  2. Phil439 joined the community
  3. nbramwel replied to gwm97e's topic in Škoda Scala
    Try Blackrod Service (or MOT) Station. Have used them in the past for MOTs and service/repair work. Have always been fine to deal with.
  4. I'm from Austria... the parts were way too expensive. 5Q0 is rubbish, just upgrade to 2Q0. Much better.
  5. Today
  6. Yes you have to 'withdraw' from the finance agreement within the first 14 days, not cancel it. My interest payment was £9.48 for 3 days. All straightforward enough.
  7. aggagaa244 joined the community
  8. Just to mention that I bought the 5Q0 radars on ebay from Austria which were from a similar Skoda Octavia mk3 2017 and both units cost me 252€. The original used mirrors with dimming from ebay cost me 136€ (one was chipped), the cables I bought from aliexpress for around 50-60€, the radar mounting brackets I bought from skoda-parts.com for 24€/both, also needed to buy a couple of cables, pins and connectors from aliexpress for around 10-20€ max. So everything cost me around 500€
  9. Reckon if its still there its either worn splines or worn cv joint. Get someone to hold shaft and try turning wheel by hand if its still there it would I think rule out Gbox and inner cv. Alasdair
  10. That's an excellent project and thanks for providing so much valuable info, I didn't know the mirrors from mk4 could be installed on the mounting bracket of the mk3! I also love that the LEDs will be integrated in the mirror casing instead of mirror elements since they are incredibly expensive and can easily be stolen I also heard that the 2Q0 radars are better than the 5Q0 ones because their range is bigger. I have just finished installing BSD/RTA myself this week on my Skoda Octavia mk3 1.4 TSI 2017 using the 5Q0 radars and original mirror elements with BSD LEDs and dimming and I am happy how the system works: I will follow your topic @Cairus to see how your work evolves! Good luck!
  11. Or maybe not 🤔
  12. Dont Work anymore What i know Can check with my 3 devices
  13. Thanks, makes sense! Do you know what dataset I need for my unit? I tried to search here https://mibsolution.one/#/1/9/Datasets/MQB/5F by my unit number 5Q0035874C and couldn't find anyting.
  14. Yes
  15. Maybe, but still true nonetheless: all demos are always done in as near-perfect conditions as possible, never reflecting real-life situations and therefore spreading misinformation and false hopes.
  16. If you're going away from OEM sizes you probably need to clear it with your insurers.
  17. Hello. I'm having a problem with my 2021 Scala 1.5 petrol. There's a display issue and an SOS message appears. I've read that a system update might be necessary. I'm currently running firmware version 1800. Has anyone done the update themselves? Is there any instructions available?
  18. I use https://tiresize.com/comparison/ if you go for 205/45 at 60mph its actually 62mph and 205/50 its actually 64mph according to their site. As previously said as long as all tyres are the same size ABS etc wont be affected. Had 225/40/18 on a people carrier but the weight rating was too low so went for 225/45/18 and didnt really notice. On it the larger size just cleared the bottom of front strut. Make sure you have enough room. Alasdair
  19. Jeszcze raz witam serdecznie.
  20. "Hello everyone. I own a 2021 Skoda Scala 1.5 petrol. Thank you for accepting me into the forum." Hi and welcome to Briskoda. Please note the default language is English. We understand it's not everyones first language but there are translation tools available. Cześć i witaj na forum Briskoda. Pamiętaj, że domyślnym językiem jest angielski. Rozumiemy, że nie dla każdego jest to język ojczysty, ale dostępne są narzędzia do tłumaczenia.
  21. From reading that reply…. I think you completely missed the point I was making, through use of sarcasm.
  22. Good morning and welcome to Briskoda. Please use an online translation tool prior to posting in order use the required language of English. Thanks! And again welcome onboard!
  23. Pietia215 started following Powitanie.
  24. Witam serdecznie wszystkich. Jestem posiadaczem Skody Scali z 2021 r. 1.5 benzynka. Dziękuję za przyjęcie do grona forumowiczów💪💪💪
  25. The mounting base is screwed to the door. You have to detach the mirror from the base plate.
  26. Pietia215 joined the community
  27. Thanks! Nice catch! Sorry, what is the Ground Blade?
  28. Octavia 4 But you need the Ground plade from Octavia 3
