VCDS options on Superb III
3 hours ago, langers2k said:
These are the different profiles, each number matches to a specific profile and has no relation to the ordering or availability on the headunit.
0 is always doors open
1 is always comfort
2 is always normal
3 is always sport
4 is always off-road
5 is always eco
6 is always race (cupra thing?)
7 is always individual
8+ I'm not sure about
Errr... I think, we say the same thing, but not the same way... 😄;)
The value of each adaption channel specifies the colour it should use. This is taken from the RGB colour list so the colour shown will depend on how those channels are configured. For my car when I made those notes:
1 is white
2 is orange
3 is red etc etc
This will match the ordering of the colour wheel shown in your headunit in 'manual' colour select mode.
I think all 16 channels need to be none zero which is why I set all unused profiles to 1.
Regarding the colours I'd like to link to some driving modes, since I'd like to keep the colour setting free for comfort & normal modes, I had assumed they could remain set to 0.
Am I wrong?
  • Replies 2.5k
  • Views 825.2k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
All driving modes will need a colour selected. As mention before, all 16 "Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil" channels need a none zero value.
One driving mode can be customised and will use the colour selected in 'manual'. This is done by setting the "Ambiente_Fahrprofil_Individual" channel to that driving mode. In my example, it's set to 7 so "individual" can have the colour changed.
This customised colour was the feature I had issue with until the CAN-gateway firmware was updated...
If you end up with a disco mode (colour changed twice a second) on the headunit, set "Ambiente_Fahrprofil_Individual" to an unused profile like 6 or 9. You'll loose the ability to set it via manual mode I'm afraid though 😞
OK thanks. I'll take a look at it and try these next days. ;)
Edited by Bap33
I have superb, 2022.can the wifi be unlocked?
Hi people. I'm wondering, is there a way to change the locking/unlocking lights for Superb facelift with dynamic lights, like in VW Artheon?
https://www.youtube.com/watch?v=k-N8thzPKkM - Check it at 0:06
ENG141649-ENG122204-External light_Blinker-ZV_Blinken_auf
ENG141649-ENG122203-Outside light_Blinker-ZV_Blinken_zu
setting these to active makes the facelift tail light lock and unlock dynamic.
But you also have to have installed the FL taillights. 😂
Thanks! I will give it a try!
@Lutz_91 I own FL model, but thanks for anyway 🤭😁
Two more things I need help with:
1. Is there a way to postpone Auto Off? My car sometime just turn off before I stopped it completely. I would love to change this if possible.. (I think my previous car was shutting off after I press harder on the brake)
2. Is it possible to change time when lane assist warning will pop up? Like now when LA is active and I'm not holding the steering wheel, I got this after 10sec. I prefer to increase this a bit, and not because I want to seat back, just is annoying when I'm driving straight, and there is no resistance on the steering wheel..
Vor 24 Minuten sagte Patt85:
Ich werde es versuchen!
Then it should work, just try it with the two points.
I've already tested mine, and you can influence it with it.
I'm just surprised that the original is not set.
1. No
2. No
Unfortunately.....
Although with #2, it can b done with VCP/ODIS by using a modified parameter file.  It increases the time to up to 30 secs or so.
Edited by JR RS
Better than nothing. I will investigate further. Thanks for the info!
On 27.12.2022 at 20:44, Patt85 said:
Спасибо! Я дам ему попробовать!
@Lutz_91 У меня есть модель FL, но все равно спасибо 🤭 😁
Еще две вещи, с которыми мне нужна помощь:
1. Есть ли способ отложить автоотключение? Моя машина иногда просто выключается, прежде чем я полностью ее остановлю. Я бы хотел изменить это, если это возможно.. (Я думаю, что моя предыдущая машина выключалась после того, как я сильнее нажимал на тормоз)
2. Можно ли изменить время появления всплывающего предупреждения Lane Assist? Типа сейчас, когда LA активен и я не держу руль, я получил это через 10 сек. Я предпочитаю немного увеличить это, и не потому, что я хочу откинуться назад, просто это раздражает, когда я еду прямо, и нет сопротивления на руле.
2. I did 60+ sec. Everything is done through odis and uploading a new parameter. A lot depends on the camera.
https://vwcoding.ru/MQB/camAssistFirmwares/
Engine shuts off under 5 km/h, but I fear this can't be tuned (at least not with VCDS).
