Everything posted by gumdrop
Overboost due to Stick Vanes
As the fuel goes into the turbo Then to the cylinders your best bet is to read up on test reports. I have voted for Wyns, accidently as I cut and pasted it for a search.
AdBlue and start stop question
My 2015 Yeti had it fitted, 2L AU6 diesel.It also had Stop/Start
Cabin pressure
https://jalopnik.com/why-do-slightly-opened-car-windows-make-that-awful-soun-1447498738
Replacement Battery
I bought batteries for cars and caravans from a company in Wales, a wide range all carefully explained, and dimensions. Countrywide delivery but I cannot remember the company name! I just remembered TAyna https://www.google.co.uk/search?q=tayna+batteries+wales&dcr=0&sxsrf=AOaemvKPfylz3Tww2j4_1c6cYVV14pN0iA%3A1631478761077&ei=6WM-YY6eBLSD8gL00LCAAQ&gs_ssp=eJzj4tZP1zcsSSnIyUhPN2C0UjWoMLEwMzUyS0syskgztDCzTLMyqEgxMDK0MDVPTEtMMjdKSzTwEi1JrMxLVEhKLClJLcpMLVYoT8xJLQYAPg4XRQ&oq=Tayna+batteries+wales&gs_lcp=Cgdnd3Mtd2l6EAEYADIOCC4QgAQQxwEQrwEQkwI6BwgAEEcQsAM6CggAEEcQsAMQyQM6CAgAEOQCELADOgQIIxAnOgYIABAHEB46BggAEAgQHjoKCAAQCBAHEAoQHkoFCDwSATFKBAhBGAFQrENYn2xg14wBaAFwAHgAgAG1AYgBswWSAQMxLjWYAQCgAQHIAQvAAQE&sclient=gws-wiz
Auto braking
Only one? I was travelling at night and my headlights picked out about eight mallard in a group on the tarmac, I braked hard but they did not have a chance there were five donk, donk, donks and I picked up five dead ones largely unmarked, the others managed to fly clear.
Rattles and Creaks
Don't just squirt it, apply it to a cloth and/or strip of cloth, use the strip to see-saw into gaps between panels (if there are any) where they might rub. Door seals just wipe around the rubber, this is especially useful in the winter to help stop seals freezing to the door aperture. to
Sat Nav memory
I tried to set my sat nav for a half hour drive, I have never seen such a user unfriendly set up, I used to have a Tom Tom unit which mas intuitive and easy. Is there a video on setting it up, please
Rattles and Creaks
All modern cars make noises, I get great satisfaction from using a wipe of silicone or polish on plastics and doorseals, it can be very satisfying. The older cars had bigger gaps in interior fittings so tended not to rub.
Roof Bars and Roof Box
I bought a roof sized Thule Ocean 80, 320ltr. front opening box, for my Fabia Estate and roof bars from an Amazon seller but do shop around. I also bought the Thule shaped bags to keep things easily loaded and unloaded.
Yeti fl 2015 suddenly brake problems
I had a problem in Wales, a long curving downward curve and another vehicle pulled out I put my foot on the brake and tried to slow, the pedal went to the floor. I started pumping the brake and it came back up. I had no further trouble and took the car back to the dealer (it was only a few months old) they changed the fluid and found one of the cylinders was leaking (porous casting they said). The fluid levels were fine as this was my first check! anyway no further trouble in the three years I owned it.
Error service: leave vehicle only when selector in position p
I can select park with the engine off but unless there is another unknown factor in play I have not been able to remove the key without starting the engine. This is the second time I have turned the engine off before selecting 'P' it is, hopefully, not becoming a habit. Just a quick return trip to the local supermarket.
- Error service: leave vehicle only when selector in position p
- Kamiq Front USB C ports fell into casing.
Cabin pressure
No, it is some kind of venturi effect where fast moving air outside the car (with partially open windows) produces a vaccuum inside the car. Mr Dyson loves the effect.
Cabin pressure
Is this the phenomenon where dust and empty plastic bags float about in the back of the car as in a vacuum? My boys used to love this effect that we had in some cars I owned.
Skoda Kamiq footrest
If you look at the photo closely the footrest looks to have a bolt/screw holding it in place. Regarding the passenger footwell there is no duplicate footrest, moulded or otherwise.
- Skoda Kamiq footrest
My recent Kamiq has a footrest fitted- Electric vehicles and charging
EVs shouldn't be towed as the car's electric motor is mechanically linked to the wheels and can't be placed in neutral. Towing one can cause lasting damage to the car's powertrain. Say the makers.- Kamiq Front USB C ports fell into casing.
- 472 miles and a smell of clutch in the cabin
What with one thing and another, the kamiq has only done 472 miles. I got into the car today after not using it for a few days and the smell of clutch was in the cabin not strong but there. I phoned the dealer but they are very busy, nothing until September. The car performs perfectly, no extrenuous noises, and as another poster said it stays in D-drive and Wafts along. S-drive is still unexplored until I have added a few more miles.- windscreen wipers juddering
I second the Bosch Aerotwin, there is also a Bosch Icon that is supposed to be good in ice and snow.- windscreen wipers juddering
Read this thread through you may find it helpful- Windscreen decontamination and Dumb Question
I no longer use add blue, I've gone petrol! I was referring to VW or Prestone screen wash. Just a thought what does the dishwasher Rinse Aid do? - Skoda Kamiq footrest
