Error service: leave vehicle only when selector in position p
Sorry if not the right place, but didn’t want to lose thread topic. My eldest daughters 2016 Skoda Fabia has started displaying this message now. Were those models given a recall notice for this fault or will she have to pay out a small fortune for the fix?
Does it stop the car driving at all, or is it just one of those annoying fault messages?
  • Replies 525
  • Views 321.7k
  • Here is how i changed my switch on Skoda Superb 3 2016.
  • Problem solved only £40, I bought the switch from a friend "mechanic" and it tog me a half hour to mount on top of the DSG gear shift very easy so the only thing you need is 5Q0-713-128-A, some tools
  • As you were "diving" I'm not surprised there was an error
Not sure about the Fabia, but if the same as the Octavia it is a Microswitch on the gearbox. On the Octavia they can be piggybacked to the existing switch and the connections moved over I believe so shouldn't be an expensive job, but I guest depends on the garage.
@cervaro67Welcome to the forum.    http://skoda-auto.com/services/recall-actions
No Recall, nor Recall Action or Service Campaign but there is a TPI and the fix need not cost a fortune.
Mk3 Fabia Section has the threads.
Like this one.
It is a DQ200 DSG.
http://briskoda.net/forums/topic/505730-weird-message-only-leave-vehicle-in-postion-p
See post page 2 9th August 2022 by @varooom
http://briskoda.net/forums/topic/501580-error-workshop-only-leave-in-position-p
Edited by toot
  • 4 weeks later...
I had this error fixed while in warranty and now when the car is 8 years old, the error appeared again (3 times this month).
Aside from the weird warning, what can happen if this is ignored?
Yes, unfortunately Skoda is a very poor built car. I have sold it after 6 months and bought something decent. I suggest you do the same! Waste of a good engine in a crappy made car! Sorry if i upset the purists but this is what i felt after only 6 months of ownership and 12000miles.
Sounds like you've been unlucky - from 2006 until 2016 I had an Audi RS4 Avant (4.2 V8) but retirement meant I needed something more sensible and since then I've had a couple of Mk3 Octavias (a 1.4TSI Elegance estate and a 1.8TSI L&K hatch) and had fewer build quality issues than I had with the RS4.
Personal preference! I had the top spec Laurin Clement 2l. Awful noisy car, even on the motorway I couldn’t hear the radio inside! Wouldn’t rate it more than 2 out 10. Sorry, I’m sure there are lots that will disagree but this was my experience. Not to mention, to replace a DLR, you need a new headlight and bumper out. That was the top for me and I decided to get rid of!
On 15/05/2020 at 18:42, Atenza said:
Problem solved only £40, I bought the switch from a friend "mechanic" and it tog me a half hour to mount on top of the DSG gear shift very easy so the only thing you need is 5Q0-713-128-A, some tools and how to put it in.
Any video on this?  Pdf instructions seem very complicated to me.
Was that a 2.0L TDI, as the TSI is 1.8L?
Found this video, maybe it helps:
  • 3 months later...
I just went to remove trim to check what type of microswitch would I need, and then I saw this:
https://imgur.com/a/0o3MZKI
I have a multi-lock on a gearbox installed from when the car was new and I guess this black part blocking everything is part of the multi-lock. Which means I probably wont be able to replace microswitch. Not a good news 😞
What is a Multilock?  When I asked Skoda to look at my wife's car they said they would only know if they could replace the microswitch when they opened it up. They did so and told me unfortunately mine was one that could not be repaired.  Assuming it is the same as yours then?
Its like anti theft device which uses a lock to lock a geabox in P position with a key (which is inserted on the right of gearbox).
However, I had this lock installed when the car was new, and my dealer actually did already a fix on this gearbox (for the same message issue "leave vechicle only..") some years later.
So they did already fixed this when this lock was present.
But I dont know what they have actually done (havent asked at the time).
I dont think they replaced microswitch (maybe they did) but not sure what was offical Skoda fix for that. I remember reading somewhere it was new gear selector or something...
  • 3 months later...
Hi all, I had this issue and have just installed the microswitch. It is operating normally (i.e. it detects when gear is in P and let me take the key out or not if it isn't) so I assume it working as expected. But I can still see the warning message appearing.
Do I need to do anything to reset the warning sign?
