Roof bars and or Roof box.
Not for a Scala, but I got a set of Nordrive bars and 2 bike holders for my Octavia, from micksgarage, but I’m sure available elsewhere. Fully adjustable, and come with custom feet to match the curve of your car roof - specify the car model during the order and they supply the correct foot pack. Haven’t had any issue with any of it, and the bike rails even fit my thick framed mtb. Lot cheaper than a set of Thule bars, and not massively less aesthetically acceptable. Bit windy at motorway speeds, but overall fine
Fuel Tank Cap Replacement Seal
Thats one very strict MOT place. Glad I didnt put my old octavia in there. Alasdair
Alasdair1 started following Fuel Tank Cap Replacement Seal
Skoda News
https://www.skoda-storyboard.com/en/emobility/peaq-enters-production-sharing-the-line-with-the-octavia/
...But the system warnings should be inhibited if you reset the system at the lower pressures (within reason) you want to use.
Lower pressures could well be appropriate for snowy conditions, and, in any case will soon gain some pressure once you are running - I'd leave them as is and recheck at your first rest stop.
Consider using Steel-Wire Armoured Cable for the run.
6.1.3.(b)(i), apparently: MOT inspection manual: cars and passenger vehicles - 6. Body, structure and attachments - Guidance - GOV.UK
I confess to being very surprised that this seal was picked up on an MOT - was it flagging a fuel purge fault (MIL) on the instrument cluster?
Replied, but for the benefit of others who may be reading:- the seal ring part number is 1K0 201 557A, currently £11.55 + VAT from Skoda. Lots of offerings for less than half that price online from the aftermarket, and lets face it, Skoda didn't supply a particularly durable one when this car was built, so there may not be a strong case for staying genuine.
Firmware 6276 source
IMHO it's rather HW issue, not SW
I don't own the radio; I have it connected to a bench power supply here, so I can't test those specific functions. It has been running on the power supply for several days now. Unfortunately, the owner doesn't know the details either—since the radio wasn't really working, he didn't use it and just wants to get it fixed up. Do you think it could be a software issue?
Prins joined the community
Infotainment retrofitting
Hi, I have the following system details on my mkIII Octavia Elegance -- Device part #: 5E 003 587 4A Hardware: 040 Software: 0421 It has the smaller screen, MIB1, but not sure if it's Bolero, Amundsen or Columbus? I assume this has never been updated, but I don't get the download screen, as I don't have the maps SD card -- it just complains about not having a card. I'm getting a card off the Yorkshire bay -- by gum! How do I get the latest soft/firm ware? Maybe the software on the SD card will also need updating, regularly ...
zeta_91 started following Infotainment retrofitting
- Yesterday
Electric window
Okay started with both windows failing to open, it's been into Skoda three times with no positive lasting outcome. After the windows wouldn't open a Skoda employee forced them to shut and for a while they opened and closed but the glass could not be correctly placed on either side. Entering our garage I close the mirrors, sometimes when in a morning they will work and when selecting reverse the windows dip as had be programmed.Todsy everything stopped mirrors folded in but would not open left for 3/4 hours ignition on and mirrors opened but nothing worked, moved car onto garage locked mirrors wouldn't turn in locked and messy disarmed. Any solutions welcomed
Kodiaq memory seat coding?
Hi, Here are the codes on my LHD MY22 Kodiaq : Driver seat (Left side) : Address 36: Seat Mem. Drvr (J810) Labels:* None Part No SW: 3Q0 959 760 E HW: 3Q0 959 760 E Component: Sitzmemory H07 0026 Coding: 001000020000150081C280808180000000008181000000D440 Shop #: WSC 00033 790 00122 Passanger side (Right side) : Address 06: Seat Mem. Pass (J521) Labels:* None Part No SW: 3Q0 959 760 E HW: 3Q0 959 760 E Component: Sitzmemory H07 0026 Coding: 001000020000150081C080808180000000008181000000D400 Note: They are both fitted with massage function and have only 2 memory button.
- Electric window
- Electric window
Frank19 started following Electric window
Thanks for that information, most helpful. I'm going to have to wait a while if I want to try and tap into the mains as the ground is like concrete and impossible to dig with shovels or spades, so once we have a decent amount of rain that softens the ground I might be able to get our gardening team to dig a trench across the lawn about 12" deep so I can install a cable conduit (usually a heavy duty water pipe) and bury it in the trench up to a base of a redundant lamp post base, reuse that for a charger on a post.
VRS Mk1 crankcase ventilation system
Creation Motorsport are not far from me, but not sure if I like their catchcan kit- looks lie one of the cheap ones on ebay with some hose thrown into the deal (£67)
thanks bullet-guy! Yes this forum has supplied all the info I need to at least do the SAI, N249,N112 deltes and, if I get that far, then fit a catch can. Hopefully the piggyback sump plug will arrive tomorrow- until I've sorted that out, I'm not ordering £250 of parts. Everyone keeps telling me I'm crazy to attempt this, but I've had such a series of hassles from garages, it's down to me. Still don't know if i can start on the deletes and arrive at a point that allows me to drive the car- probably inadvisable. Cos it's likely to take a few days and I expect problems along the way I'll try not to ask too many questions - I expect a lot of the folks who have contributed to the 'Octavia Mk 1' sub-forum have moved onto other cars by now. The posts are over ten years old thanks for the help so far !
Pm'd
Photography Thread
- Disabling traffic attraction alerts
If you find that you need to do a lot of charging not at home then it may be worth knowing about Tesla's charging network. Many of their "supercharger" locations are open to all. Tesla cars pay a reduced rate per kWhr. Most locations are open to all and if you dont drive a Tesla you can buy a "subscription" to get the cheaper rate that Tesla cars pay..... From Duckduckgo ....
Gusm joined the community
Skoda UK Customer Support are useless!
Thanks for your very comprehensive reply Arianne. I use exactly the format and folder structure you describe above on a Samsung 256GB usb-c stick. Also tried with other makes of sticks and a 1TB external ssd. Well that was my last shot at fixing my media playback woes. I’m in the process of ordering the Honda Civic eHEV in Advanced trim. I love it’s driving characteristics, fuel economy and ergonomic control layout. It comes with an 8 year guarantee too. Not as luxurious as the Superb but I can live with that, I came back from my test drive with a huge smile on my face!
- Skoda Yeti Head unit clock 00:00
