0806 mini dashcam Group buy ALL SPACES NOW FILLED
Can you add me to the list please.
  • Replies 270
  • Views 37k
  • Collected mine from local sorting office today as I was out yesterday. Had quick look. Everything is delivered. Camera,hard wire kit and filter. Like others hopefully the weekend job, if time allows.
  • Quick update to anyone that's put there order in and is waiting for there 0806 dash cam which includes myself Just emailed carcamera shop they are hoping to get delivery of some more of these around
Been out on North Yorkshire Moors to Blakey Ridge for lunch. First time really used the mini 0806. Excellent video. Went with green landscape, left with an extremely white landscape 1 HR later. Unfortunately the sound was on, so afraid I can't send it to anyone as my missus was constantly wittering at the conditions. I was driving of course, or we would never have got home. Highly recommend.
Stupid question, Should the red light be steady or flash when recording. Sure it didn't flash yesterday, but does today. I did play with the setting last night in the house.
Mini 0806 has two memory slots which will give the camera a maximum of 256GB of recording approx.
Are the memory card slots for a SD card only or, MICRO card only, or the combination of both an SD adapter and MICRO card.
Thanks guys & gals..
Many thanks  'decuk' (below member)
Both micro SD slots.
Hi all
To the ones that have received there dash cams so far
And fitted them are you happy with them,
Let's get some opinions whether happy with it or not or it could have been better
In certain areas
It all helps with future purchases
Hi all
In certain areas
......and, dare I say it, some example footage??
Any updates on the list gadgetman? :D
I'll be on it later ;)
Isn't it possible to upload it without sound?
Maybe I'm just used to seeing FUBAR with his Steven Spielberg productions and expecting too much? :giggle:
1. Gadgetman - code sent
2. Johnny 5ive - code sent
3. Andyvee - code sent
4. Leouk - code sent
5. wharferat - code sent
6. hockeylad72 - code sent
7. decuk - code sent
8. Ally_bassman - code sent
9. FlyHigh - code sent
10. Splooter - code sent
11. XCR41G - code sent
12. jjc - code sent
13. The hub - code sent
14. Daz1972 - code sent
15. Dempster - code sent
16.
17.
18.
19.
20.
All ordered :D
Hi - can I be added to the list as well? I cant seem to order this dashcam anywhere just now so may as well wait...
edit: I signed up for briskoda years back but only just realized I've never posted!
Edited by Cheechy
Ordered mine
That has to be some sort of record. 1 post in almost 11 years of membership :giggle:
Hi can you add me to the list please :-)
12. jjc - code sent
16. Cheechy - code sent
17. Dozer123456 - code sent
18.
19.
20.
Ordered this morning, does anyone who has already fitted theirs have any pictures, any points to avoid. Would love not to make any mistakes when fitting.
Thanks gadgetman for setting this up :clap:
John
Ordered :)
Hi gadgetman, could I be added on to the list as well, thanks.
One thing I would suggest, rather than ordering micro sd memory cards with the camera, check out Amazon or Dabs.com & order from one of them, or any other outlet you may prefer. For the cost of buying a 32gb card with the camera, from other sources, that money will get you a 64Gb card, with change.
Earlier mention about which way round to fit the piggy back fuse holder. Checked mine today, (removing the glove box is a doddle once you know).It's just that stupid easy to fall out damper that can be a pain.
I removed the cam fuse and it went off. Turned the piggy round and repeated, it went off. So it seems with the one I bought, it doesn't matter which way round. Took the opportunity to swap the fuse for a 5 amp instead of the 10 that came with it.
Mine is ordered and will get the memory cards elsewhere for example 7Dayshop other outlets exist..
I'm not sure that your test proved anything - as I understand it removing the cam fuse will break the camera circuit whether it is the right way round or not. The test you should do is see if the camera still gets power when you remove the donor fuse - if it doesn't then it is the wrong way round.
Ah. Complicated stuff electrics. i'm only a fitter :happy:  Another job another day.....
