Past hour
JPenedo joined the community
Today
S3's Virtual Cockpit
From China, the VC 😉... unfortunately, you bought an older software version; the Sportline visuals, etc., only arrived with "Index A" what i know... It is possible to perform an update via an SD card through the MIB2 unit—provided you have retrofitted the MOST connection—but I cannot offer any guarantees regarding this.
Cairus started following S3's Virtual Cockpit
2012 to 2019 Superb Refresh
I definitely did not intend to offend anyone. If my words came across the wrong way—which can certainly happen, given that English is not my native language—I apologize. My only point was that the discussion should remain focused on the Superb; if someone were to read this thread days, weeks, or years later and encounter talk about a VW T6.1—or any other vehicle with a completely different system architecture—it would simply be confusing. I am certainly not questioning anyone’s competence; everyone—absolutely everyone—in this forum contributes something of value. I simply felt a personal need to clarify this, and as far as I am concerned, this matter is now settled.
Ross2001 joined the community
A few questions regarding the Kodiaq – brake light, Start-Stop and Travel Assist
No, the dataset is essentially an extension of the firmware. It is loaded onto a control unit and—to put it simply—contains vehicle-specific data and the functions that the control unit is supposed to execute. Tools like ODIS-E or VCP can be used to flash these datasets. There are also some handy tools that allow you to load the OEM dataset, which then provides you with a user-friendly interface for making adjustments; you can then save your configuration and flash it onto the unit.
Yesterday
AlexLiv joined the community
BazzY started following Skoda Fabia Mk3 (2014-2021)
The cooling-fans keep on running even after I’ve turned off the car
A diesel vehicles fan can continue to run if the vehicle was mid-regen when stopped
I’m sure everyone can take a mo to calm down. It’s easy to read things in the wrong tone. Plenty of knowledge to be shared which makes the forum greater. Cairus has a wealth of knowledge particular to these models. You clearly have lots of knowledge too but seems more general. Both have their place but I’m sure nothing was intended to be a p***ing contest 👍🏼
Retrofit autodimming mirror
Thank You for the reply and the link, and Your original post, very helpful! The mirror in the link is the same mirror I have sourced, I was left with the ceramic circle after removing the factory mirror so I have mounted just below as I managed to get a working sensor to mount in the middle of the retaining bracket. All working fine, Thanks again
replacing front springs
I changed my NS front spring today and yes the 21 yo top mount was goosed , good job I bought one then I had a few issues getting the shock off but a lot more hassle trying to fit it back in the hub. I dont suppose if anyone knows if the tab that slots into the hub that the pinch bolt goes through is supposed to be elongated and have a 90 deg hook on the bottom? I noticed this as i was changing the spring and tried to bend it backin line with the tab but it seemed pre-formed so I ended up leaving it. I,m not sure if the shock is sitting slightly higher in the hub then it should and its got me paranoid now after finishing the job in the dark tonight 🅰️ I'll compare it with the other side in the morning if it aint pishing it down then back to the MOT station on Monday ,good article this one thanks guys !
Servicing intervals?
Id be more inclined to go on mileage, and if its one you want to keep for a while, do more often than 15000. I do the oil in mine every 7,500 because oil is actually pretty cheap. 1.4 TSI engine I get whatever VW502 is on special and change it more often. If the 504 is on special I get that but my understanding is the 504 only gives extended service intervals so not worth it in my case
Heater Matrix Flush??
Yeah, I think the main work is the refill procedure and pipe connections. I think the actual matrix is fairly easy to access
Octavia 3 Haynes workshop manual
Nice. Im keen I wonder how detailed it is. Keen to hear the feedback. I got a Haynes and a Gregory's in the past. Gregory's was way superior. Just better graphics and explanations. More detail.