Not very safe when arriving gently at round about and intending to insert in the traffic without fully stopping. It happened to me 3-4 times with my wife's Audi Q3 with mechanical gear box. It's really stressful 'cause engine can even stall and you're stuck in the middle of the round about, traffic rushing towards you. It lasts waaaaaaaay too long before you understand what happens (at least for the 1st time) and know how to get out of this tricky situation (just press couch pedal and restart with key). Only happened once with my DSG6 Mk3. Engine restarted on its own (hopefully).
@GizmoHi have a Superb SE L TDI DSG on a 72 reg wondered if you can code in lane assist and sign recognition as well as close boot from centre console. Also if you can let me know if there is anything else you think it’s worth coding in. I’m only in margate so can easily get to you.
Hi, I haven't plugged into one this new, but I assume they are now all protected by SFD? If so then it's not something I can do until VCDS can obtain an SFD token.
Superb has no SFD
Pe 21.05.2021 la 23:44, Hdsn555 a spus:
Știu că modul pentru paleta de 30 de culori din ecranul de iluminare ambientală a fost menționat de mai multe ori pe forum.
TLDR: Valorile RGB sunt disponibile în tabelul din partea de jos a postării mele.
Au existat câteva îndrumări aproximative cu privire la valorile RGB, dar am vrut să urmăresc un aspect OEM+.
Mi-am luat ceva timp pentru a construi un palet de culori de 30 de culori pe baza celor 10 originale care vin ca standard.
În loc să încerce să unesc punctele uitându-mă la valorile RGB brute, am construit un gradient pentru cele 10 valori RGB din originale. Apoi am făcut referire la 30 de culori din gradient și am notat valorile.
Mai jos sunt valorile inițiale ale ecranului, gradientul și cele 30 de culori alese.
Banda de iluminare ambientală folosește valori diferite de față de valorile ecranului, interesant totuși, valoarea de alb din banda de lumină ambientală este de fapt verde deschis, dar apare albă pe bandă.
Paletul original înainte de codificare:
Paleta de 30 de culori după codare.
Mulțumiri masive pentru@Ivan8192 pentru că ai ajutat cu scriptul și i-ai permis accesul la VCDS-ul său din nou! :) și a@SashaGracepentru că mi-a stârnit interesul pentru acest mod.
Pentru oricine este interesat valorile RGB sunt disponibile mai jos:
Ecran
Ambient Strip
Culoare de bază
roșu
Verde
Albastru
Culoare de bază
roșu
Verde
Albastru
alb
217
221
233
alb
120
231
71
229
205
161
163
221
49
241
190
88
205
211
26
Galben
253
174
16
Galben
247
202
4
254
155
18
234
167
2
254
135
34
208
128
3
Portocale
253
115
50
Portocale
183
89
5
251
85
52
189
60
5
247
51
47
215
40
4
roșu
244
18
43
roșu
241
20
3
244
19
73
255
27
17
247
59
142
255
65
49
Liliac
251
100
212
Liliac
255
105
82
232
109
243
244
134
112
197
98
247
196
136
136
Magenta
163
86
251
Magenta
149
138
160
129
77
255
104
139
183
87
85
255
70
130
207
Albastru
45
93
255
Albastru
37
121
229
5
101
255
4
111
251
0
127
255
8
142
226
Cyan
1
156
255
Cyan
17
179
194
1
184
255
26
215
162
1
194
214
35
229
120
Verde
0
197
157
Verde
45
236
73
0
200
99
54
242
27
30
210
70
58
228
3
Lămâie
88
227
65
Lămâie
58
196
2
145
244
60
57
163
1
182
255
57
57
132
0
Good evening ! My car only has 3 basic colors, could I switch to the
 30 colors based on the table?
Or do I need to make other settings?
Can anyone help and be more specific how do I lower the sensitivity of auto headlights in VCDS?
They turn on much early in the day.thanks
@MartiniB may help you. If I remember well, he did this mod. ;)
there is a setting "Light Sensor sensitivity" in the infotainment, under Light Settings, to select Early, Medium or Late for the auto headlights.
have u tried that?
You are right was on medium,I feel silly
