Infotainment System Restarting endlessly
4 minutes ago, SkOmk4 said:
Kövesse a fórum szabályait srácok, ez nagyon udvariatlan a többi taggal szemben...
Privát üzenetet küldhettek egymásnak, ha külön beszélgetést szeretnétek.
Dear System Administrator!
I apologize! Your comment is completely valid.
I recently found this forum and learned a lot of useful information.
Sincerely, HeRee79
  • Replies 1.7k
  • Views 399.9k
  • I had so many spontaneous reboots this week with even 4 occurring on the same day that the infotainment system was practically unusable. That’s why I decided to go ahead and install 1941 yesterday.
  • TheUltraRunner
    TheUltraRunner
    Hi all. Maybe this will give some of you guys some hope. I copied this message from German FB group from a respectable source. Translation might be a little bit off since this is FB automatic t
  • No, with the specific original file.    I will post the link. I don't know if it is OK by the forum rules. If it isn't please tell me to delete it immediately.  Update size is almost 10
Hello! I called Skoda service and they said that I should have received the 1941 update by OTA at the beginning of October. OTA doesn't update for me. Any ideas why it won't download the update? I am a main user, online update is turned on, I have an eSim.....
What can I expect from the dealer?
If your vehicel is qualified you still might have to be more patient since the rollout is done "step-by-step" so the update is not available for all at the same time. If you can't wait due to pressing issues the dealer should be able to help you via manual update our you perform the update by yourself @own risk...
Hi! Could I have the link to the SW 1941 please?
Mine was in yesterday for it's yearly service and already had the 1941 update. There was a TPI for it though to module 5F that specifically targets the infotainment system reboots.
I'm at work this now so will edit my post when I get home with the TPI number.
John
The TPI is 2069590/3. This does an 5F recovery and part of BAID 167231935.
I hope this helps folks.
John
Mine hasn`t rebooted so far (5 days using the car). Used to do it on every few starts of the car.
Got mine, it's update this morning it's. just installing 1941 now, waiting for it to download.
UK.  Old version was  1898 👍😁
כי
System information
Device part number: 5E3035816K
Hardware: H58
Software: 1898
Display unit/control panel hardware: H47 Display unit/control panel software: 2103 Navigation database:
23.3
Media Codec:
3.1.4
Edited by skoda2019
ooh exciting! I've driven mine for about an hour this morning. 3x crashes and no sign of an ota update :dull: Hopefully soon!
I have slightly older (ever so slightly) system stats though...
Device part number: 53035816H
Hardware: H56
Software: 1896
Display unit/control panel hardware: H44
Display unit/control panel software: 2088
Navigation database; 20.3
Media Codec: 3.1.4
My dealership updated my infotainment software a couple of weeks ago and I assumed it was the latest version, but reading the above posts, it doesn't seem to be...
Device part number: 5E3035816H
Hardware: H56
Software: 1896
Navigation database; 22.1
Media Codec: 3.1.4
Since the update, my sat nav hasn't loaded at all (I've using my android phone instead) and it hasn't stopped the "pop pop SOS" error. The system doesn't restart itself though. I wonder why we all have different software versions.
Just try getting the 1941 update.
UK Over the air are dropping for 1941 you just need to be a bit more patience.
It's worth the wait.
Or call into a dealer to sort it if you're in a rush and not confident of doing it yourself.
I was tempted to DIY but it's not my car, so very happy it was showing as OTA this morning.
@jpeg86.  Your maps are out of date so are you sure you're getting OTA updates?
I think that's because i'm not subscribed to the "Infotainment Online" package in the shop? it reads like you only get the latest map updates if you pay for that... and seeing as i use waze via carplay, i dont see the need.
You're correct. The map updates have nothing to do with the system updates. You get system updates OTA regardless of any subscriptions.
So after week of driving no more reboots!!! The 1941 update worked for me thx all!
On 24/10/2023 at 07:39, HeRee79 said:
Szia ! Egy olyan kérdésem lenne, hogy bejelentetted a szervizben a hibát és úgy küldték rá a frissítést vagy automatikusan jött?
On 24/10/2023 at 07:47, WiziPok said:
Szia, minden automatikusan történt minden bejelentés nélkül, csak sokat kellet várni rá 🙂. Az autót 05/2023-ban gyártották.
@HeRee79 & @WiziPok can you please write in English ONLY as per the rules, I appreciate English may not be your first language, if at all but please use a translation service (google etc) if needed:
5. Posting & Freedom of speech
All posts should be made in English. The use of other languages, or "txt speak" is not permitted and will lead to posts being removed.
Hello!  I have an appointment for the update on November 7th!  Downloaded it by itself today and installed it in 15 minutes!  Haven't tried it yet, but I'll give it a try!
Good, you can cancel the dealer appointment now then and save some money 💰
Finally got the 1941 update over the weekend. I didn't have any loop problems, but I am hoping it *might* fix the Android Auto bug I have.
Anyone else use Android Auto via USB-C? Works flawlessly? Periodic problems? Mine mostly works perfectly, but occasionally I am unable to press icons which requires me to reconnect USB-C.
Tell your phone to forget your phone and set it up again, just be aware that if you have a VPN installed on your phone, that it's disabled as it causes AA to crash with a Red Screen of Death.
That's useful to know, thank you. I've been encouraging the family to use a VPN when out and about on public WiFi at least - but easy to leave it on when back on good ol' 4G and connecting to the car. Hopefully they'll sort it for AndroidAuto; thankfully I had no such issue with iOS and CarPlay but worth being aware of the potential.
Back to 1941 update; mine sometimes reboots once when first starting the car (about one in three or four times) but the repeated reboots for the initial few minutes are gone.
It shouldn't be doing any reboots, mine isn't doing it and its had a few downloads on top of the update.
Thanks. Thinking about it, what I am seeing is probably an initial boot up (rather than a 'resume' from sleep/standby) as it occurs mostly after being left for a while.
