  2. Your ABS Wheel speed sensors could be dirty and or broken. Your tires made of harder rubber depending on make and type. Tyres over inflated for the weight of the car. Driving skills? And I don't mean this rudely. If you know the car is powerful enough to spin off the line. Learn to get off the line and immediately short shift to second. Or get accustomed to pulling away cautiously. Does the car do it in the dry, or the wet? Do you have the habit of stamping on the throttle. The car can't change what it does. But the driver can adapt to make sure the car behaves. Its all about experience.
  3. Yes, I have a rear camera and it is clean and working normally.
  4. Today
  5. Graemed15 joined the community
  6. Hello, this is my first post :) I write question about pre-facelift fabia. Is it possible to fit original monte carlo parts to stock fabia? I saw that diffuser fit, but I can't find any information about rest of parts.
  7. Park Distance Control: please clean rear sensors - 2022 Octavia 1.4TSI iV Hi, I am getting this message on the display and NONE of my rear parking sensors are now working. The front sensors are working fine. The scanner fault code is B107B or 13959168 rear parking sensor ice, dirt or environmental influence. It does not appear to be an issue with an individual sensor, if I disconnect any one of the rear sensors the scanner will identify that sensor as being disconnected. I have disconnected and reconnected the battery in the hope it might reset it but no joy. Any idea what my issue is or how I might go about further fault finding it.
  8. Welcome to the forum. What tyres does it have on? Are the tyre pressures correct?
  9. Does vnci 6154 work the same? They’re much cheaper than vas https://www.obd2shop.co.uk/wholesale/vnci-6154a-vag-diagnostic-tool.html?gad_source=1&gad_campaignid=22158049574&gbraid=0AAAAA-tYH4gLXtC0uR2X3OZAFbsqtiakj&gclid=CjwKCAiAlKrYBhBuEiwA4o3xo5msqzdEwPAsN_ww26PdRsjXXdyX_6CI-9_YfBl8LcpqZZGR-IcBlBoCpWwQAvD_BwE
  10. Ok, understandt… regret being so far away from Austria…
  11. Thank you. Does that mean it would work in another car if it had a similar spec or it needs the data from VCDS(?) and sending back to you for it recoding?
  12. Uffe joined the community
  13. Scooch joined the community
  14. Fuse checked same time as the bulbs - all good. Thanks for the fuse layout file. Found hatboyharvey YouTube for lower dash removal. Will attempt fix when weather is better- no garage, ☹️. Thanks again for your help, Richard
  15. @TerryJP Odd that it comes on almost every time and not 'every time'. It musty be broken 2 or is that 3 ways. Coming on at low speed and not being able to disable. Then not always coming on. They do typically activate around 60 km/h / 37-40 mph. Ask Skoda Customer services chat bot and see what the A! tells you.
  16. I might sound like a bit of a killjoy, but I'm inclined to agree.. I called it a day with diesels earlier this year as a result of one problem after another. I've closely watched what was then a 20P per litre gap above Petrol open up to more like 30P in just this year. That gap is manufactured (IMO) and won't be closing at anytime soon.
  17. I have a VW UP 2023 that has lane assist. I do have a switch for lane assist that defaults to on at every start up. I managed to program the car for it to remember the last position the button was in at the next start up. So if left it off, it stayed off, until I wanted to turn it on again. I used OBDEleven. I don't know if there is an option for it to do it with your car. Thanks. AG Falco
  18. Oh, OK, not a mk2 then. I wondered about the mismatch between car in profile versus subforum you posted in. Doesn't matter. In that case check cabin fuse number 2 first, layout image and table in attached file. Access to the brake light switch requires lower dash trim removal on mk1, I think, which is a bit of a faff. Mk1 Fabia Cabin Fuses.pdf
  19. Thanks for that, further food for thought! Yes, they're labelled 12V 27W, so should draw 2.25A and R should be 5.33 if the elements are ok.
  20. Hello Breezy_Pete, Thank you for your quick response. Fabia is 2004, estate version. Retired to Ireland ( profile just updated!). Will find some more info on switch on brake pedal. Had a quick look at the bellows wiring - all seemed fine, but will investigate more thoroughly. ( Not required for the MOT I believe). Kind regards, Richard
  21. Hello everyone , in 2019, I bought a brand-new Skoda Rapid Spaceback. After nine years, it’s time for a change. 😢 My dear fellow is now making way for a new 1 1/2 years old Skoda Scala. 😁 I am currently having an issue with the Rapid’s infotainment system, which I would like to get fixed before selling the car.
  22. I don't have any experience of diesel addtives. IMO, as has been mentioned in this thread the correct VAG has been more than adequate for all all of my Diesel Skodas thus far (I've since switched to Petrol).... I guess the bigger questions are how many miles has your vehicle done? and how frequent/consistent has the servicing been up until the point when you purchased? I'm sure that you chose a great example, but if for whatever reason the oil servicing has been patchy then I;m not sure that an aditive wil make up for that. Each to their own though - I hope it works for you.
  23. The speed control is what differs. Manual 4-speed cars use a resistor pack, Climatronic an electronic regulator, so match any replacement to your system. Before doing the access work, check the blower fuse and 12V at the motor plug. Dead on all speeds is usually supply or a seized motor.
  24. What year is your mk2? Whereabouts in Berkshire are you? May be a failure of the brake light switch on the brake pedal, plus a broken wire in the bellows between rear hatch and body for the high level one.
  25. Nearly 10 years on from my first post, I have today parted with my Roomster. Bought in January 2017, I traded it in today for a new Karoq 1.5Tsi Design Edition. 96,688 miles, mostly trouble free. Outlasted three other cars; a Volvo V70, a Discovery Sport and the Kodiaq mentioned in an earlier post. For the last 2 years it had been the everyday car. Thrashed mercilessly between Oxfordshire and Kent regularly and still easily turned in 60mpg. No idea what the future holds for GJ57 HLH, but if someone buys it through the auctions they will get a good little car. I was very sad to see it go and in many ways it has been the best car I have ever owned. Let’s see how I get on with the Karoq. We do still have a Roomster in the family though as my daughter runs a 1.2Tdi Greenline.
  26. On 8 October on @Sklinda's original enquiry about her car's behaviour, you asked her whether the car's motor was a TSI or MPI type. You asked again on 13 October and her reply was "It's an MPI". (And. of course, she said "mpi" in this topic's title.) I can't see any persuasive reason to think that @Sklinda's reply might be incorrect. But, if she has any doubts herself and has the vehicle's EC Certificate of Conformity, her car's motor's maximum net power will be shown at 27.1 on the Certificate's 2nd page and, if it has the MPI motor, the entry will read 59.00 at 6300 As the TSI motor has a turbocharger, there are visual differences between that motor and the MPI one - but I can't find any online images of the engine compartment of a Fabia Mk4 that has the MPI motor that could be used for easy identification purposes. Using' logic,' if @Sklinda's Fabia Mk4 has an a DSG automatic transmission or a 6-speed manual gearbox, then it must have a TSI motor. But, if it has a 5-speed manual gearbox, then it could have either a MPI or a TSI motor.
