the truth about electric cars
GevaarlijkeGek joined the community
danidani joined the community
Skoda Octavia MK3 Greenline III (1.6 TDI) - cambelt interval
Hi all, Just wondering what the cambelt interval on a 1.6 Greenline III is. I’m seeing conflicting information online. I’ve just bought my old Octavia back and the belt was done before I originally bought it in 2020 at 90,000ish miles. The car has now done 140,000 miles so I’m guessing it’s overdue? It’s been owned by a family member so I know the car hasn’t had the belt done during their ownership. Looking to get it booked in if it is actually due, but just wanted to make sure it definitely is before I shell out. Also what’s the going rate for a cambelt & water pump change at an indie currently?
Toby7243 started following Skoda Octavia MK3 Greenline III (1.6 TDI) - cambelt interval
Amundsen MIB2 Firmware Update
Hello, I feel I am late to the party and haven't updated my firmware since 2017. I believe I am after MST2_EU_SK_ZR_P0480T - (currently on P0468T). Can someone help point me to where I might find it? Thank you.
Rocketeer125 started following Amundsen MIB2 Firmware Update
CD PLAYER
Does the SD card fit in the extra slot in the glovebox unit? I'm a bit of a Luddite when it comes to electonickery, give me an engine to work on any day! Thanks, that looks the very dab.
CD PLAYER
Something like this means you can rip your CDs easily. https://amzn.eu/d/0iICC1YP
- Engine cover
thelee79 joined the community
- 38 mph in 5th gear ?
Skoda News
https://www.skoda-storyboard.com/en/skoda-world/what-was-racing-like-half-a-century-ago-skoda-120-s-rallye-delights-a-champion/
Engine cover
Top Cowling 1.2HTP Škoda 03E103929A ? Need VIN to check properly, but that's what comes up for 2012 CGPA engine. Maybe it had something non-original on it before, if that doesn't look like what you expect. I will message you to ask for VIN. Dirt on the outside of the engine doesn't matter, clean oil inside is much more important
- Engine cover
CD PLAYER
Thanks Dave, that's what I was afraid might be the answer. The problem I have is that my new DELL laptop doesn't have a CD/DVD player built in so unless I can find an inexpensive CD player to plug in, I am stuck with what I have.
- Engine cover
Tomas525 joined the community
- Engine cover
Miastubb started following Engine cover
- Elroq tailgate won't stay closed
Fuel Leak!
Has anyone managed to get a goodwill payment for this fault? My Leon 1.4TSI broke down a couple of weeks ago, fuel leak from the fuel rail, 1 bolt ‘missing’ and others loose. 3rd party warranty would not pay out because it was a bolt issue and bolts aren’t covered!
Shamblerc started following Fuel Leak!
Shamblerc joined the community
Miastubb joined the community
1.9 TDi Timing belt kits
Found similar in cluch kits Bought an LUK kit and it had a valeo clutch disc. I would have thought that as INA are a premium bearing manufacturer they would use their own unless they also now make them for Gates and you got one branded for Gates . Reckon a lot of companies supply each other with parts and are rebranded to suit Alasdair
Chinese rear differential
As with everything, if you know what you’re buying, you’re probably going to get a great deal. If you don’t, then sometimes it’s best to err on the side of caution. As said, the same factory can product different qualities (and, often, you’ll find that the lower quality items end up as different brands - take Hisense and LG, for example). @Cairus I meant to tag you, but clearly don’t seem to have managed it!
CD PLAYER
Been asked several times on here, answer is always the same - this generation of infotainment systems doesn't support a CD player or changer. You need to rip your CDs and copy the MP3 files onto an SD card.
LewisADJ started following Digital Cockpit Display Error
I have a digital cockpit display in my Kodiaq. Part number 565 920 790 C It’s recently turned off mid journey and only comes back on intermittently. There’s not actually anything wrong with the display, it just won’t stay on. It’s just the screen too, the petrol and temp lights are fine, as are the warning symbols. I’m just left with a blank screen and a red warning light. After an extensive search the only solutions for a fix I’ve found are to pull fuse 17, disconnect the battery and reset the infotainment system. All 3 of those haven’t worked. I took it for a VCDS scan which showed a fault (see attached image). Has anyone else had this issue? It’s booked in to have the software / firmware updated this week as a last resort before I have to look at replacing (£2500+) Any advice appreciated
CD PLAYER
Bump to this question.
Engine mount bolts?
As @Breezy_Pete says it's a term that refers to the properties of the material. Most materials are linear in that they stretch as a result of a load but when that load is removed they return to Thier original length. That's termed 'elastic' deformation and is a linear relationship that can be measured and is referred to as 'Youngs Modulus'. However they also have a point at the top of that linear relationship, called a 'yield point' and if they are loaded or stretched beyond that point they don't return to thier original length and the load remains constant and doesn't increase if lengthened further until fast fracture occurs and the material breaks. This characteristic beyond the Yield point but before fracture is termed 'plastic' deformation. It's made use of in in stretch bolts to provide an accurate loading. Usually there is a slight drop in strength below the Yield point that can be felt, so if you torque a bolt to it's Yield point and beyond you feel it almost 'give' a bit. (Guess who's studied materials and fast fracture mechanics 🤣)
LewisADJ joined the community
Engine mount bolts?
That's the technical term for causing a screw or bolt to stretch to the point that it doesn't return to original length when undone (elastic region is everything before that). It's actually fairly easy to feel when (if ever) this happens. You continue to turn the head but without any increase in effort like there normally is. Weird feeling. Rare on cars, even on headgasket bolts.
@lol-lol While you made some good points, I did, however, say that at the current time their decisions are indefensible. We don't have the transition to electric, and we will be dependent on other fuels for some years to come, and we have zero plan to cope. Our gas reserve and storage facility has gone, and so have all the sources we had.
