What bulbs are fitted to the S3 & upgraded bulb recommendations
I’ll check the manuals see if there’s a list
I did see What I started writing down Just lazy lol
Error: selector lever...
Hello. Same issue. Got it booked into Maidstone Skoda for 12 Nov. I just wanted to check that you have not had the error message again after the fix?
AndrewK started following Error: selector lever...
New headlight cannot adjust the dipped up enough
2016 Fabia with the dome lense over the dipped beam bulb
2tite started following New headlight cannot adjust the dipped up enough
Help needed The led DRL on my right drivers side head light failed as the headlight sprung a leak at the seam between lense and plastic case next to the wing Bought new skoda headlight from skoda dealer and fitted it but the dipped beam is just far to low Odd but the nylon adjuster looked as though some tool had already been on it so I was suspicious The main beam was ok with a tweak to its adjuster which was in perfect order I have rotated the dipped adjuster until i feel resistance. ( anti clockwise was lifting beam seemed odd direction as main was clockwise to lift ?) but it dipped beam still pointing down onto road and far lower than than it should be
Oil pressure regulation valve P164E00
Hi I am about to do the same with my one as I have the very same code on my car now . Ordered the plug with wiring just in case my ones are broken to replace them as I am there and now looking for the valve itself. Can you still get them oem valves ? Really appreciate your time here sharing all the info you have and experience 😀 Thank you!
myxailcho started following Oil pressure regulation valve P164E00
Front wiper blades on 2026 SEL
This 1-year-old topic may be of interest https://www.briskoda.net/forums/topic/536354-wipers-very-noisy/#comment-5981475
the first few posts on this thread lists nearly all of them
Mostly... 😐
zzeelljjkkoo started following Front wiper blades on 2026 SEL
octavia mild hybrid generator belt sound
Hello, I’d like to bring up an old thread of mine again. Does anyone have any ideas regarding my issue? It seems that the authorized service center doesn't even know what to do or suggest—according to them, everything is fine. The sound in the link occurs almost every morning, or during the day after the car has been sitting for a while. Lately, it has also been happening after long drives. The sound appears when the car is rolling in 'D' (Drive) gear, or when starting to move in 'D' without pressing the accelerator pedal. As soon as the car comes to a stop, the sound disappears. They replaced the belt tensioner this week, but it didn't help. Also, besides this sound, there is some jerking when accelerating. Thanks for your thoughts. https://youtube.com/shorts/4iBDhxFsDdc?feature=shared
Crikey are the OE front wiper blades this noisy on all Fabia’s?
DaveP61 started following Front wiper blades on 2026 SEL
Skoda News
Skoda 3D printable accessories https://www.skoda-storyboard.com/en/skoda-world/printly-clever-custom-accessories-you-can-3d-print-yourselves/ 'The world beneath the upholstery' https://www.skoda-storyboard.com/en/skoda-world/the-world-beneath-the-upholstery/
Firmware Request MST2_EU_SK_ZR_P0480T
Should I perform an update for the software, or should I continue using it as is?
Is there an explanatory video?
Firmware 0480 Only Install when the unit is patched, you need modify Meta File and Audio Channel Change Side, After Update left is right
There’s a full list of bulbs to be replaced to LED I started writing down each bulb and location - but was taking ages And wondered if there was a list or do I need to keep going 😂
RogueWagon started following What bulbs are fitted to the S3 & upgraded bulb recommendations
- Skoda Superb II - Total Ignition Dead (No Terminal 15) After Alternator & Battery Replacement - Out of Ideas!
mateiapostoiu joined the community
Matus22 joined the community
2015 skoda roomster brake lock up
It could be that the brake pedal hasn't returned fully. Try and lift it with your toe. Also check reservoir isnt full to the brim. Only other thing I can think of is ABS unit. It may require vcds or similar to bleed if air got in while changing calipers. As its all four wheels I reckon its trapped hydraulic pressure somewhere between master and ABS. Alasdair
Alasdair1 started following 2015 skoda roomster brake lock up
Dual Tailgate
Hi Only the boot (half) of my 2013 Superb opens.Is it possible to open the full hatch manually to examine the wiring in the hinged area. What does the Torx Bolt pictured do?
jjtone started following Dual Tailgate
I have just fitted new front dics calipers and pads to my 2015 skoda roomster 1.2 tsi with 35000 miles the items were replaced as brakes had seized on 1 wheel following a successful mot/nct test a d 1 front disc had been fried so to speak after fitting new brakes and bleeding system all 4 wheels are locked any ideas
Liamkel started following 2015 skoda roomster brake lock up
Bulb failure warning
Yes Sir, Mr. Thread Revival.
Dog hair & Cowboys - new boot trims
So when I collected my car Smelt of dog constantly Detailer says they have painted over the dog hair with black spray paint While he will do his best to get a lot of it off Is there part numbers for new side pieces, maybe bottom carpets and back of the seats? This is what I’m faced with So might just replace Part numbers and pieces be perfect for all rear pieces Estate
Daturon joined the community
VRS brakes on a 1.2/12v HTP
Thank you for the detailed study.
To be fair, it's always been a requirement for drivers to check their vehicle. The Highway Code states: Checks you should carry out Every time you drive you should check: the windscreen, windows and mirrors are clean all lights work the brakes work It's our laziness that encourages reliance on the car's electronics, but are they always right. There are now street legal LED retro fit bulbs that can still be seen as failed by some ECU's (older I suspect) that can be fooled by a resistor pack (Osram do all of this). NOTE: Unsurprisingly, the UK is behind the majority of European countries in granting LED retro fit bulbs type approval 🙄 All 'coding out' bulb failure means is doing checks as per the Highway Code 🙂
