VCDS options on Superb III.FL
On 07/05/2024 at 12:12, MartiniB said:
@leolito
on my previous Mk3 i have done this mod
The throttle response
44 - Steering Assist
            Security access: 19249
            Adaptations:
                        channel: 'Driving profile switchover' change
                                    from 'Incremental: controlled over time'
                                    to 'Direct: controlled over threshold value'
but i skipped it on my current Mk3.FL, me similarly as several colleagues noticed, it works more like a placebo,
touchable difference can be get just by moving back DSG lever, fasted way to switch D <-> S
I did not try the adaptation yet, I am unable to find free time to play, every time I need to use the car I have some unavoidable task and cannot risk something going "wrong" 😝
I saw there is a 'Torque Steering assist' setting or something similar, what is it?
In any case I tried in a ~300km trip I had yesterday to play with the settings, and I concluded that:
- in 'Sport' the throttle response in much better, but the ride becomes very choppy and harsh
- will try to set up 'Individual' mode with a mix, if possible (say suspension on comfort, DSG on sport, etc. and see)
- the DSG response in 'comfort' or 'eco' is very laid back, in Sport more active
- I tried to move the lever from D to S but it goes in "Manual", not "Sport". Am I missing something?
In any case I see me going to the pedal box if playing with the above settings does not give a meaningful result.
  • Replies 264
  • Views 87.7k
  • Why would you want them off? Auto lights are notorious for people driving around in poor visibility and no rear side lights.   Personally I always code them to be on.
  • https://github.com/olli991/mib-std2-pq-zr-toolbox Here you can find out whether it is suitable for MIB or not
  • Paikesejanku
    Paikesejanku
    Yes, you have to change two values: 09 – Central Electrics - Adaptions Search 'scheinwerferreinigung' (headlight cleaning) Select 'SRA Verzoegerungszeit' and set value to '2000' (don't wor
This only change the gearbox setting, not the driving profil. Thus it's normal, that it doesn't switch to "Sport" mode.
However, it's strange, that it goes to "Manual". If you only pull the lever from D to S it shall keep in automatic. To switch to "Manual", you really need to push on the side...
Yes, sorry, I meant the DSG should go to "Sport", not the driver profile. So many settings! 🤪
And yes I confirm I have tried this more times, flicking the lever from Left to Right goes into "Manual" mode, which after you can operate with the "+/-" or with the paddles. When flicking the lever back to Left, returns to "Drive".
This, irrespective of the driver profile loaded (i.e. Eco, Comfort, Normal).
Now I read you better and perhaps I should try to "pull" the lever towards the rear, not the side, and see if that makes it go in "S".
Will try!
:thumbup:
Yesterday I had a long ride, but on an Octavia 4x4 with the same 7spd DSG.
I did pull the lever towards the rear and it goes to 'Sport' (only gearbox response, of course).
That made the ride much more interesting, compared to the dull response in D.
Can't wait to try it on my own 280 now. How foolish of me not to notice that ... how they say it? RTFM? 🙄
@leolito
just one but 😞
with smaller engines i can leave 'S' all day long
while 2.0 TSI keeps too long gears and i have to switch back to 'D'
when reached third gear after pulled from standstill or after overtake
Well, this was a TDI and I did notice it would keep, as you say, the higher gears for long. On the way going on my journey (it was early and we had time and all the nice things) it was just a D thing, on the return leg we made a mountain pass, very little traffic, and I was "chasing" (literally! 😁) my colleague that went to pick up a Tesla suv do not know what, so it was S all the time.
