Felicia bonnet swap
Hello all, i have the 1.9 felicia pickup and to be able to swap the bonnet to the facelift one i must remove the radiator so i can get to the screws that hold the grill to be able to remove it. Since i cant do it on my own i asked a mechanic to do the job. Now he tells me the lock i provided has different screw holes. Have i got the wrong part? Thanks in advance for any help.
FernandoPessoa started following Felicia bonnet swap
Skoda Fabia 1.4 oil problem
The OP posted that it is a 1.4 16 valve 84 ps. That is not a diesel so no glow plugs.
Oh, it's a diesel? Ignore my previous post completely then.
Probably one of the seals between rocker cover and head failed in one of the spark plug wells. Not a nice job to fix that as it's a sealant gasket, and the cambelts need to come off to remove the rocker cover, I think, judging by this image: There will be a problem causing crankcase pressurisation too, I think, most likely the oil separator on the back of the block being clogged to buggery. Probably worth replacing that, cleaning everything up and then seeing which plug well fills up, and how fast.
That's what's confusing...pooling under rocker cover. The oil only found in pan below engine last week when oil pressure light came on. Mechanic is totally stumped.
DrawingSeeker25 started following Fabia MK II 2007-2014
Radio cutting out new starter motor
With engine off I reckon 12.6v to 12.01v with what you said on is normal so pretty sure battery is good. Blower plus dip and fogs will draw a fair bit of current. Does yours have an earth strap from Gbox to chassis and has it been checked. Alasdair
- R600 Plus Pikey mod Skoda-specific?
I've replaced the extension live wire to starter motor. Even with correct sized spades I've had to crimp with pliers to tighten fit. Duct tape just in case. I used extra earth to starter from battery neg. Radio still cut out. I'm on my own so no voltage readings. I did a drop test on battery. Ign on dipped beam, blower on fogs on. 12.01v Which is possibly questionable for a Feb 2026 battery. Resting voltage is always above 12.6v Alternator giving 14.2v iirc Last battery lasted 6years and was resting at 12.3v but drop tested to 11.6v or lower. It failed to hold charge dropping to 12.1v resting. Soon after power steering light came on. Heavy steering etc. Could be battery? Coincided with cold weather arriving. I've got battery tester but last batteries on other cars that were on way out were passed and told me to recharge. Only when cell collapsed does it fail . Shop replaced battery FOC (2 year old Bosch and 5yr warranty).
Possu joined the community
19” vega alloys advice
Screen shots would help me 😂
Heater not working
That may either be a blocked heater matrix or airlock. Has there been any work done on the cooling system recently .Check that the expansion reservoir doesnt have the silica bag in it. If it ruptures then it will block heater matrix. Think they have Mit Silicat on them. Have read that if may also have G13 on tank Alasdair
Alasdair1 started following Heater not working
If oil seperator gets blocked or PCV( Think its a diaphram one) is bad it can lead to excessive pressure and force oil out. Normally at weakest point/seal. I agree with warrior Overheating and smoke is not good. I assume it was oil temp warning. If seperator and pcv are ok it could be blocked oil return passage ways so oil isnt managing to get back to sump. I think with engine running there should be a slight vaccum at oil filler cap. If it feels like pressure then I would get the seperator/pcv checked. Might be worth a compression test as well. Alasdair
GIBbeer joined the community
DrawingSeeker25 started following Skoda Dealers - North East , Breaking cars , Free Stuff and 4 others
I don't understand your comment in your first post - 'oil pooling under rocker cover' do you mean the oil was not draining back to the engine sump from the top of the engine ?
- Hello from England!
I topped it up just over 2 weeks earlier 'chk oil level' light came on again. Must have been around 200 - 300 in that time before I put the extra 2 litres in begire I had to get rescued
mljicar joined the community
DrawingSeeker25 joined the community
I really don't like the sound of 'overheating warning and smoke from under hood' ! How many miles since last top up had it done to use more than 2 litres ?
The 1.4 16 84 ps
- Heater not working
Amundsen MIB2 Firmware Update
@pab567 hi mate I'm looking to update my system would you be able to point me in the right direction for this am I right in that I have to keep the new update on the 02**t or can I jump directly to the latest 0480t ? Thanks in advance for any help
Momodog joined the community
- Which all-season tyres are you running on your Octavia?
This one? https://www.instagram.com/superb_vrs3?mdxt=dWZic3NjbmVpYTJr
Rear Dashcam Cable Length?
I'm just about to order a F&R dashcam package. It comes with a 6m cable for the rear camera as standard but also offers longer cables of 8m or 10m (mid-size SUV or large SUV). What length cable have others used for the rear camera? I'm also wondering if I need to allow extra cable to route away from the DAB antenna? 🤔
Skoda Fabia 1.2TSI Monte Carlo 09/2011 - Electric Windows Fault
the lin-bus is shared for the MFSW too so if the linbus is interupted the button will not be working, and if the MFSW isn't communicating also the cruise control will stop working as a safety function
