Past hour
- S3 owners - electric tailgate / hatch closing from inside
enoktakenokta started following ADAS Calibration
ADAS Calibration
Hi. My car’s steering box was replaced by the service. I know that if steering box is replaced calibration should be done. But the tech said that there is no need to claibrate. Can you tell me whether calibration should be done or not. If needed which procedure should be applied that is to say static calibration or dynamic calibration?
Coolant warning again
I've had toyota and hyundai hybrids in the past and don't remember a sealed system before, but then again I may not have need to have looked,I wouldn't attempt to completely refill the system but a simple top up was easy
Welcome to the forum. I fail to understand VAGs logic in sealing the engine coolant expansion vessel - I can (sort of) understand it if it was for the sealed battery cooling system on a full EV, where there could be a significant fire or explosion risk from an overheating traction battery. Does the much smaller traction battery of a Hybrid use the IC engine cooling circuit for cooling ?
Warrior193 started following Coolant warning again
Phone symbols on infotainment screen.
Thanks @skomaz but it's not that, as the numbers appear even when there are no unread messages. Sometimes it shows the Bluetooth symbol but the most common is the digit 1. The digit 2 is the one that's seen the least. Baffling. FP
Skoda Kamiq Dashcam – Don’t make my mistake!
As Petrol Dave says you can swap the ign/live feed even on OK cars, but a dash cam will not drain a car battery if it is fully charged, either put a charger on it or have a 50 mile or so drive to charge it
Today
Adjutant joined the community
- 1.5TSI Axial bearing (2018 car)
daveo138 started following 1.5TSI Axial bearing (2018 car)
Passenger side mirror won’t unfold
There’s two different fuses depending on side of car, but yeah it’s not that unfortunately
I have seen this before. It seems to be very hit and miss for coding this. I tried exactly the same as I did on @AL2772 's car using my module and app and it just kept saying bad OBD2 module. I think it is very dependent on your OEM dataset version. Does carscanner and your module work for other coding ok?
- Radio stations Logos database updates
JStyles joined the community
L&K Front Fog light Bulb access?
I installed Bevinsee LED headlight bulbs to replace the bixenons and they are great. Passed MOT no issue too. Highly recommend them. https://www.ebay.co.uk/itm/298188805629 £28 a set with the coupon code currently. But both sides you have to jack up car, take wheel off and arch liner out to get to them. I managed to get one bulb out from above but couldnt get the new one back in.
Hello @Gizmo Will it be the only one able to sort coding? Any links recommendation please? My 2 obd2 not able to do and showing faulty wondering cos car not able to do no matter what as showings my diagnostic tool faulty Please read my new respond in here Are you able if so change dataset and what with?
Yep I would concur with that. The new fog bulbs are looking much more like the main beams now, if not a bit brighter / whiter. Close up inspection of the original Bi-Xenon main headlight inner lenses shows that they do look a bit cloudy. Need a clean perhaps? I'm wondering whether I should consider changing the Bi-Xenon's for LED's or, leave well alone? Looks like changing the drivers side is fairly straight forward but the passenger side involves removing front wheel & wheel arch liner to get to the back of the headlamp unit as under bonnet access is very tight😒. I think I will leave alone until the weather gets a bit warmer. Not the time of year to be messing about in the cold on my drive.🥶 For reference below is a Ali Express link for the replacement Fog LED bulbs I used. Fairly cheap at £9 but so far so good. The car is in for it's 8th MOT today @71.5k🤞 https://www.aliexpress.com/item/1005006840794986.html?spm=a2g0o.tm1000027143.appPushSupportRecommend.3.71cc6a77QFScA6&gps-id=appPushSupportRecommend&scm=1007.67346.516855.0&scm_id=1007.67346.516855.0&scm-url=1007.67346.516855.0&pvid=0fd4b796-753d-4d2d-8e4d-cf5800ec5718&_t=gps-id%3AappPushSupportRecommend%2Cscm-url%3A1007.67346.516855.0%2Cpvid%3A0fd4b796-753d-4d2d-8e4d-cf5800ec5718%2Ctpp_buckets%3A668%232846%238110%231995&pdp_ext_f=%7B%22order%22%3A%2271%22%2C%22eval%22%3A%221%22%2C%22sceneId%22%3A%2257346%22%2C%22fromPage%22%3A%22recommend%22%7D&pdp_npi=6%40dis%21GBP%218.13%218.13%21%21%2110.37%2110.37%21%402103849717951015968395942e0ef6%2112000038479188887%21rec%21UK%213413154159%21XZ%211%210%21n_tag%3A-29919%3Bd%3Addd822d5%3Bm03_new_user%3A-29895&utparam-url=scene%3AappPushSupportRecommend%7Cquery_from%3A%7Cx_object_id%3A1005006840794986%7C_p_origin_prod%3A
Doesn't dim as its been replaced with standard glass when I broke it but will give the heating a go. The puddle light that side still works. Will try the adjustment too. I would have thought if it was fuse would both mirrors be affected?
