Amundsen MIB2 Firmware Update
4 minutes ago, Cairus said:
The Last Firmware in Firmware Train 4 is 0480
https://mega.nz/#P!AgGWtzUFoIPQqD6Qv8A-2I2d5XjuwDaK12fCuicLu8RAR3mRnTKXituarno4wcOvrRpcAAy3FgW3K4mjmEnGP-kFyJ61Pm_FPJBIxqi3HuslJs8BK-cZgzCt6IkRG4Rzf_BZxqYXR30
I have tried re flash to latest version however, my unit could not recognise the update so I was advise I would require a re flash bridge to then allow me to download the latest one.
  • Replies 4.7k
  • Views 900k
you need an edited meta file and the ToolBox
Thanks, that makes sense. I’m unable to send PMs yet. any chance you could point me to where I can find the edited meta file and ToolBox SD image, or is there a way to reach you externally?
If you can use the Internet and Google, you will find everything you need
On 01/08/2025 at 11:58, varaderoguy said:
It can only damage your system if the update files are either corrupted or the updates borks mid-upgrade. In most cases, the system will revert out of the update. I've never heard of any system being physically damaged.
Thanks for your response. The system was updated without any problems.
Hi
Can any one advise on the latest stable firmware for my Amundsen mib 2 please
I haven't updated since end of 2022, maps I'm currently downloading
WhatsApp Image 2025-08-09 at 20.31.56_ffedafa7.jpgWhatsApp Image 2025-08-09 at 20.31.56_10cce159.jpg
Hello
I have just bought a 2016 Octavia Estate, can anyone advise on updating the media system software, please, its currently.....
@pab567
Device part number: 5Q0035874B
Hardware: H30
Software: 0359
Navigation database:
V03959823CB
2510
ECE1 2026
SHIELD: SHIELD 2016-03 (build 020)
Edited by irishkeet
10 minutes ago, irishkeet said:
Hello
Hardware: H30
Software: 0359
V03959823CB
2510
ECE1 2026
Firmware 0369 is the Last in the train
https://mega.nz/file/Fm1yTYoZ#fC9DgUXxtEe1pz-IFr9KyR9teX44u5ECXH8ZddE4omc
Hi Cairus
thanks for sending the link, does this mean its the only update I can install, I cant do newer?
cheers
irishkeet
Offiziell, yes
On 09/08/2025 at 21:35, Stevejd58 said:
Hi
You already have most recent SW version for your unit.
Hello, I've been reading and learning on this forum for days. I have an Octavia from late 2015, 5Q0035864A, with MST2_EU_SK_ZR_P0253T. I've managed to activate Mirror Link with FEC_ALL, but not CarPlay. Can you give me any help before I run out of options to update the device? Thank you very much.
Is the USB port compatible? Is the coding OK?
I have problems with USB, I do all the steps through SD
Is the USB port even certified for Apple CarPlay and Android Auto? Is the programming correct?
The USB is Apple-certified, detects it perfectly, plays iPhone music, and charges without issue. Appconnect only displays the MirrorLink logo in gray.
Anything CarPlay/AA was post-2016, no?
No, CarPlay came in with the MIB2 infotainment which was introduced in around May 2015 on the Octavia 3.
6 hours ago, SalvaS said:
Der USB-Anschluss ist Apple-zertifiziert, wird einwandfrei erkannt, spielt iPhone-Musik ab und lädt problemlos. Appconnect zeigt das MirrorLink-Logo nur in Grau an.
This coding has been completed?
Unit 5F
Adaptation
Vehicle_configuration
Google_GAL
on
Apple_DIO
on
Edited by Cairus
@pab567 Hi can you please send me update for this radio from skoda rapid i need to try diferent one becaose the mic isnt working even after replacing it and i want to try sw before i try poking inside the unit
You are on the latest firmware.
@Matess36 I confirm what @varaderoguy wrote, in such case I believe this is either some HW issue with your infotainment unit or broken microphone harness.
Thanks to both I will try probing the wires to mic if it is still not working I will try if there are any solder cracks inside the unit. I also have unit from octavia mk3 so I can relace chips inside if I find something bad
Unit 5F
Adaptation
Google_GAL
on
Apple_DIO
on
Finally!!!! Thank you very much!!!❤️❤️❤️
8 hours ago, SalvaS said:
Endlich!!!! Vielen Dank!!! ❤️ ❤️ ❤️
then say thank you to my contribution please