I've noticed  that if the keeping in the higher gear bothers (say it stays in 5th or 6th instead of 7th), a quick flick back to D solves the problem. And another back to S when needed ... hope the selector like that! 😊
On 07/09/2023 at 08:05, MartiniB said:
my apologises about starting this new thread, few reasons to keep it separate:
1. Mk3 coding's thread is grown hugely and isn't easy search something in it.
2. FL codings has several differences.
3. coding procedure has been also changed -
 before do coding, must be opened bonnet and activated handbrake
what have been tested on Mk3.FL MY23 280ps L&K
23.02.21          OK
** Scandinavian Daytime Running Lights
09 Central Electrics
            Access Code 31347
            Adaptations
            -> Leuchte23SL HLC10:
            --> Lichtfunktion C 23:
                        nicht aktiv       ->         Tagfahrlicht
            --> Dimmwert CD 23:
                        0          ->         100
            --> Lichtfunktion C 24:
            --> Dimmwert CD 24:
                        0          ->         100
23.03.20          OK
*- - Daytime Running Lights only with switch on ‘Auto’
*** Daytime Running Lights off with Handbrake
*** Daytime Running Lights Setting available via Menu
            Access Code 31347
            Adaptation
            -> Aussenlicht_Front
            ---> Tagfahrlicht nur in Schalterstellung AUTO:
                        not active        ->         active
            ---> Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten:
            ---> Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich:
23.03.20          ok, Fogs added, headlights didn't gone
*** Set Fogs Lights as Coming/Leaving Home Lights
            Access Code 31347
            Adaptation
            -> Aussenlicht_uebergreifend
            ---> Coming home Leuchten:
                        Low beam       ->         Fog light
            ---> Coming-home Einschaltereignis:
                        driver door      ->         ignition
23.03.20          OK
** High Beam Memory On
            Access Code 31347
            Adaptation
            -> Fernlicht_assistent
            ---> Fernlichtassistent Reset:
                        active   ->         not active
23.03.20          NOK, + Foglight ERR
- - Coding Eyelashes always on in the headlights
            Access Code 31347
            Adaptation
            -> Change (8)Leuchte17TFL R BLK ......... C17 to Daytime running lights
            -> Change (10)Leuchte17TFL R BLK ......... CD17 to 100
            -> Change (8)Leuchte16BLK SLB ......... C16 to Daytime running lights
            -> Change (10)Leuchte16BLK SLB......... CD16 to 100
23.03.20          OK
** Comfort Blink Cycle
            Access Code 31347
            Adaptation
            -> Aussenlicht_Blinker
            ---> Komfortblinken Blinkzyklen:
                        3          ->         2
23.04.03          OK
*** Tear Drop Wipe For Front Wipers
            Subsystem: 48x LL 221122
            Long coding
                        164DDD
            ->         1E4DFD
            -> Byte 0
                        Bit 3 "Adaptative Post/Tear Wiping Active"
            -> Byte 2
                        Bit 5 "Post/Tear Wiping Active"
or         Adaptation
            -> Front_wiper
            ---> Traenenwischen Front Status:
23.03.20          OK
** Smoth Dimming / Brightening Internal Light
            Access Code 31347
            Adaptation
            -> Suchbeleuchtung_allgemein
            ---> KL58 Einschalten mit Rampe:
23.05.09          OK
* Dim Emergency Flasher Button on Dash
            Adaptation
            -> Leuchte 35 LED Warnblinktaster C48
            --> Dimmwert AB 15:
                        100      ->         55
23.03.28          OK
*** Change Light threshold
            Access Code 31347
            Adaptation
            -> Light sensor
            ---> Helligkeitsgrenze_Licht_ausschalten:
                        orig.     2200 lx
                        ->         1200 lx
            ---> Daemmerungsgrenze_Hysterese_untergrenze:
                        orig.     2200 lx
                        ->         1200 lx
            ---> Helligkeitsgrenze_Licht__einschalten:
                        orig.     1200 lx
                        ->           800 lx
            ---> Daemmerungsgrenze, Hysterese_obergrenze:
                        orig.     1200 lx
                        ->           800 lx
23.05.09          OK
*** Enable Autolock(based on speed) option in Car Settings
09 Central Electronics
            Access Code 31347
            Adaptation
            -> Menuesteuerung ZV Autolock-Unlock:
                        not active        ->         Adjustable
23.04.20          OK
*** Enable Fob with Car Running
            Access Code 31347
