Android 10 Stereo £162 AliExpress gamble! Results:
4 minutes ago, Lamont1980 said:
You could give it a try and let us know 😉
Would happy try it but need to order the head unit and DAB dongle 1st 🤣
  • Replies 778
  • Views 101.7k
  • The job is never finished until you leave DNA behind!
  • Small update as have now gone back in and put a generic external microphone in place. I opted not to put it behind the trim where factory one is as it's blanked off on driver side and didn't think it
  • That screen to map out the steering controls is identical to that on mine.   If you did want to add DAB to it by the way then I can highly recommend the rear amplifier and splitter option.
After doing some digging it looks like it is a active DAB system, more information the link below but basically it seems the MIB2 unit kicks out 8.75volts to the antenna amplifier so not having the existing DAB connected to the MIB would throw up errors unless I changed the coding to tell it DAB isn't activated or installed.
It seems that most of the USB DAB dongles kick out 5volts to the antenna anyway so it might still work.
https://forum.obdeleven.com/thread/7557/antenne-problem-coding-hardware-fault
Hi,
one more question, is the cd player in the glove box still usable?
Finally are you fully happy with the unit?
8 minutes ago, nickytheshaft said:
Hi,
Plug(s) on unit in glovebox are unplugged and plugged into new screen so it is totally redundant.
OK so the player becomes useless.
I'd say the CD player became useless 15 years+ ago tbh lol
Especially when they put it in the Glovebox so you can't even change the disc without crashing the car.
Ha ha well said :)
In deed, it is lost space now
completely true...
I may five it a try, now I am hesitating with the different models.
Is it worth going for the octo core 4 gigs or is the octo core 2 gigs enought?
1 minute ago, nickytheshaft said:
completely true...
Going by peoples recent experience on here, I'd go with 4gb/64gb 8 core or 6gb/128gb 8 core only.
ok thanks, I will go that road.
Yip, don't touch the 2gb/32gb
will do thanks
On 17/03/2021 at 21:36, FUBAR said:
1 gripe I have with it, that I may be able to address but I haven't looked into it yet. The screen you see at the start of my video with heating controls info while changing stuff with it, when climate control is on auto and the fan goes up one speed or down one speed periodically to maintain the temperature, that screen will pop up to show the change.
Hi,
have you managed to fix this issue?
2 minutes ago, nickytheshaft said:
Hi,
You can turn the onscreen heater control thing off totally in settings so it will not come up ever, that's about it. Realistically the physical controls you use to set and or adjust the climate control tell you everything themselves, so it's not really needed in first place. I have left mine on still as it doesn't come up that often, only really when you change settings and when it then gets to temp requested and backs down to maintain it etc.
Ok good news. My MIB1 amundsen doesn't give me this info abd as you say the cliamt control in complete as it is so I don't care about this function.
I am just trying to get my head around what mic I need to place it in the factory position. I have a VRS LHD.
Was it hard to pull the wireing for the rear camera?
And also how long does it take to boot when you start the car?
Should be a little easier to install in LHD than in RHD as per the video near start of thread. Boot time I don't know I haven't timed it specifically, sub 30 seconds it's essentially a mobile phone or tablet being booted from fully off each time. Like any computer or android device it will boot into it's launcher then continue to load up stuff in background so for full speed smoothness of going through stuff a good 2 minutes, but can be used just a bit slower until it's done this. I run a custom launcher so that's running and booting in addition to it's factory one which adds a little to it.
Rear camera is fine if you are happy with removing boot trim and feeding it through the grommet that goes from boot to cars body and routing it to front of car, then it's just plug into adapter that comes with stereo and connect to a power source (there is one on the stereo specifically for this which is handy, but can use anywhere.
Near start I posted what I did instead of using the factory mic position as I really CBA with doing it and a mic open in the cabin with a boom would ultimately be the best for picking up the sound without spending silly money. You could stuff the same mic in place of the factory one against the grill, but I would think it likely less clear at picking up voice that way.
Thanks you.
Well another question. I was driving home and wondered. Can you still change the driving mode on the screen when you press the mode button. Plus do you have the custom mode with the different settings.
If it is not asking to much, if you have all these settings, could you post some pictures?
Yea it brings up a screen with the drive modes on it to select which one you want. The 'individual' one which you can set yourself, I have no idea how I would go back into it to change the settings of that one, but i already had it set up the way I wanted so not needed or wanted to try.
Great, I had a big doubt about that
Also in case you didn't know, when you press the drive mode button in front of the gear stick and it brings up your modes on screen, you can keep pressing the drive mode button and it will scroll through them, whichever one you leave highlighted it will go to that one after a few seconds so you don't actually have to touch the screen with factory stereo etc.
Ok so they kept the original function. Well , the project is getting better and better.
Also, does it auto dim when the headlights come on?
We have unlimited data on our cell phones in France and I have sygic with traffic information. I read that you have too. Can the unit take advantage of the cell phone to update traffic information Sygic?
Sorry for all these questions but I want to make sure it will be a confortable use.
Yea auto dim with headlights etc. If your mobile service provider also allows unlimited tethering you can use your phone as a wifi hotspot and let the car connect to that for full connectivity. Sygic works very well on it.
Just be sure to order the 4gb/64gb one or 6gb/128gb one and not the 2gb/32gb one