  • 4 months later...
Evening all.
So I purchased the piggy back part 5Q0-713-128-A and I have tried twice today to fit it but either I am doing something wrong or the piggy back part has a fault.
Having removed the trim I disconnected the connecter with a green switch that connects into the front of the selector housing, I inserted this into the piggy back part and then connected the duplicate piggy back connector to the car.
I then removed the horizontal screw from the selector housing, placed the switch on top and then replaced the screw, a very fiddly job.  I then added the four retaining clips.  Turning the key I am still getting the bong and the warning plus I am now getting an additional warning 'Error: gearbox' and the gear selector is stuck in P.  On both occasions I had to remove the piggy back unit and return it to standard which then removed the 'Error: gearbox' warning and allowed me to move the selector.
I have since used a regular BDC2 scanner and then a VCDS but the warning isn't showing on either scans! I can still see it in the dashboard and the infotainment.
Has anyone experienced this? Is there a way to rest the dashboard?
I didn't want to take it to an official Skoda but would you suggest I do now?
This is VCDS scan from yesterday.
Tuesday,03,September,2024,16:44:24:23195
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3 www.Ross-Tech.com
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction
0010 10-Park/Steer Assist -- Status: OK
0000 15-Airbags -- Status: OK
0000 16-Steering wheel -- Status: OK
0000 17-Instruments -- Status: OK
0000 19-CAN Gateway -- Status: OK
0000 42-Door Elect, Driver -- Status: OK
0000 44-Steering Assist -- Status: OK
0000 52-Door Elect, Pass. -- Status: OK
0000 5F-Information Electr. -- Status: OK 0000
That's not the scan, that's just the installation list - a mistake that a lot of people make!
Sorry, copy/paste issue. This is the whole report I was given. Nonetheless I have seen in the forum that the "leave vehicle only when selector in position p" throws up an error on 16-Steering wheel an in this summary status it doesn't show anything. So is that normal i.e. dashboard showing a warning but nothing on VCDS?
The 09-Cent. Elect. is throwing one malfunction but its I think related to 204546 - Remote key 2 B147A 18 [00001001] - Current Too Low Confirmed
Tuesday,03,September,2024,16:44:24:23195 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4 Data version: 20240715 DS356.3 www.Ross-Tech.com VIN: xxxxxxxx License Plate: xxxx Mileage: 68441km-42527mi Repair Order: 1 -------------------------------------------------------------------------------- --------------------------------------------------------------------------------
Chassis Type: NE-SK37 (3Q0) Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F VIN: xxxxxxxx Mileage: 68441km-42527miles
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Address 01: Engine (J623-CZDA) Labels:. 04E-907-309-V1.clb Part No SW: 04E 906 027 HD HW: 04E 907 309 BH Component: R4 1.4l TFS H26 3742 Revision: R7H26--- CVN: 65239CB2 Coding: 01250032232419080000 Shop #: WSC 73430 031 00000 ASAM Dataset: EV_ECM14TFS01104E906027HD 001007 ROD: EV_ECM14TFS01104E906027HD.rod VCID: 6D863FA2FD1457D2845-8038 VINID: 91D49B4C779501A0010C608514DCBFC388 Center armrest control head 1: No fault code found. Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb Part No SW: 0CW 300 041 B HW: 0AM 927 769 E Component: GSG DQ200G2_M H05 1006 Revision: 00005026 Serial number: CU501707168143 CVN: 1265A98F Coding: 0014 Shop #: WSC 73430 031 00000 ASAM Dataset: EV_TCMDQ200021 001001 ROD: EV_TCMDQ200021.rod VCID: 3430EAC6DEBEC61A8BB-8060 No fault code found.
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF Component: ESC H62 0400 Revision: 00000000 Serial number: 62057000000829 Coding: 25078A91242321724079060540C824A451248402600224722021F070C002430000000012121212B8586C384E4484EE Shop #: WSC 73430 031 00000 ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010 ROD: EV_Brake1UDSContiMK100ESP_036_SK37.rod VCID: 00587616DA86AABA5F3-8054 No fault code found.
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb Part No SW: 5E0 907 044 AP HW: 5E0 907 044 AP Component: Climatronic H04 2001 Revision: 00001K00 Coding: 0211000400011001100500080010102A Shop #: WSC 73430 031 00000 ASAM Dataset: EV_ACClimaBHBVW37X 006146 ROD: EV_ACClimaBHBVW37X_006_VW37.rod VCID: 73B229DA9B308122521-8026 Fresh air blower control module (front): A/C pressure/coolant temperature sensor: Air quality sensor: No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 086 BK HW: 5Q0 937 086 BF Component: BCM PQ37BOSCH 034 0242 Revision: -------- Serial number: 865824061700EW Dataset Number: V03935263AU 0001 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_BodyContrModul1UDSBosc 018001 ROD: EV_BCMBOSCH_018.rod VCID: 04507A06CE9EB69A7BB-8050 Wiper motor control module: Subsystem 1 - Part No SW: 5E2 955 119 A HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB Component: WWS371 170411 051 0915 Serial number: 887253F0401710102144 Coding: 164DDD Anti-theft alarm system sensor: Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171 Component: Sensor, DWA 005 0316 Serial number: 000000000ZY170730JXQ Alarm horn: Subsystem 3 - Part No SW: 5QD 951 605 HW: 5QD 951 605 Component: Sirene, DWA 005 0314 Serial number: 00002856223971864255 Humidity sensor: interior: Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559 Component: G355_FeuchteS H07 0002 Serial number: 71921930 3 Faults Found: 204546 - Remote key 2 B147A 18 [00001001] - Current Too Low Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 0 Mileage: 63356 km Date: 2024.04.17 Time: 12:55:17 Terminal 15 status: OFF Terminal 50 status: OFF CAN-Bus_aktiv: OFF Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: Not operated Position lamps: Not operated Automatic high beam assist: Not operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: gültiges Funktelegramm Voltage: 12.6 V Outside temperature: -50.0 °C 262936 - Sensor for anti-theft alarm system B1330 29 [00001000] - Signal Implausible Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 2 Reset counter: 231 Mileage: 67849 km Date: 2024.08.17 Time: 13:14:07 Terminal 15 status: OFF Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: operated Position lamps: Not operated Automatic high beam assist: Not operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: no cause for fault protection Voltage: 12.5 V Outside temperature: 22.5 °C 197904 - Central Locking B140A 4B [00001000] - Over Temperature Intermittent - Confirmed - Tested Since Memory Clear
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb Part No SW: 5QA 919 283 B HW: 5QA 919 283 Component: PDC 4 KanalH07 0044 Serial number: 000308419617207 Dataset Number: V03935256AE 0001 Coding: 0601050011 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_EPHVA14AU3700000 009033 ROD: EV_EPHVA14AU3700000_009_SK37.rod VCID: 49CEAB32A93CABF2C8D-801C No fault code found.
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH Component: Airbag VW21 006 0703 Revision: -------- Serial number: 003W4PF0PFUK Dataset Number: V03935266KC 0001 Coding: 98CCC000000000005C5400CC008800000065 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_AirbaVW21TS6VW48X 001014 ROD: EV_AirbaVW21TS6VW48X_VW37.rod VCID: 05566702C5A48F926C5-8050 Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 454 001 707 17 Component: SideSensor_Df 008 0887 Serial number: 357000000009452DC72Q Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 2 - Part No SW: ----------- HW: 454 002 007 17 Component: SideSensor_Pf 008 0887 Serial number: 3580000000087410F72H Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 454 802 107 17 Component: SideSensor_Dr 301 0148 Serial number: 35100EC4611100000005 Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 454 801 907 17 Component: SideSensor_Pr 301 0148 Serial number: 3520040D73C100000007 Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 5 - Part No SW: ----------- HW: 454 801 906 17 Component: FrontSensor_D 304 0149 Serial number: 355006FD62510000000I Coding: 2D2D2D No fault code found.
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb Part No SW: 5Q0 953 521 M HW: 5Q0 953 569 A Component: Lenks.Modul 075 0195 Revision: FF033033 Serial number: 20160203400329 Coding: 1400 Shop #: WSC 73430 031 00063 ASAM Dataset: EV_SMLSVALEOMQB 001015 ROD: EV_SMLSVALEOMQB.rod VCID: 3C20C2E6F6EE0E5A43B-8068 No fault code found.
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 5E0 920 980 E HW: 5E0 920 980 E Component: KOMBI 203 1440 Coding: 27A40A082180860001082B001001000000000000 Shop #: WSC 73430 031 00063 ASAM Dataset: EV_DashBoardJCIMQBAB 009008 ROD: EV_DashBoardJCIMQBAB_009_SK37.rod VCID: 2B02F1BA038099E2DA1-807E No fault code found.
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 F HW: 3Q0 907 530 B Component: GW MQB Mid 432 4303 Revision: -------- Serial number: 0006608918 Dataset Number: V03935258RY 0001 Coding: 030100047F085700EB0002481C0F00010001070000000000000000000000 Shop #: WSC 73430 790 00000 GVL: 01543C0000000000400C00000000C80000000000000000000000000000000000 ASAM Dataset: EV_GatewNF 013023 ROD: EV_GatewNF_VW37.rod VCID: 323CECDE24AAC82A997-8066 Generator: Multifunction steering wheel control module: Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A Component: E221__MFL-PR6 H02 0160 Serial number: 000000000A1962050717 Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J Component: J367-BDMConti H03 1050 Serial number: 75886000001707220BA1 No fault code found.
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B Component: TSG FS 011 0032 Serial number: 0000269271122 Dataset Number: V03935252QV 0001 Coding: 001000208001040000001100 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 ROD: EV_DCUDriveSideEWMAXKLO.rod VCID: 45D6A70285244F922C5-8010 Rear Driver Side Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labels: 5QX-959-81X-V1.CLB Component: FOND_FHSG_DRV 005 0007 Serial number: 00000000000015655708 Coding: 1D0200 No fault code found.
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R Component: EPS_MQB_ZFLS 129 1072 Dataset Number: V03935242GR 0001 Coding: 8107 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_SteerAssisMQB 013144 ROD: EV_SteerAssisMQB_013.rod VCID: 45D6A70285244F922C5-8010 No fault code found.
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B Component: TSG BFS 011 0032 Serial number: 0000270041203 Dataset Number: V03935252QY 0001 Coding: 001000208001040000001100 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001 ROD: EV_DCUPasseSideEWMAXKLO.rod VCID: 44D0BA068E1E769A3BB-8010 Rear Passenger Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labels: 5QX-959-81X-V1.CLB Component: FOND_FHSG_PSG 005 0007 Serial number: 00000000000015627209 Coding: 050200 No fault code found.
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb Part No SW: 5Q0 035 842 C HW: 5Q0 035 842 C Component: MU-S-D-ER H41 0456 Serial number: SKZAZ2T5307632 Dataset Number: V03935267DK 0001 Coding: 03730200FF00000051111201008800002F0208C60120050003 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_MUStd4CTSAT 001022 ROD: EV_MUStd4CTSAT_VW26.rod VCID: 2F3AE5AA3798E5C2F69-807A Display and control head 1 for information electronics: Subsystem 1 - Part No SW: 5E0 919 605 N HW: 5E0 919 605 N Component: ABT_Std-2 H50 8130 Serial number: SKZ6ZHT1931438 No fault code found. End----------(Elapsed Time: 01:25, VBatt start/end: 12.3V/12.3V)----------- -------------------------------------------------------------------------------- --------------------------------------------------------------------------------
Address 09: DTCs cleared
Mientras no falle más se quedará en espera de reparar
  • 4 months later...
So I finally got around to buying a replacement switch. I have a 2015 1.4 Tsi DSG Octavia. I have trawled through all of this thread, many other threads here and elsewhere, googled and searched youtube...... Is there a video anywhere that shows how to remove the trim to get access to fit it specifically for an Octavia 3? I've found golfs, seats, superbs, VW recall instructions etc, but cannot find anything that resembles my Octavia 3 trim - any links would be most appreciated!
  • 5 months later...
On 14/03/2017 at 18:00, MoggyTech said:
Gear selector mechanism faulty (Intermittent) It's actually a switch in the unit, but they replace the assembly.
should it be exchanged or can it be fixed with just a wd40 spray ?
1 hour ago, toni8b said:
MANY thanks!
Thanks from me too.
One question. After fitting the piggyback switch do you continue to get the warning triangle and message? I'm pretty sure I've done the fitting right. Does it need to be cleared (using ODB11) or will it self-clear after driving a few times?