            Adaptation
            -> ZV allgemein(Access control)
            ---> Funk bei Klemm 15 ein:
                        not active        ->         Active
23.05.09          OK
*** Enable passive lock/unlock via door handle sensors (KESSY) with ignition on
B7 - Access Startsystem Interface
            Long Coding
                        0F20000723
            ->         1F20000723
or         -> Terminal 15 characteristics of passive entry exit function
                        orig. value:      Function only allowed for terminal 15 off
                        new value:       Function only allowed for terminal 15 on or off
23.03.20          OK
** Enable Fan Level display on Climatronic Auto
08 Air Conditioning
            Long coding
                        11010004004411011005100D00109136
            ->         11010004004411011005104D00109136
or         -> Blower display in auto operation:
                        Not activated  ->         activated
23.03.20          OK
** Retain Heated Seat Setting
08 Air Conditioning
            Long coding
            ->         11010004104411011005104D00109136
            Adaptation
or         -> Retention of driver's seat heater level
                        active for 10 minutes  ->         active
            -> Retention of frt.pass. seat heater level
23.03.28          OK
** Heart-Beat light effect on Start Engine Button for Keyless
B7 Access Startsystem Interface
            Access Code 20103
            Adaptation
            -> DeveloperCoding: Search lights
            ---> ZAT_illumination_concept_mybeat_clamp58xt
                        Not activated  ->         Activated
            ---> ZAT_illumination_modus_mybeat_clamp58xt
23.02.21          OK
*** add Simple Cruise Control
13 Adaptive Cruise Control
            Long Coding
                                32057FD25DFFC728949C812481400680000000000000000066
            ->                 32057FD25DFFC728949C812481400680000000000000000076
or         -> Cruise Control Mode:
                        --> Activated
23.03.27          OK
*** Start-Stop prevent Engine start when Car in front moves
            Adaption
            --> Expanded restart function:
                        On       ->         Off
23.03.27          OK
*** Overtaking Right Prevention
            Long coding
            ->         32055FD25DFFC728949C812481400680000000000000000076
or         -> Overtaking_right_prevention:
                        activated         ->         Deactivated
23.04.19          ok, option added, but works only first of three
*** add Tolerance for Predictive Adaptive Cruise Control
            Long coding
            ->         32055FD25DFFC728949D812481400680000000000000000076
            ->         32055FD25DFFC728979D812481400680000000000000000076
            ->         32055FD25DFFC728979D812481400680000000000010000076
or         -> Tempolimitassistent_CarMenu:
or         -> zul_Regelabweichung_CarMenu:
                        orig.     Off
                                    Small     (nothing)
                                    Medium (nothing)
                        ->         Large     (off; low; medium; high)
or         -> pACC_Learning_drivers_offset:
                        Deactivated     ->         activated
23.03.31          OK
*** Minimize Lane Assist's Ping-Pong Effect
A5 Driver Assistance
            Long coding
                        00020898116E4020089F10001030008001418000000000000000000000000000
            ->         00020898116E4020889F18001030008001438000000000000000000000000000
or         -> Point_of_intervention:
                        early    ->         early_setting_over_menu
            -> HC_Warn_Intensity:
                        No_Setting      ->         Setting_over_Menu
            -> Lane_assist_off_text:
                        disabled           -> enabled
23.04.11          OK
*** Lane Assist automatic ON from 60kmh
            Long coding
            ->         00020898116E4020889F18001030008001238000000000000000000000000000
or         -> Hc_variante:
                                    Variante_0 (? Off ?)
                        ->         Variante_1 (automatic, when 60kmh reached)
                        orig.     Variante_2 (manually, by button on Steering Wheel)
                                    Variante_3 - 7 (?????)
23.04.11          ? OK
? Emergency Assit mode, what is diff ?
            Long coding
            ->         00020898116E4020889F28001030008001238000000000000000000000000000
or         -> Emergency_Assist:
                                    Not_coded
                        orig.     EA_Variant_1 (?????)
                        ->         EA_Variant_2 (?????)
                                    EA_Variant_3 (?????)
                                    EA_Variant_4 (?????)