Photography Thread
I agree with 26DIPP. For the sake of a few pounds I will have the oil and oil filter changed at 9,000 miles to preserve the life of the engine and turbo, as I have done with all my cars that I tend to keep for 9 years or so. However I also have a look and smell the oil on the dipstick as well at about 6,000 miles to see how dark and smelly it is! As for filters, the air filter gets looked at every year and replaced before it gets really dirty, likewise the cabin filters. Basically I don’t trust manufacturers schedules any more. Also I don’t trust cheap chain car servicers who use inferior generic oil filters not fit for purpose. My local reliable independent has got used to me supplying him the desired oil, correct filters, sump washer for him to fit during the past 30 years He is happy as he says he wastes a lot of time arguing with Eurobits factors and FSG plc that they have sent him the incorrect poor quality part and service item on the van. Unlike others I believe the 0-20w Castrol Edge LL IV spec meeting Volkswagen requirements is better for these Turbocharged cars in UK. I will revise that opinion as Global warming takes hold and my turbocharger catches fire!
Kamikazedriver started following Servicing intervals?
Remap options for 2023 Mk4 vRS TDI
The bosch md1 [ tdi ] ecu's in vag cars from around 2020 are locked from the factory and it has taken until now for someone to crack them. ECU needs to be removed and sent away for unlocking, then a remap can be done in the normal way. There's only 2 places doing the unlocking at the moment but that's likely to change in the future. DC Remapping UKNew ECUs We Can Unlock | DC Remapping UKThe locked, encrypted ECUs (Bosch MG1 / MD1) we now bench-unlock in-house - across BMW, Porsche, VAG, Land Rover, Ford and more, with the models each covers.
henrypolack84 started following Skoda Octavia Mk3 (2013 - 2020)
Yes! Best post ever! Just ordered mine!
henrypolack84 joined the community
To be honest the biggest faff with heater matrix is draining the coolant and then if you flushed it, disconnecting pipes, might as well bite the bullet and replace, not sure flushing would be that effective (I replaced mine). Lots of blocked matrix threads going on!
- Heater not working
01skodaOCT joined the community
AG_Precision joined the community
- Bixenon Headlights auto-adjustment problem
@AroCz - which channel r u reading the values from? I'm assuming this is on module 55 - Headlight, given urs is MY16 This is the Basic Settings values of mine (with DCC). However this with all 4 wheels hanging, for the DCC Recalibration procedure. I'll c if I can get the readings with the car sitting normally.
Kamikazedriver joined the community
3.6 fsi
Hello, I’ve noticed this “swooshing” sound on my 3.6 fsi after releasing gas pedal, I know this sound is expected on NA engine but not that noticeable. Haven’t done anything to the engine in few months so everything should be tight without any leaks, should I look for some loose vacuum connection of valve cover gasket leak, maybe pcv? thank you for any advise IMG_2178.mov
Can you change front shocks without removing hubs etc? 12 plate 1.6tdi
So much easier to remove the driveshaft out of the hub, even on the drivers side it's a struggle. Undo the 3 X nuts bottom of ball joint, drive shaft hub bolt, split the hub at the back at it should drop down. No need to remove tie rod end
Octavia 2l tdi cupa egr cooler bypass what is needed and how to do it ?
So, did this myself today. Likewise, dpf and egr are mapped out. Car has been using coolant since about 100k miles. Now on 180k and worse than ever after changing everything but the head gasket. This is the last chance before I get rid of it. Link below to the connector I used. You need under the car to get at the bottom coolant hose on the egr cooler and the top hose from the top of the engine. Once both are disconnected the connector piece is just about long enough to bring the two hoses together. You will probably make a mess even with hose clamps to try stop the flow. If you don’t have the vw hose clamp pliers for removing the hose clamps you might struggle https://vehicleclips.co.uk/products/20mm-car-heater-breather-hose-connector-straight-nylon-pa66
Incredibly stubborn hub bolt
Yep use a 3/4 breaker bar, its too much for a 1/2 especially when you need to re torque the new one (200nm + 180°)
- MK2 Octavia VRs wheel sizes
- Persistent P0441 error on Octavia vRS MK2 2011
Karel91 joined the community
octavia18l joined the community
