Dashcam
I have a 2025 diesel Kodiaq Mk ll. I have never had a dashcam in any of my cars but thinking of getting a front facing one. Any recommendations of make and model would be welcome. Thanks.
Amundsen MIB2 Firmware Update
Is there a new firmware availabl for the skoda kodiaq? Device Part number: 565035864 Hardware: H41 Software: 0480 Thanks Andreas
Misty Headlight
Yep, 2 round rubber covers, one about 3 inches across and 2 inches.
Firmware Request MST2_EU_SK_ZR_P0480T
Sent
Crank but no start 2.0TDi
I would have said 500-1000rpm was pretty fast for just cranking. Wonder if the crank or cam position sensor has failed. Reckon a scan with vcds or similar might be in order. The brake manoeuvring unavailable may be down to the long cranking and voltage drop. As said see if there are any fault codes stored. Alasdair
Alasdair1 started following Crank but no start 2.0TDi
Hi, @pab567 can you also PM the link to MST2_EU_SK_ZR_P0480T please? Looking to upgrade from MST2_EU_SK_ZR_P0468T Cheers,
lilion started following Firmware Request MST2_EU_SK_ZR_P0480T
Returning member in the Czech Republic
Hi, I bought my first Skoda and signed up here on Briskoda back in 2009. I was so impressed with the car I moved to the Czech Republic (ok not real reason 🙂 ) Now back in ownership with a Mk3 Octavia RS tdi.
modra_vrs started following Returning member in the Czech Republic
DCC Slider adjustment option mod
They're different beasts; Superb is larger MQB-B chassis; longer and heavier. The car isn't a hot hatch and is a Passat equivalent so better at motorway munching with much better interior space. Whiteline rear arb is good - hopefully on the stiffest setting. I found although the droplinks weren't necessary, you can notice the firmer bushes based in uprated ones.
Who needs a sports car?
I don’t NEED a sports car, but i’m so glad I have my 1979 MG Midget, the antidote to modern all-singing all-dancing cars… 😎
Baxlin started following Who needs a sports car?
So I tried to start my 2.0TDI crmb engine this morning and I had crank with some spluttering but no start. I've had this a few weeks ago but after a few cranks got it going, but today no luck. It's cranking between 500-1000rpm, glow plug light is off and after failing to crank i getting brake manoeuvring unavailable. I have a new battery replaced on Thursday and coded correctly, tested it and it was showing at 12.4v. Any ideas on what it might be? Anything to test?
CianKT started following Crank but no start 2.0TDi
Misty Headlight
I have had a look. Sorry, but what do you mean by the rear of the unit? Are the rubber covers where you change the bulbs?
G@J joined the community
1.5 Tsi Power Cutting Out
You won't get any action from the dealer, they'll deny knowledge of a problem. Report it as a safety issue to the DVSA as I suggested above
235/40/18 Tyres on 8.5" wheel - Mk3 Estate
Good morning all - I promise I have tried but I am loosing the will to live with the search as it is such a common string - The problem is I am trying to research going for a wider tyre on our car with a wider wheel but same size (18) We have the standard alloys at present on our estate - these are 18x7.5 I think - the standard 18's that come on a 2014 VRS estate - they come with a 225/40/18. The car is presently in having some serious maintenance done so not seen it for good few weeks... new subframe rear, B12 Kit, new Turbo, DMF, Clutch and we have owned this car from almost new and the wife loves it... Can't really fault it or the 120+ K she has done in it but.... Wheels.... We are considering a set of the old Ronal A8 18's - What I am after is anyone that has run a 235 width on the mk3.. I hoping going for a 235 would give her a little protection from curbs as the same alloys I have seen with 225 seem a little stretched to me and I think she'd be gutted first time she curbed them with any stretch... Will 235's catch the inner arch/strut is my concern? I suspect rears be fine but looking for any experience with 235's on the mk3.. I am presuming everything else will clear as the Ronal's an very similar to present setup but offset I think will push the wheels out a tad and with the small drop from the Eibach setup but I did not think this would be an issue.... things that concern we are arch scrub loaded up or inner arch liner/interferance... 235 V stretch 225 - We already have the 225's on standard rims but can't help thinking the stretch will catch her out is all.... prob over thinking it but never seen an Mk3 running the old school Ronal's which makes me thing there are issues but these are 18.8x5 112x5 Et 45 - the original fat fives as I know them. Anyone any advise, experience or know anyone that runs these on anything in the VAG MQB range and can feedback around interference or work needed.. Have a good, Bobby
No such issues with mine. All seems to work fine
Misty Headlight
That's great advice, thanks. I will take a look.
Google maps error / Android Auto, My Skoda
To me this sound more of a phone issue then the car, is google maps and the phone OS up to date, am guessing that you are using wireless are the moment, have you tested it using a usb cable, as that would rule out any wireless interference issue. My guess would be if its suddleing stopped working, is the phone had done an app update that has a bug in it and causing something on the phone to crash, what modal phone are you using.
MonkeyBoy2283 started following Google maps error / Android Auto, My Skoda
Misty Headlight
I second the above - my daughters suffered similar misting of the nearside unit on a 2017. I found run off from the bonnet was falling straight on to the indicator bulb holder so used some silicon grease on that to prevent ingress there, ran PTFE tape over the top of the headlight at the joint between the 'glass' and rear section and also used some duck tape to direct water run off from the bonnet away from the indicator bulb holder. No more problems since.
Flo96 joined the community
- Bolero firmware update request – 5Q0035840B, MST2_EU_SK_ZR_P0353T to P0369T
Misty Headlight
The seal along the join between front and rear of unit has probably failed. It did on one of mine so I ran a bead of clear sealant along the join and ran my finger along to smooth it out. Job done. However it may not be needed. On the rear of the unit there are 2 rubber covers. Pop them off, leave it for a few hours and it will clear itself. That may sort it or you can use a hair drier blowing through the openings which will speed things up. Have a look at the rubber covers as they may be damaged or not sitting around the opening properly.
I do too, they have a weird side effect that the electrics don't shut down properly when you switch the ignition off if any of the other interior lights are turned on!
fffffff32 joined the community
I just asked for a diagnostic for this intermittent cut out at traffic lights and slow revs but was told they want £150 pounds to check it the car is still under warranty and has had this fault from new they originally tested it and said no fault found.
Oil cap problem
Are this covers aftermarket good? Febi?
Kodiaq steering wheel vibration
Now it is time to Check you tires. Go to road hunter test. Test ocour road force in simulation with load. IF the road force were under 60 niutons it should be ok. But tire technican Can optymalize set of tire in realiom to wheel ring. I had to throw away 2 tires because road force was ocet 100 niutons
Yeah, I meassured dimension on every wheels, Its aproximetely 0,2mm difference between center and wheel - OEM. Orginal bolt are spherical, thats why it centre by this surface not by the center hub. I used insulatoon tape 0,13, in my opinion, vibration still exist. Of course you have right, 0,2mm its too much.
These ones. Had no issues. The black trim needed a tiny fettle for them to install perfectly but otherwise have been perfect. I just found this on AliExpress: https://a.aliexpress.com/_EJBESM6
