Superskoda hood power damper
Success at last, the second strut finally arrived from Germany this morning - mounted straight onto the ball pins with a little lithium grease and job's a goodun. Really pleased with the way that the weight of the hood is picked up once it's about 25% open, then gently comes to a stop on full extension. Just need to apply a bit of touch-up paint to the base of the ball pins. I'm inclined to bin the old support stay as soon as I'm happy that the new struts aren't leaking.
Warrior193.
Can you list what you ordered in the end. I am tempted to do this with my Octavia.
  • Replies 172
  • Views 49.7k
  • some folks on german forum as already came up with some part numbers for OEM stuff that is an alternative to superskoda hood dampers.   you can buy the ball pins from BMW: 2x M6 ball pin 41 62 8 18
  • No I went for Febi Bilstein ones. The Superskoda set came in about 50 euros including delivery and I read that they aren't quite as good. Would have taken longer to come too.   The Febi stru
  • Big shout out too @ahenners for your assistance & explaining what bits n bobs are needed to do this mod   & everyone else who has participated in this thread    Everything ahenners l
Hi GRH, I used the advice from one of the previous posters and used Seat Ibiza Mk 2 / 3 gas struts (Febi Bilstein 27709) - Ebay item 401182532250.  NB. If you check the specs for the Bilsteins, you will probably be able to source identical struts from a different manufacturer - it took me a few weeks to get a pair of the Bilsteins together from separate suppliers. - A bit of advice, don't bother using Premier Factors unless you enjoy dealing with incompetent suppliers.
The ball pins are 6mm x M10 and 8mm x M10, Ebay items 201561709396 and 401102290899 - although a slightly longer thread (at least 15mm of thread to allow for the thickness of the washer) would be better on the 8mm one. NB. first size is the thread, second size (M10) is the ball. The 8mm stud goes into the front bolt position of the hood hinge.
I got also got some 6mm and 8mm washers (the 6mm ones will need to be the "penny / repair" type to completely cover the hole in the wing mount, a standard washer is ok for the 8mm stud.
Unless you already have one, you will need a special spline (actually 3 square) adapter bit to remove the bolt from the hood hinge ( Ebay item 110640243135)
I mounted my struts with the cylinder on the forward ball pin (with the ram facing rearwards) - all the other posters have mounted theirs with the cylinder on the hood hinge and the ram facing forward. It works either way but I think the way I've done mine looks better.
Once you have all the parts together, this job doesn't take very long at all. Just surprised that more manufacturers don't fit this standard - so much better that the pony support stay.
Warrior193.
Warrior193.
Thanks. Think I have new job for my car. Cheers
  • 6 months later...
Hi guys,
found the febi bilstein in ebay,
but can't find anything else.
I really need some help for those :)
""The ball pins are 6mm x M10 and 8mm x M10, Ebay items 201561709396 and 401102290899 - although a slightly longer thread (at least 15mm of thread to allow for the thickness of the washer) would be better on the 8mm one. NB. first size is the thread, second size (M10) is the ball. The 8mm stud goes into the front bolt position of the hood hinge.
I got also got some 6mm and 8mm washers (the 6mm ones will need to be the "penny / repair" type to completely cover the hole in the wing mount, a standard washer is ok for the 8mm stud.""
9 hours ago, hitmn said:
Hi guys,
you can get these:
http://www.ebay.com.sg/itm/2x-10mm-BALL-STUD-BOLT-M8-for-gas-struts-ball-ended-bolt-bonnet-hatch-STD-002-/111293094319
http://www.ebay.com.sg/itm/2x-10mm-BALL-STUD-BOLT-M6-for-gas-strut-struts-ball-ended-bolt-bonnet-STD-001-/111293093987
Installed, but with some modifications with my pocket knife. I forgot to take a shot, but the bilstein shape is a little bit different. I highlithed it at the pic below. This one (on the pic) is "concave", bilstein it is not, so I made it with my knife :)
All is functioning now :)
Hi Hitmn, it looks as if the 'stand-off' (or lack of ) was your problem with the top mounting ball-pin. The pins I got had a thicker hexagon section to them - but it took a lot of searching on the web to get them. The longer hex also gives a little more contact surface for tightening them. Other than that, are you happy with the struts?
yes. in my opinion 350N is perfect force!
  • 7 months later...
Apologies for the thread resurrection, looking to get the Febi struts as used by the last few posters but a bit confused about the ball studs based on the comments.
Can anyone who used the Febi struts confirm the best ball stud thread lengths etc to ensure there is sufficient gap between the strut and the bonnet edge? Thanks
Edited by ahenners
I’ve just read it and confused as hell too.
When specifying Gas Struts you need the closed centre dimension, force, any end damping (usually only one end) and the stroke as well as the end ball dimensions.
Not seen the closed centre dimension mentioned anywhere, I know the Stabilus rep so will get some foc when I find out all the above.
There is oil in the cylinder and the Cylinder should be mounted to the Hood//Bonnet to keep the seals lubed when closed.
It seems to be that the Febi 27709 have the right length and force and I will be going for those.
Was looking at this M8 10mm ball joint https://www.sgs-engineering.com/x3-ball-extension Will the thread length of 12mm be enough for clearance with the washer? 220 I noticed you mentioned the 25mm length ones, did you use those in the end?  @hitmn @Warrior193 @220
Yes I used the 25mm's in the end no issues with fitment.
Thanks for the quick reply to my quoting of such an old post! 25mm only required on the M8 end then? 12mm length fine on the M6? Everything all good with this installation still since you fitted mid last year?
No problem. Just checked and the ones I ordered were 10mm so you should be okay with 12mm. No issues at all great mod.
Great, thanks again :)
Another thing dont worry about the foam the weight of the bonnet will make a nice area for the struts to go foam seems to mould quite well.
Thanks everyone who posted with advice on the struts, bolts etc. Fitted mine today and works perfectly, so much better! :)
Very nice :) Are you leaving prop on? I would have to remove it, it would bug my OCD far too much!
Thanks! No I'm going to remove it, but its bloody freezing outside today so I'll leave that for another time :D
That’s better, I’ve stopped shaking now :) Really mild where I am today, makes a change!
@ahenners did you buy them from SuperSkoda? or from somewhere else!
I've been in two minds if to do this but the more I see them, the more I just want to do it! Also can I ask what you needed to buy apart from the dampers in-order to fit them, B) Thanks
Thanks @ahenners that is spot on information :thumbup: just ordered all the parts/bits & dampers so will hopefully get them fitted within the next 2 weeks B)
4 hours ago, ahenners said:
Painted the washers and ball joint bolts with a touch up kit I already had to make them blend in and look more OEM.
Well done. :thumbup:
