Amundsen MIB2 Firmware Update
Hi @pab567
Any chance you could have a look if my system is up to date?
Thanks for your help
  • Replies 4.7k
  • Views 936k
14 hours ago, pab567 said:
mib3
All check your PMs
pab567 thx for your answer. Please, could you tell me, is it my sofware lateset. Is it firmware latest or should I do same updates ? If I should update where to download it ?
Thenk you very much !
All check your PMs
4 minutes ago, pab567 said:
All check your PMs
Thank youu!
25 minutes ago, pab567 said:
All check your PMs
Thank youu for everything.
2 hours ago, pab567 said:
All check your PMs
Thanks for all your help 👍
13 hours ago, pab567 said:
All check your PMs
Thank you!!
Is there an update for this firmware, my stereo keeps playing up and I was hoping an update might fix it for me?
Thanks in advance for any help given.
I am looking for an update to the skoda superb:
5Q0035840C
You can help ?
On 05/05/2022 at 07:46, pab567 said:
All check your PMs
Now the tape is as seen in the picture, what should I do?
Either you have incorrectly prepared SD card with swoftware or ypour unit is broken. Try another SD card.
I think the software is not compatible.I'm attaching my device picture again, can you check?
Guys, i probably messed something up during upgrade.
Now i have a message: COMPONENT PROTECTION ACTIVE, after the firmware upgrade. No nav, no phone, no volume for radio.
Any way to solve it?!
Hi @pab567
Could you check if there are any updates available for my device?
Thanks a lot…. 💪
So it looks your unit had a SW patch for both CP and activations. Such units should NOT be upgraded. Now the unit must be patched again...
It is compatible otherwise the update process would not start at all. As I wrote you in PM - either problem with SD card or unit itself (EMMC).
@Madsus you have download link on PM
Could you check if there are any updates available for my device (seat leon my2017)?
Thanks so much for your help on this  thread 😇
Edited by VrsMad
Typo
I ran the patch launcher.
But from inside GEM the patch is not working... It cannot execute and cannot find the folders/files.
Still trying to trouble shoot, i have component protection active and no more RADIO NAV PHONE...
@VrsMad check your PM
Hello @pab567, I'm after a firmware update for my system. I read you're the man?
@SpinyTider check your PM
Edited by GrayedoutUK
Is there an update available for my Superb 2015 please?
Can someone help me update my new Skoda? It looks like the firmware is out of date and I'm also missing WLAN/Hotspot settings + Skoda Connect on my RS but has the slot for the sim (which I plan on using).
Skoda Octavia RS MY 18 135TDi
I tried the Skoda site to even just update the maps as I'm running old 2019 maps and after spending an hour copying 28GB to an SD card to insert it shows "update on SD1" but then when it looks for it, no update 😞
It's driving me nuts.
TIA
Much appreciated if someone could provide an update for my OK3. I believe it's a bit outdated. Thanks in advance! @pab567 :)
