Past hour
Kodiaq Dsg
It had a service at 89000 , however we don’t know if it’s had an earlier one.complete records show services but not specifically the dsg
mickemelec joined the community
Knowing more than one fella that deals with parts, this is to avoid writing on the "plastic paint" which is far more easy to damage, especially if you use the wrong product. Unfortunately the pen is the cheapest option ... I got a breaker that moved to a barcode sticker type, but the adhesive sucks and it takes a long time to remove ... same problem ultimately ☠️
Strong smell of fumes ( diesel) coming into car
First thing is to work out whether it's raw diesel or exhaust, because they point to different places. A raw diesel smell is usually a weep somewhere in the fuel system: around the fuel filter housing, especially if it's been serviced recently, the injector return lines, or a fuel line joint. With the engine cold, look for a damp patch or fresh staining. Exhaust fumes on a high-mileage TDI are often a joint blowing between the turbo and the DPF, or at a clamp further back. Sooty marks around a joint are the giveaway. A leak at the front can get pulled into the heater intake under the scuttle, so it can smell worse with the fan on. If it turns out to be exhaust, drive with a window open until it's found and don't sit in it idling. Exhaust fumes getting into the passenger compartment is a major fault on an MOT as well, so it's worth getting it properly sorted.
SparePartAlam started following Strong smell of fumes ( diesel) coming into car
1.6tdi revs high at idle after driving car short distance/DPF???
Better yesterday but then decided to do a regen so think its coincindence with cold weather an car not getting used so much. When it was at high idle there were no fans on when stopping car after a short run until yesterday. Have put battery on charge overnight and will take out for a decent run today to see if everything goes back to normal. Battery is about a year oldish so should be good. If it does it again will get battery checked. Alasdair
Fabia Spare Wheel
Fabia Mk4 spare wheels were also discussed in this 2024 BRISKODA forum topic https://www.briskoda.net/forums/topic/522682-spare-wheel-and-central-tool-holder/ The Skoda optional spare-wheel for a Fabia Mk4 is steel and 15"-diameter fitted with a 185/65 R15 88H tyre. (In my own Fabia's case that tyre is NEXEN-branded.) So there's no doubt that this size of wheel/tyre combination will comfortably fit in a Fabia Mk4's spare-wheel well. When a spare-wheel is ordered as an option for a new Fabia Mk4, it comes with a wheel-changing tool-kit housed in a polystyrene insert as shown in the image in my last posting. It is the top surface of the polystyrene insert (NOT the wheel itself or the tyre on it) that provides support to the underside of the boot's floor. Consequently, if you just put the spare-wheel into the spare-wheel well without the polystyrene insert being present, the boot floor will need to be suitably packed up (or reinforced) to prevent it sagging if a heavy load is placed on it. This was mentioned in this more recent 'space saver' forum topic
Cairus's Leon FR
I passed by by chance, looking at very impressive set of upgrades and modifications ... very very good, compliments! With some electronic stuff, is not only learning the ropes, but make it also work without any 'ripple effect' ... more than skill, it becomes art 😉 I actually been procrastinating getting in touch with you to see some stuff on my car, but I can't open new fronts of work while I got so many still unresolved ... nevertheless will happen soon! I also got some health stuff I can't get rid of and need to accommodate my life to live with, but such are the cards sometimes we are dealt with, and we just have to play with what we got ☹️ Thanks to our ancestors who created automobiles, we got something to escape to, often with satisfaction! (and some bitter frustrating times as well! 😁) Talk soon ...
leolito started following Cairus's Leon FR
Bonnet support clip come away
Nothing down there. Its simple stuff. Not mechanical engeneering needed. It works that way, not otherwise, try to use something wider to spread more those 4 pins. Or maybe you need a different part And put here actual photos and measurements of your car, not from internet.
All in servicing
Agree, so I have just taken it out anyway
Today
Kodiaq Dsg
Welcome to the forum. A DQ250 6 speed wet clutch DSG should have no issues if proper Servicing. So Oil & Filter changes to the DSG at 40,000 mile intervals or sooner. Has yours had 2 oil changes?
Evolution13 started following Kodiaq Dsg
Graham1959 started following Kodiaq Dsg
Kodiaq Dsg
Hi,have just purchased my kodiaq 1.4 petrol paired with the wet clutch 6 speed Dsg with 93000 miles,how do other owners find the longevity of the box in terms of mileage?
