity to make them.
Edited by davojuri
It's time for some  music uograde😊😊😊.
We've spent whole two day just sound proofing the car. Front and rear Doors in 5 layers, 3 on door itself and 2 on pannels, two layers on hood and 4 layers on 5 door-2 on door,and 2 on pannels
Trunk and roof are insulated in 2 layers and floor im one layers. We've used CTK for all and some STP sponge. We fitted Hertz Mille Legend 1650.3 two way system 300w (,EISA 2915/16 award) in front doors-woofers, tweeters are to be mounted in cnc'ed alu pods on A pillar,and rear where OEM woofers were also in alu pods OEM speakers are all removed, rear woofwes will be in rear shell fixed with Musway MSR-VO2  16,5cm alu adapter rings, and JBL sub hub 800w design award 2018 in spare tyre and Helix M four DSP amplifier with all four crossowers in back of spare tyre. Phoenix gold TX series amplifier install kit. Audiotec Fischer Conductor one touch remote control EISA award best pepduct 2021/22. Complete pictures  and video follow up to come when finished. Can't wait, after all the upgrades it was time for some deep basses to come. We Will put also cable for Alpine Halo 11" unit and reverse Alpine HDCR camera, untill that upgrade Denissin BT,USB micro sdhc  reader for Symphony MP3 player,hehehe, stay Times😇💪
All done after whole 3 days of hard work. Done perfectly from aesthetic point od view and functional to. Now doing DSP fine tune up.
Detailed follow up to come in following days.
List of part that I purchased and we installed them directly in shop https://www.supersound.si/izolacija-vozila/
Thumbs up for the shop and Marko. Great guy and ethusiast who performed all the work together with me helping him and controling every step of installation-otherwise I Will get sick🤣🤣🤣
Great reccommendation firstly regarding quality and dedication and amount of love and commitment he inplements in his work and not to expensive!
Edited by davojuri
Now it performs high fidelity sound. I never tought that I will be doing some music upgrades and than went full custom total transformation. Hehehe never say never
