Tested and working coding Octavia mk4
Just my comment on the "Driving mode on last remembered setting e.g. individual". This one is not possible.
  • Replies 294
  • Views 125.7k
  • Self moderation is the key to happiness. The best reply is sometimes no reply at all.   we’re all free to do what we want to do with our stuff.   Why would someone buy a brand new
  • @SkOmk4, My answer in line: 1. All the Release Active DTCs will be present only on the SFD locked modules. The reason why the DTC is still present on that module is that you forgot cu SFD Lock the m
  • I think both sides of the argument have some validity.   Perhaps an addition to the first post by the OP stating that you should backup the configs before doing anything, you should understa
On 22/05/2023 at 22:36, tomas_cz1 said:
Open door alarm deactivation with engine on.
Tested that one and working ... but in my case the adaptation is called in a different way: there are 2 variables instead one ... Ausgabe MoLaWa_AAW from active to not_active and Unterdrückung der Zündungswarnung from active to not_active.
is it possible to disable annoying warning sound for drive in the center of the road?
Edited by brankokotor
On 13/03/2022 at 19:53, petopzdiag said:
activate additional ambient light colours
open the bonnet
09 central electrics - adaptations - interior light  hmi config
first and second value should be 7fffffff coding and ignition of, ignition on turn multimedia on , find ambient lights and shoul be activated additional 20 colours
this worked for me btw,
Hello
is it possible to code a tow bar on a O4 vrs 2022 with odb11 ?
like here :
yes :)
if anyone needs coding, we can do it remotely, any car, vcds or obd11 needed
On 28/06/2023 at 13:49, petopzdiag said:
yes :)
No problem with sfd protection ?
no, working good :) normal just coding
I drive 2023 Skoda Octavia that does not seem to have ambient lightning in the cockpit. Does anyone happen to know if the hardware is still present in the car and I could enable it by coding?
I have the same question.
No, it's not. You need all the lights and everything in order to retrofit it.
Have a question - i have 2023 mk4 and want to do some coddings, but dealer told me that if i plug obd11 and made any changes, the warranty will be gone, because of the online Skoda services.
does this is true and can i do it without anyone can see it ?
hello, warranty will be gone when you : clear error code or reset service inetrval, do something with mechanics work, and turn off start stop or seat belt.... other coding all safe because your car only has those things when you unlock them.
you don't have to worry, we code 3.4 new cars under warranty every day and warranty not gone ... :)  we coding new car skoda audi seat bmw and other .... :) dont wory
Hello,
so does this mean, that codding like - needle sweep, vrs theme on digital cockpit + torque monitor can be used, without warranty gone ?
Yes and many other coding .. vrs theme  daytime running light to menu radio. And other coding from list you can coding all options only dont disable seat belt Warning and start stop and dont delete error code , dont reset service interval
I find it really hard to believe that deleting any error code at all would invalidate the warranty. I've been deleting a bunch of intermittent communication bus error codes and the likes every once in a while to tidy everything up when scanning. Dealer hasn't mentioned anything during visits...
Yes but sometime  dealer can see resrt interval or delete dtc code in ecu parameter..
  • 3 months later...
Great thread any new adaptions like the headlight washer delay?.
@petopzdiag
do you have a more updated list of coding available for the mkiV vrs?
I used your original list and successfully coded :
G-meter
Volume to be replenished
but Lap timer didn't seem to work - when i get to Control unit 17 adaptation-personalization -display _laptimer to active - it wont accept that change ( gives error 31)
There are a couple of other things i want to do, can you help with these?
Rear teardrop wipe
set ambient colors in 'mode' setting to specific colours.
set convenience turn signal from 3 to 5
Also i took up the free offer from skoda for extra ambient colours and  additional functions, They are free for the first month, after which i'll want to code them in, you've already shared the extra colours, do you have a 'how to' for the additional features?
Edited by mczakk
44 minutes ago, mczakk said:
@petopzdiag
G-meter
Rear teardrop wipe
Hello,
for No2 (ambient colors in "mode"  please see this link
https://forum.obdeleven.com/thread/19160/interior-colors-changed-drive-modes
and this
https://www.vwgolfcommunity.com/vb/forum/vw-golf-world/vw-golf-8/interni-ad/1414069-luci-ambientali-preimpostati-come-modificare
If you have OBD11 maybe you could successfully change the colors.
Edited by Giannis20
3 minutes ago, Giannis20 said:
Hello,
and this
I have seen these posts, but wasn't able to change the values in the modes, don't know if there was a previous step I missed?
You know about SFD lock right? Are you familiar with this?
Yes, control unit 09 was unlocked.
I am aware that this guide was for a golf, has anyone managed to get it to work for an octavia?
On 11/03/2024 at 17:27, Giannis20 said:
Hello,
and this
This doesn't work for the Octavia, probably because the golf only had four dive modes, while the octy had five. I can change the values in the interior lights general settings, but it just does random things. None of the mapping_fpa_profilexx settings seem to relate to the drive modes.
Edited by mczakk