Hello So I have tried many times yesterday Don’t work at all. My control module is 5Q0959107L I got obd2 as follow Vgate vLinker MC+ Bluetooth 4.0 OBD2 Car Diagnostic Scanner Also MUCAR BT200 Max Automotive OBD2 Code Reader Lifetime Free AI Diagnostic Scanner also vcds I know vcds won’t work But with above every time try do something saying’s that my obd2 are faulty They are genuine btw. Also im using car scanner pro ( paid for full version) Anyone able please direct me in the right direction? I have read all 9 pages but would love someone go through again perhaps some more new updates etc Thank you in advance
Tom1214u started following Hello and help needed already 😂 and S3 owners - electric tailgate / hatch closing from inside
A VW Group Global Recall 2026.
today I received a letter from VAG Croatia, regarding the replacement of one bolt of the steering rack. I won't go now because many rushed to the service stations and created crowds because they think their steering wheel will fall off. when the situation calms down, I will go. in our country, insurance companies supervise this service action and it is changed on literally every car on these platforms, because in the event of a collision, an accident or a bolt breaking, great damage and life-threatening damage can occur, so the action is not optional but mandatory. or your insurance will not pay compensation if they estimate that the bolt is to blame for anything. I translated it into Eng.
Shine a torch at the interior mirror, is it wing still dimming? Could also try heated function too Just wondering if motor is dying and it’s tripped a fuse or so Edit: Just checked and that’s fuse 39, looks like if that went you’d have issues with central looking on passenger side Still be worth checking the dimming and heating works though, does the mirror movement still work? If all good guess it’s just the motors had enough Must admit mine sounds a bit “dry” sometimes like it needs more lube, but never bothered to look
Headlights out ( dipped. & Main beam ) fuse and bulbs OK !!!
It was the bulbs. Thought it was something more serious as they both went at the same time.
Hello everyone Would like introduce myself and say hello everyone. Based Hereford Vag man Skoda Superb MK3 Estate 2016 2.0Tdi 190bhp Dsg DQ250 As you can imagine this car it’s absolutely Superb
Binx1310 started following Passenger side mirror won’t unfold
Went out to the car this afternoon to pick the kids up from school and the passenger side mirror didn’t unfold. Flicked the switch a few times and no joy. Tried gently pushing it as unlocking the car to see if it could help it and and it seems it doesn’t try to open up at all. It can be moved by hand but it’s not moving the motor, just moving it off its position. If that makes sense. Anyone had anything similar or is it terminal?
Red 2017 Skoda Superb Sportline TDI DSG hatchback
As far as I know (not a Fabia owner) the numbers relate to the number of unread messages that you have received on your phone since it was connected to the car (eg Whatsapp or text).
JD52 started following 1.5TSI Axial bearing (2018 car)
Anyone have any idea what the numbers mean in the photos below? Obviously the blue symbol indicates Bluetooth but why the two numbers 1 and 2 in the other photos? The Bluetooth symbol and the others appear seemingly random regardless of what the phone is doing. There is only one phone linked to the car and most of the time it is just sat in the cubby hole or my coat pocket. There's nothing in the manual to indicate the difference, and it's pointless trying to ask the dealer! FP
FabiaPilot started following Phone symbols on infotainment screen.
I have had mine out a few times now after changing the bulbs for various reasons, and they seem to come out quite easily now. I think once you have removed it once, it tthey are much easier from then on. I hope you like the bulbs and it was worth the effort!