23.05.20          OK
*** Disable DSG coasting(sailing) function on Normal profile
19 Gateway module
            Long coding
                        0B0900047F285900AB1042DE980F00010001070000000000000000000000
            ->         0B0900047F285900AB0042DE980F00010001070000000000000000000000
or         -> FPA_function_freilauf_defaultON
^^^     ? ok
            Long coding
            ->         32055FD25DFFC728979D816481400680000000000010000076
or         -> Sailing_function:
                        not active        ->         no_predictive_sailing
23.03.27          OK
** Change Parking Assist Switch Off Speed
76 Parking Assistance
            Adaptation
            -> Switch-off speed for parking assist
                        15 km/h           ->         10 km/h
23.03.01          OK
** Easy Entry driver
36 Driver Seat
        Long coding
                        0010000000000500018280808080000000008181000000D440
            ->         0010000200000500018280808080000000008181000000D440
            ->         001000020000050001C280808080000000008181000000D440
            ->         001000020000150001C280808080000000008181000000D440
or         --> Easy_Entry_front:
            --> Easy_Entry_front_over_MMI:
            --> EasyEntry_Enable_Passenger_over_DriverMMI:
23.03.20          OK
** Easy Entry passenger
06 Passenger Seat
            Long coding
                        0010000000000500018280808080000000008181000000D400
            ->         0010000200001500018280808080000000008181000000D400
            ->         001000020000150001C280808080000000008181000000D400
or         -> Easy_Entry_front:
            -> Easy_entry_front_over_MMI:
23.03.01          OK
* Easy Entry options in Car Settings
5F Multimedia
            Security Access 20103
            Adaptations
            Vehicle menu operation
                        menu_display_seat_configuration
                        menu_display_seat_configuration_over_threshold_high
            Vehicle function list BAP
                        driver_seat_0x10
                        driver_seat_0x10_msg_bus
                                    Not activated  ->         Comfort data bus
23.03.20          OK
* Date format
17 Dashboard
            Long coding
                        05A5001AFF8C00080188634B1001000800600000
            ->         05A5001AFF8C000A0188634B1001000800600000
or         -> Date:
                        dd_mm_yy      ->         yy_mm_dd
23.03.20          OK
* Refuel Quantity
17 Dashboard
            Long coding
            ->         05A5001AFF8C000A0188734B1001000800600000
or         -> Byte 10
                        Enable bit 4
23.04.03          OK
** ICE Warning threshold
17 Dashboard
            Adaptation
            -> outside_temperature
            ---> p_ice_warning_entry_temperature:
                        4 °C     ->         2 °C
            ---> p_ice_warning_exit_temperature:
                        6 °C     ->         3 °C
23.04.11          NOK, but it deactivates Start-Stop
- Efficiency assist.
17 Dashboard
            Long coding
                        05A5001AFF8C000A0188734B0001000800600000
            ->         05A5001AFF8C000A0188734B0001080800600000
or         -> Efficiency assist.:
                        No       ->         Yes
23.04.11          OK
23.05.20          reverted
* Disable Exit Warning
17 Dashboard
            Long coding
            ->         05A5001AFF8C000A0188734B0001000800600000
revert   ->         05A50019FF8C000A0189734B1001000800600001
or         -> Exit warning:
                        Yes      ->         No
23.05.09          NOK
* Disable Ignition On Warning
17 Dashboard
            Adaptation
            -> Ignition active message, actuator
                        Driver door(orig.)        ->         No display
23.06.08          ok
17 Dashboard
            Adaptation
            -> Tubes illustration
                        orig.     Version 0
                        ->         Version 1
23.06.08          NOK, err msg on dashboard "Vehicle is not secured against rolling away"
17 Dashboard
            Adaptation
            -> Shift exit warning
                        orig.     Car exit warning
                        ->         Exit warning, VW commercial vehicles
Thank you for the detailed explanations. I used some on a 2023 SIII L&K, however I had to revert some as I seem to have very different codings of some controllers and I had some errors. I did the coding with VCP.
The seat settings worked, I could also stop the engine on warning with the driver door open, the light not on warning when not on auto, high beam memory and a few others.
