  2. It was the bulbs. Thought it was something more serious as they both went at the same time.
  3. Went out to the car this afternoon to pick the kids up from school and the passenger side mirror didn’t unfold. Flicked the switch a few times and no joy. Tried gently pushing it as unlocking the car to see if it could help it and and it seems it doesn’t try to open up at all. It can be moved by hand but it’s not moving the motor, just moving it off its position. If that makes sense. Anyone had anything similar or is it terminal?
  4. As far as I know (not a Fabia owner) the numbers relate to the number of unread messages that you have received on your phone since it was connected to the car (eg Whatsapp or text).
  5. Anyone have any idea what the numbers mean in the photos below? Obviously the blue symbol indicates Bluetooth but why the two numbers 1 and 2 in the other photos? The Bluetooth symbol and the others appear seemingly random regardless of what the phone is doing. There is only one phone linked to the car and most of the time it is just sat in the cubby hole or my coat pocket. There's nothing in the manual to indicate the difference, and it's pointless trying to ask the dealer! FP
  6. Today
  7. I have had mine out a few times now after changing the bulbs for various reasons, and they seem to come out quite easily now. I think once you have removed it once, it tthey are much easier from then on. I hope you like the bulbs and it was worth the effort!
  8. HI All, 2 fault codes picked up on my car, not effecting any driving or performance P2002 "Particulate filter efficiency below threshold" and P0474 Exhaust Pressure sensor A Circuit Intermittent/Erratic. From what I have been advised it can be one of 3 sensors. Car has passed all emission tests and runs like a dream even with 220K on the clock, ad blu has been bypassed. Before I go through swapping the sensors 1 by 1 to find its the last one and spend too much doing so, would any of you legends know which sensor is more than likely to cause these errors and bring the engine warning light on. Thanks all Dan
  9. Hiya, new poster here. Just back from getting my car looked at, I had an occasional yellow engine light and rough idle at cold, garage has identified play in the axial bearing. According to their source in a Skoda dealership, it's a new engine job - is this right? TIA
  10. SecretSam joined the community
  11. Thanks @k00ks , appreciate your help! @CrazySkoda @varooom @andreiro221 I've investigated the firmware packages further and found something interesting: Both 0469 and 1800 have exactly the same Variant (FM3-E2-*-*-SK-MQB-PA-*) in their main.mnf manifests. Both also have identical BlockedTrains lists, which don't include my current MEN3_EU_SK370_P9305P. The 1800 emmc_device manifest doesn't explicitly restrict HW 033 either. This suggests the P/L suffix doesn't necessarily indicate hardware compatibility, although matching manifests alone don't guarantee a safe update. Has anyone successfully upgraded an HW 033 unit to 1790/1798/1800? I'd particularly appreciate confirmation before risking my infotainment unit. My main objective is fixing Android Auto connectivity with my Samsung Galaxy S23+. Thanks.
  12. I have a Superb with the same issue. It got really bad over the summer and I booked it in with the dealer a week ago. The night before I gave it a quick wash at the local jet wash. That stopped it creaking! So the dealer had nothing to go on. They dismantled the door card and window regulator. Then reassembled,greasing the mating parts. So far it hasn't come back but it has rained a bit so I doubt the seal has dried out. I agree that it seems likely it comes from the felt seal at the top of the door. That would explain why hosing it down with the jet wash cures it. If it comes back I'll investigate some of anti squeak tape suck alopng the body where the felt rubs. I've seen this used on a BMW forum for a similar problem. https://f30.bimmerpost.com/forums/showthread/1210175/fix-annoying-door-creaking-bmw-3m-tape-solution https://www.babybmw.net/threads/creaking-doors-update-resolved.65299/
  13. @pervp Have a look at my last post. Godspeed!
  14. Cheers man. I have the swing/swing+ information screen So how easy is it to install this subwoofer? And what wires do I need?
  15. I'd echo @Nick_H's experience - brake discs and pads, shocks, springs and top mounts; and add the battery and air quality sensor. Read the fault codes if you can to pick up any hidden problems. I think the Superb is hard on the basic wear and tear parts because it uses Golf sized components on a much larger car.
  16. VelcroSubtextShawl joined the community
  17. Mine works fine for charging in both slots. Have noticed recently though that CarPlay seems to be disconnecting randomly when the phones in a charging slot. No issues when phone is in my pocket though. Strange one…
  18. Rear tailgate door struts, water pump ( on petrol dont know about diesel ), window regulator's, thing that breaks in gear selector, rear tailgate door latching mechanism, noisy front suspension. Think that's about it for mine ... 2015 Had since new now done 60k. Replaced the disks, springs and usual suspension wear and tear items about 18 months ago. Mate of mine did airport taxi runs his had done 150k with zero problems.
