Estate vRS 2.0 TSI 245 PS DSG - fluid change or not
lol..By all means, stick to what the dealers tell you. Any competent automatic transmission specialist will tell you when the fluid and filter need changing. You could change the fluid at 80,000 miles for the DQ381, but you can't see the actual condition of the fluid inside the transmission. It is madness to change the fluid without changing the filter; such fluid will likely damage the mechatronics unit, causing the transmission to jerk and making gear shifts unsmooth. The transmission normally shifts up after 1,800 RPM; if it is shifting at 1,900 or 2,000 RPM, you have likely already reached the 60,000-mile mark. This device changes the oil in 40 minutes; the housing allows you to see the oil change process and the condition of the oil being replaced. You buy a £30,000 car, yet you can't change the oil after four years.😇
2011 Octavia 2.0TDI 140 CFHC Fuel Filter Confusion
I remember there being a short and a longer housing and filters. Suggest measuring the housing length/dimensions to help you get the right part.
Armed with VIN, it appears to be the part number shown in the green box. The one below the green box is for the housing (3C0127400E) that is greyed out within the orange box of 'Pos. 1s', so I'm assuming that is not suitable for yours. No idea why your housing has a misleading part number label on it. Probably a 'subassembly' that doesn't exist in the spare parts catalogue. 3C0 127 434 filter element with gasket is a mere £41.15 + VAT from Skoda. 😆
Tow car of the year
How can it be tow car of the year when the only completely working towbar is the overly expensive fancy dancy one???
Car swap queries
We've sold our caravan and swapped our 2019 Karoq Edition 2.0 190PS 4X4 DSG for a 2020 Kamiq SE L 1.5 DSG. The Kamiq was from our local Skoda dealership and met our requirements by having: Reversing camera - to assist in reversing out of our drive. Variable boot floor - to allow the dog's crate to fit when the rear seat is down Heated front seats - for Mrs SDA's bad back Amazingly there was only one other Kamiq with that spec. on Autotrader and that was 200 miles away in Devon. We collected the Kamiq last Friday and there are several odd issues: Smell - the interior has a strong odour of white spirit that wasn't there when test driven. Missing floor mat - the driver's floor carpet mat is missing, though the other three are in place. There again I guess it gets the most wear. Missing lever - the driver's seat lumbar adjusting lever isn't there. The stub of the adjuster is there but no lever. The passenger side is OK. Missing tools - there is no spare wheel, but there is the foam tool kit tray which only contains a locking wheel nut and a jack winding handle. No jack, tyre compressor, tyre gunk or anything else. It would be good to know what it should have as standard.
Steamdrivenandy started following Car swap queries
- Fitting rear wheel arch liners - my experience
Hi Pete, Messaged you the Vin Thanks Nick
Message me with VIN, please Nick.
Would the 1.5 150hp Scala be a good highway cruiser?
also tried a 1.5 Monte Carlo trim, much sharper, but nearly 50% more on price for similar age
hi, I just moved from a Seat Leon FR130 to a Scala 150 SE with DSG The cars are about the same size externally, internally the Scala cabin is a bit smaller, but the boot is larger, which works for me. The controls are more reminiscent of my 2016 Leon FR 150, as is the power. Maybe the handling is'nt as sharp, but that's down to tyres mostly. The Scala is a softer ride and with D mode is an easy motorway cruiser. Price , a bit more than your budget, but not much, 6500 miles, <1 year ex demonstrator. Took me while to find it, still would have preferred a manual, but it seems they are no longer around
Headsup started following Would the 1.5 150hp Scala be a good highway cruiser?
Headsup joined the community
Hi folks, Can anyone advise which fuel filter is correct for my application? I’ve searched the usual parts places eg GSF, Opie, ECP, Parts in motion, Autodoc but not one of them tell me the exact fuel filter to use. I’ve done a little research it’s for my 2011 Octavia Mk2 2.0TDI 140 version with CFHC engine code. I’ve even noted the part number on the canister 1k0 127 399 CL but still can’t find any reference to which filter should be in the canister. I’m assuming the canister part number is superseded and the after market fuel filters are referencing the later number perhaps? Anyone help? TIA Nick
- Any luck with intermittent limp mode fault?
I sought help from citizens advice and write a letter describing the problems to the overall Company and setting out my rights and what the law requires. I received a reply saying that they will take the car, leave me with a courtesy car, and give the car a run around and basically sort out the problem....to we will see!!
- CarPlay crackling issue, software update fix?
fullerlee started following Fitting rear wheel arch liners - my experience
- New car
- New car
Official Briskoda Fabia II Monte Carlo Register
I forgot to add photo's.... Black 17" low profile tyres (not keen) 16" MK1 VRS wheels (better ride) at my age I find them smoother...
On a 21 plate the Corolla will only have 122hp with the 1.8 and gen 4 hybrid running gear. From 23 plate it’ll be much improved in many ways inc 140hp, gen 5 hybrid, better infotainment CarPlay etc… Do you have the Suzuki Swace in your country? - which is a Corolla TS in drag, frequently cheaper, better spec but didn’t have low profile tyres (quieter!). I find my 24 plate relaxed on a run , even on a motorway. It frequently drops to electric only - especially in roadworks. You don’t “hear “ the engine come and go. However the 1.5 engine is a lively beast in the Scala and should be pretty relaxed on a long run. Can’t comment re other noises.
Fabia 1,6 TDI (105bhp) Reg Date; 2013 (13) Colour; White Options; Amundsen satnav & Bluetooth, Mods; Changed to 5J 16" VRS wheels
Paul1001 started following Official Briskoda Fabia II Monte Carlo Register
feketediagnosztika joined the community
Octavia Scout Estate Larger Spoiler?
Welcome to the forum. Doesn't look bad actually - I rather like the bi-plane and extra 'kick up' look. I wonder if it actually helps to keep the rear window a bit clearer in rain?
Warrior193 started following Octavia Scout Estate Larger Spoiler?
Jaguar, will it survive?
The Jag is bold but that Alfa, wow. It'll look amazing on the back of a recovery truck
Car Shudders Various Lights Come On Goes Into Limp Mode
UPDATE: Car has been to the garage, they have replaced the crank sensor and asked me to see how it goes, I will keep you updated. Regards Tony
Firmware 6276 source
Hi at all, I found your forum because i have the same problem. I have to update with de swl file but i can´t find it. My unit ref is: 3C8 035 680 HW : h26 SW: 6270 Can you help me? thank you