I could not code the pingpong of the ACC, the DSG coasting disabling and reverted.
I would have liked to code the eyelashes!!! I have taken a screen shot of the lamp adaptation page. If anyone knows which lamp numbers are the eyelashes I might try again. When I coded as described I received an error to check my fog lights.
I was left with a stupid error which I am unable to trace back so far. I tried to code the VZE /TSR and after getting nowhere I simply copied and pasted my original coding for the controllers.
STG17 is still showing VZE error in the dash when I switch on the ignition.
The error is in the attached pdf file. Does anyone know which adaption I did not revert by any chance?
DTC STG17.pdf
Eylashes coding is 100% not possible on a S3 FL.
Vor 22 Stunden sagte 26DIPP:
Am liebsten hätte ich die Wimpern codiert!!!
You can save yourself the effort with a facelift!
This FL is starting to suck ... they took away the pleasure of playing! 🤪
Did I write this?
Can anyone tell me if I can activate an indicator light in the virtual dashboard (AID) to show that the headlights are on. I know the car should do it in Auto setting of the light switch. I just miss it from my previous Superb.
51 minutes ago, 26DIPP said:
I went through the manual of my MY2023 and I don’t see any indicator for this function.
I’d say the best you can do is check the lights knob. In the auto mode, the parking lights indicator should be lit when the headlights are turned on (the one named „led” in the attached picture)
What I mean, is there an option in the controller to code in a light that comes on in the virtual dash?
If there is no indicator light for this in the AID, then you can't code anything there.
The main beam or DRL indicator on the instrument cluster is gone for good in almost all the cars.
Don't worry - compared to some other cars your chances of driving without main beam at night are close to zero. The car would give you a message on the cluster if you are driving on DRL at night.
Besides that of course - just leave the light switch in Auto mode.
Edited by komoornik
Another coding question.
Can I set the driving mode so that it remembers the last setting and does not reset to "Normal" again?
The answer is: yes and no.
Yes, this can be changed.
No, this is not done via coding - but via changing parameters (quite a bit more complicated  then coding with OBD11).
I did this in my car:
Hi, I am having trouble with several topics:
-Skoda virtual surround & subwoofer: in ECU 5F, it want to change byte 11 to "Sound_System_internal_individual", however there isn't any option available. Is this function special to certain SW or vehicle trims?
-Aircare always on: I changed ECU 08 adaptation "Filtering of interior air: store" from "service life dependent store" to "active", however, I still have to manually activate Aircare everytime. Is there further coding necessary?
-Emergency assist: I want to activate the function, is it part of Traffic Jam Assist? I did the following changes but there isn't any option appeared anywhere in the menus:
   -A5 -> Byte 10, bit 4-6 "20 Emergency_Assist, EA_Variant_2"
   -13 -> Byte 4, bit 2 "Emergency assist active"
   -09 -> Channel "Aussenlicht_Blinker-Warnblinken_durch_Fahrerassistenz" --> Active
 Lane assist is active any working properly
Thank you
I have another couple questions about the FL models.
1. Is there a way to get the ACC / CC adjusted in single MpH / Km/h steps rather than the 5 MPH steps as it is now.
and
2. is there a good FL guide to code the Traffic Jam Assist?
If not changed from non FL :
Pull the ACC stalk = +1 MPH / Km/h
Press "Set" at the end of the stalk = -1 MPH / Km/h
The FL does not have the CC / ACC on the indicator stalk but on a separate one below.
When you pull this stalk forward it activates ACC, LA and whatever else... The increments are in 5 MPH / Km/h up or down.
I was wondering whether there was a setting in the adaptation when coding the controller that I have missed.
exactly same on FL, and
stalk Up for + 10 Km/h, Down for -10 Km/h, Forward turns ACC Off
one important note, @Bap33 and me are talking about continental not UK steering wheel
i have/had (2023FL/2016Mk3) version without mode button
Are yours going up and down by 1 or 10 Km/h?
I cannot remember if I have have a Mode sign on mine. What does it do?