  19. Thanks for the additional instructions for the USB! Hi @k00ks , one last clarification: do you know if the firmware files you shared compatible with both HW 033 and HW 040, provided the SW Train is identical (MEN3_EU_SK370_P9305P)? Or are there hardware-specific firmware packages? I want to avoid bricking my HW 033 unit. Many Thanks!
  20. ian-inhome posted a topic in Skoda Karoq
    When I started the car this morning. It came up on the screen that there were 2 campaign messages.. I pressed the first one and I was told to scan the QR code that appeared then press ok. The same with the second message. Then the screen went to normal. Does anyone know what this is about . The only thing that I can see different is in the Skoda app you can click on smart home and generate a key. How you use it I don't know
  21. Jim1556 started following Potential new owner
  22. Hi all, I've been more than happy with my bought from new 2011 Octavia VRS TDI hatch, but it's now getting on a little at nearly 200k. So, I've placed a deposit on a 2024 VRS TSI estate as I no longer need a diesel. It's one of the last manuals built with only 16k on it. Any common problems I need to look out for? It's coming from a main dealer, so comes with 12 months warranty (unless I go the PCP route) but I hate finance - although it gives an extra £400 off so... Any advice appreciated! TIA.
  23. I was recently out of town and needed to get my vehicle diagnosed pretty urgently. My situation was a little different, though. I used an OBD scanner, and a technician was able to run the diagnostics remotely while I was sitting in the car. You can read more about how that works here: https://www.flexihub.com/remote-vehicle-diagnostics/ In your case, though, you’ll still need someone on-site to connect a laptop to the car
  24. i everyone, I own a 2025 Skoda Superb IV 1.5 TSI iV Plug-in Hybrid (L&K), and I'm experiencing some hesitation and jerking from the drivetrain. The issue seems to occur during low-speed driving, particularly when accelerating and when the car transitions between electric and petrol power. I've been researching this issue and found several reports from owners of the VW Passat, VW Tayron and Skoda Superb with the same 1.5 eHybrid powertrain. I also came across reports of a software update referred to as PV5, which reportedly resolved similar jerking issues for some VW owners. I'd like to ask: Does anyone with a 2025/2026 Superb 1.5 TSI iV experience similar hesitation or jerking? Has anyone had the PV5 software update installed? Did the update actually fix the problem? Has Skoda officially acknowledged this issue or issued a technical service bulletin (TSB/TPI)? Is there a specific software version or update that Superb owners should ask their dealerships about? I'm particularly interested in feedback from owners of the latest Superb IV 1.5 PHEV, rather than older Superb generations. I would really appreciate any feedback, especially from owners who have had this issue diagnosed or fixed by an authorised Skoda dealership. Thanks!
  25. luka2113 joined the community
  26. mauska joined the community
  27. I took my ill fitting R/H trim piece back off again today. It came off a lot easier the 2nd time around. Straight pull with two hands & gloves on did the trick. Seems one of the locating barbs had bent over preventing the trim from fully seating. I bent the barb gently back out & refitted it. It's fine now. As D402 said above, dropping the front underside tray is another option to get access from the back. Not easy scratching around on the floor trying to find all the retaining screws for the tray unless the car is jacked up or on a ramp but, it's doable as an alternative option.
  28. Hi Stevio and welcome.
  29. minsy started following Hello from Sydney!
  30. I'm wondering if anyone can point me in the right direction. Airbag light is on the dash. cleared it but it comes straight back. research so far has pointed me towards checking the wiring where it goes through the rubber boot in the door opening. I've looked in there and I can't see anything obvious. however it's so tight that even if something was broken I cant imagine getting enough slack to solder in a new bit. many thanks.
  31. A 70 mph pheasant impact did the removal stage for me 😬 I think it might help to remove the undertray and access the clips from behind. If you need to replace the trim part, don't waste your money on aftermarket versions. The one I bought was a very poor fit and the chrome strip deteriorated quickly.
  32. mcwieger joined the community
  33. Every VAG car I've owned since 1999 has a permanently live 12V socket, which I find really useful for a coolbox. Apparently in non-UK vehicles the fuse can be moved to make the 12V socket ignition switched...
