  2. The voltage is just a crude indication. Better if you can find a place that do a capacity check.
  3. Today
  4. Hi, i took the clutch cutout inside. How did u do it? Any tip on how to route and Where to ground the 230v input in the front ? Left or right side and where did u ground?
  5. Jaaaaaa joined the community
  6. The Greenline does have lowered ride height. According to the Kilen spring catalogue, the Superb MK2 1.6TDI estate Greenline has rear springs with OEM part number 1K0511115BT. 1K0511115BT has one blue paint mark, and three yellow paint marks. This is the only Superb MK2 rear spring with lowered ride height that has three yellow paint marks. 1K0511115CA is one up in the hierarchy, 1K0511115DG is two up in the hierarchy. However, 1K0511115DG might be too stiff so 1K0511115CD might be a better option as it's softer but longer than 1K0511115DG. If 1K0511115CD lowered ride height rear springs don't give you enough rear end lift, then the 1K0511115DE standard ride height rear springs might be a good option. Both these springs have the same 12.25mm wire diameter, so should be about the same stiffness, ie. provide the same level of comfort. Even the 1K0511115CD lowered ride height rear springs should lift the rear end up by at least 12mm compared to what you have now, ie. the 1K0511115BT lowered ride height rear springs. Sachs 994 454 lowered ride height rear springs (matches 1K0511115BT) (build code 0YD) Length 330mm Wire diameter 11.75mm Saches 994 363 lowered ride height rear springs (matches 1K0511115CA) (build code 0YE) Length 333mm Wire diameter 12.00mm Sachs 994 360 lowered ride height rear springs (matches 1K0511115DG) (build code 0YF) Length 333mm Wire diameter 12.5mm 1K0511115DH lowered ride height rear springs (build code 0YG) Length unknown Wire diameter unknown Sachs 994 373 lowered ride height rear springs (matches 1K0511115CD) (build code 0YH) Length 342mm Wire diameter 12.25mm Sachs 994 361 lowered ride height rear springs (matches 1K0511115CE) (build code 0YJ) Length 342mm Wire diameter 12.75mm Sachs 994 559 lowered ride height rear springs (matches 1K0511115CF) (build code 0YK) Length 345mm Wire diameter 12.75mm Kilen 65074 lowered ride height rear springs (matches 1K0511115CD) Length 342mm Wire diameter 12.25mm https://www.ebay.co.uk/itm/318939090159 Kilen 65056 standard ride height rear springs (matches 1K0511115DE) Length 362mm Wire diameter 12.25mm https://www.ebay.co.uk/itm/336905897118
  7. unfortunatly i dont have a steering wheel with paddles or heated wheel ( really cant justify ebay prices ) but the heated REAR seats seem warmer than the front 😇😜
  8. I have VCP. You can code what your controller allows. You may be able to write a new data file if it is available. I wanted to get the inside opening and closing functionality for our 2023 SIII but have not been able to do it yet. Skoda have fitted different controllers for different years and they have dropped functionality and called it safety. You might have to change your controller. But that also involves coding.
  9. skoda_superb_2022 joined the community
  10. When I replaced the timing chain on my own car - completely different engine, I still made timing marks in white paint. Once the chain is fitted and locking tools removed the engine should be turned over (by hand) a few times and checked against the timing marks before any covers are refitted. Having marks present does not surprise me. They are useful as checks. Getting the timing wrong usually is catastrophic. Even where parts have timing marks I highlighted these with white paint to aid visibility. Kev.
  11. You're welcome.
  12. Though I have heated windscreen, I sometime use a very efficient method when I'm in a hurry to leave: a simple spray bottle that I fill with household alcohol. This prevents any risk of scratches on windscreen and any glasses. With ice scrapper, if your glasses are a bit dirty, it may cause awful scratches. 😬 BTW, it reminds me an old joke in the '80s: _ Do you know why Ladas have heated rear screen? _ To keep your hands warm, when you have to push it. 😂
  13. Mark8206 joined the community
  14. the wet clutch DSG is very different from dry clutch DSG... an is much more smooth and durable. The wet clutch DSG has also emergency mode (mechanical redundancy for limp mode ) , which dry clutch DSg does not have...
  15. the clutch master cylinder is very easy to replace, once you know that you must remove the clutch pedal with the master brake cylinder alltogether from the inside
  16. Before you go down the water pump replacement route consider that it could be caused by a couple of other things: Air in system. I've heard it can be difficult to get all the air out after replacing the coolant. Thermostat stuck closed or some other blockage in the system
  17. From my back garden a few minutes ago: Clouds are doing a good job of getting on my tits! 🙄🤬 Gaz
  18. b2311e joined the community
  19. liammurphy joined the community
  20. Haven’t started yet 😂😂😂
  21. In my experience, once you start, that’s the seal broken…
  22. Loads of plans but seem To have lost interest now Unsure whether to mod it because it’s such a nice car as it is
  23. I'm concerned by your mechanics reference to using 'marks' to establish correct valve timing while replacing your cam belt - AFAIK, it is critical to use the correct tool to physically lock both the cam and crankshaft in position while doing this job.
  24. Hello, I am looking for firmware mst2_eu_sk_zr_p0253t and MST2_EU_SK_ZR_P0480T I now have MST2_EU_SK_ZR_P0241T (which also would be nice as backup) Thank you in advance
  25. EmillienR joined the community
  26. Lovely clouds, sky, Moon (99% full) and reflections this afternoon. Only had my phone to hand sadly🫤
  27. 1941 is not actually the latest software version, although it is considered a stable release so if it isn't causing you issues, I'd just stick with it. 1989 is the latest version, although I myself stuck with 1985 as it was (and still is) working absolutely fine for me. 1985 and 1989 are the only 2 releases after 1941
  28. Ah that might make sense re battery. Think its about a year old but cant remember if I bought a new one or nicked a good one from one of my older cars. Will check voltage tomorrow. The high idle has only been there for the last few cold days -3C and below and only today did it fail a regen hence fans on. Previously it just sat at high idle but no signs of regen or fans. Its supposed to get a bit warmer tomorrow (a balmy 4 degrees!) so will monitor it plus give it a good run when I can. Cold weather is hard on batteries so hopefully thats it and nothing more sinister. Alasdair
  29. zeletu joined the community
  30. Does it if the battery charge is getting low, particularly in cold weather. May be first sign of battery getting tired.
  31. Weird it has done it the last two/three days in a row even after a 30min blast down road. Alasdair
  32. Mines does the same but also get strong exhaust smell. Only in winter the smell but the high rpm is regular due to short runs.
  33. Same here used to do longish runs but now all fairly short. It used to wait till engine upto temp but now seems to do it from cold plus a good blast yesterday seemed to cure it. This morning was the same again?? Seems to be regen every time I start car?? Apart from that car is running perfectly Alasdair
