0806 mini dashcam Group buy ALL SPACES NOW FILLED
OK, the camera & extras arrived today, a job for the weekend installing the hardwiring. Am I right in thinking that the camera can be powered through the GPS mounting, as well as via it's own micro usb port?
  • Replies 270
  • Views 37k
  • Collected mine from local sorting office today as I was out yesterday. Had quick look. Everything is delivered. Camera,hard wire kit and filter. Like others hopefully the weekend job, if time allows.
  • Quick update to anyone that's put there order in and is waiting for there 0806 dash cam which includes myself Just emailed carcamera shop they are hoping to get delivery of some more of these around
In laws missed the postie today, so needs picking up.
Can't wait to see SWMBOs F1 drives to work each morning
I was wondering the same - the instructions don't appear to say.
1. Gadgetman - code sent
2. Johnny 5ive - code sent
3. Andyvee - code sent
4. Leouk - code sent
5. wharferat - code sent
6. hockeylad72 - code sent
7. decuk - code sent
8. Ally_bassman - code sent
9. FlyHigh - code sent
10. Splooter - code sent
11. XCR41G - code sent
Yes it can.
Sent from my Nexus 4 using Tapatalk
Yep, power the mount, otherwise the GPS doesn't work :)
Mine arrived today as well, had a good play around with it, pretty impressed.
Only issue is if I choose the 1080p HDR setting it locks up every time it tries to save the file. I think I saw this mentioned as a bug, but I'm probably going to use the 1080p 45fps setting anyway. The polarising filter seems to make a difference as well.
In my excitement, I couldn't find any instructions, cursed, then printed in book format, cut and stapled. Then I moved the delivery box off the table. they were underneath..... Oops.
Anyone else going to get one of those fuse connections and wire direct to the fuse box?
Also wondering which size in line fuse to fit.
Yep, ordered one earlier (and also ordered 2 x 64Gb cards yesterday  :sweat: ).
The other threads on here regarding hard-wiring a dashcam suggest that a 5A fuse is appropriate.
Do you think Halfords would have something?
Hoping to get it fitted tomorrow
I'm using a 2A fuse with my current dashcam so will stick with that
1.5 or 3 was my initial thoughts, so 2 sounds like a plan.
Where'd you get your neg feed?
I there still an option to buy one? If so please could I have a code?
This is a switched live
John
I have installed mine this afternoon. Quite easy. Used a piggy back fuse holder off eBay. Took to fuse 47 as shown somewhere else on here. Earth wire to a bolt at the side where you remove the side trim. The hardwire box is sticky backed to lower left of fuse board.
Wish the instruction manual was bigger, I've put it down and can't find it.....
Got a piggy back fuse holder from Wilko Autosave. Have fitted the kit, & tested the camera, so far so good. However, trying to remove the camera from the mount is a different story. It is very tight & I have concerns that I will either damage the camera, or rip the mounting off the sticky pad/screen. If anyone has tips on how to get the camera off the mounting, without damaging anything, I would be grateful if they could share it with all of us.
Took me a few, leave it, have a go leave it attempts. Hard to say, I placed fingers against out let side then wiggled gently ( cam not me), by gripping at the base. I was going to put silicone furniture polish on before replacing, but forgot.
Tip on removing the SD cards, press in with 1 finger nail, but use other hand to put a finger over the side of card. They eject like a missile, then take some finding.
Haven't we got any footage available yet?
Can't think of anything more boring than watching me drive round town....... So no.
Interesting about, which way round to fit the piggy back holder. Better check mine, as it also occurred to me that I could be taking power straight to the wire and not going through the fuse. Or am I wrong.
Add me to the list please
Well after telling swmbo I'd be fitting it today, she's gone out in the car for the day. Apparently it's been planned all week.
So it'll be fitted next weekend now :x
Add me to list please.