Yeti 2.0 litre tdi temperature problems
Thanks for that, will have a look.
B pillar gloss black
I have the same issue. I'm living with it for now, but it's not ideal.
- Abs module long coding
Radoxx joined the community
Cairus's Leon FR
Change/Edit Car Immo Data
What summer tyres do you drive on 19'' wheels with your Kodiaq?
I think you'd struggle to get part-worn linglongs for £100 all round!
OccyVRS started following Parts & Accessories and What summer tyres do you drive on 19'' wheels with your Kodiaq?
Parts & Accessories
I've spent over £1000 with these guys over the last few years (replacement caliper, washer motor, suspension parts, steering parts, trim pieces, body pieces, wheel bolts and endless little bits). They are all 100% genuine, and come well-packaged in the original VW bags/boxes. Absolutely top service, every time. If you ever need help, before or after an order, email [email protected] and ask for Jan - he's their UK representative. VAT is included. There are no import fees (I've ordered in excess of £400 for a single delivery). Unless I'm in an insane hurry for parts, I always use these guys. The only issue I've ever had was on a recent order, where FedEx farmed out local delivery to InPost, for some reason. The order arrived a day later, without issue - and, of course, it's not Skoda-Parts' fault.
Yesterday
As soon as you drive the car it will sense that it needs to put back into the battery the energy used for starting. That is normal but more noticable in cold weather as the battery capacity is less.
Number of flashes.. observations
From @andyvee in the MK3 adaptations, tried and tested thread: "Changing the number of flashes of the comfort (lane change) indicator Controller 09 - Central Electronics 16 - Security Access - enter 31347 10 - Adaptations (2)-Turn signal control-Komfortblinken Blinkzyklen - change the value from the default of 3. I think the range is 2-5. [screenshot to follow] Edit: You may need to set your lights back to factory default in the infotainment unit before this change takes effect Edited 12 yr by andyvee" This worked perfectly on mine, thanks @andyvee .. as you suggested I had to do factory settings in the infotainment menu. Then a few days ago I did the thing that brings on rear lights (two bulbs each side, anyway) with DRLs, something that really all cars should have been set up for imho. That adaptation worked great, but the flash number retuned to 3. Looking in VCDS the setting of 4 was still there but the actual flashes only numbered 3. Another factory settings reset and it's back to 4, now with rear lights on with DRLs. Excellent! I saw there's an option to have clocks lit up or not with the DRLs, I went for not lit in order to save confusion: clock lights are only on when 'proper' lights are shining. Onwards and upwards! 🙂
hubrad started following Number of flashes.. observations
Haldex versions
Yea, I got one from an s3 Audi after a few months looking around. part nos matched
Skoda Rapid Radiator fan not working
Nope, still not sorted. I pushed the pin down but it barely spreads the prongs. It still just falls out, genuine Skoda part as well. I’m thinking there’s something underneath it clips into.
Haldex versions
Hi, I've got the same problem with my 2014 MK3 Tour De France. And yes, it is proving very difficult to find a replacement. Although I have been quoted £7500 to repair 🤯🤯🤯 My garage said cheaper/easier to get a 'new' axle with haldex already fitted and swap it over. Did you find a solution to the problem?
Mark1974 started following Haldex versions
VW Caddy mk2 (Felicia) Pick-Up 1.8T
The time arrived for the ‘proper test drive’ I alluded to a couple of posts ago. I was, as expected, properly nervous at the prospect of the Caddy letting me down again. Worst case scenario I would find myself stuck in traffic in a dead pick-up that still had an undiagnosed fault. That scenario would likely lead to the Caddy being left broken on the driveway for a period whilst it awaited the rekindling of my enthusiasm. I had so little faith that I even considered asking my son to follow me in his car, but eventually I put my big boy pants on and set off unchaperoned. Caution was not thrown entirely to the wind, however, as I drove in ever-increasing circles centred on my house, and avoiding all roads where a breakdown would leave me with no scope to get myself out of the way. The target for the test was 30 miles, involving a cautious start and a gradual increase in speed and boost. It ran faultlessly. After 20 miles I was relaxing into the likelihood of success, and I started to enjoy the drive. Although I can claim mission accomplished, I will not be so bold as to re-wrap the ECU looms just yet. The plan is now to use the Caddy for a bit, and if it continues to demonstrate reliability then I will either re-wrap the looms, or embark on the next stage of under-bonnet electrical housekeeping.
- Mk3 Fabia subwoofer install
