Everything posted by ords
Gearbox error DQ250
https://www.ebay.co.uk/itm/403465043218?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=403465043218&targetid=1814673647182&device=c&mktype=pla&googleloc=9045889&poi=&campaignid=19089547614&mkgroupid=142438599285&rlsatarget=pla-1814673647182&abcId=9303859&merchantid=7256454&gclid=EAIaIQobChMIvYu73Lvr_gIV5oBQBh2Bcw4AEAQYBSABEgKNz_D_BwE
Increase mileage
Is this a recent thing you've noticed or has it always had this type of fuel consumption?
whistling, vibrating sound
- Changing a s/s battery?
Did it cure the s/s fault?- Estate rear end just slid out a little easily?
Speed is not the issue here. OP was only doing 30mph and it was a momentary lapse of observation that caused the problem.- Estate rear end just slid out a little easily?
.- Fuse box and Gear Box questions…
One fuse serves both sockets.- whistling, vibrating sound
Does it go away when you turn off the ventilation system?- Drivers window just stopped working
Just hold down the unlock button and all 4 windows will open for as long as you press the button. Do the same with the lock button to close them. I think there is an option in settings to enable this feature.- Drivers window just stopped working
Can you open the window using the key fob remote?- Water in the doors and a cranky start!
A comment on page 2 gives the part no's for the modified seals for the front doors.- Strange issue i can't figure out
Can you make out any part no's?- DSG7 Recall advice (accumulator component)
I'll agree on your 1st point, but lagging? not in my experience.- DSG delayed response
- My MK3 VRS fan randomly turns and drains the battery when the car is off.
Try and scan for a fault code with vcd's or similar. Something is very wrong. If its been standing for 5 hours the fan shouldn't come on randomly. Maybe the battery is failing and confusing the system.- New Owner of a Skoda - Navigation Database
You HAVE to use a genuine Skoda sd card which has built in files to operate the system. An ordinary sd card will not work. If you bought it from a dealer you need to raise it with them that no card was supplied.- Vibration with my Octavia 2017 2.0 DSG
Does it do with the car not moving and the revs at 2000?- coolant expansion bottle
If you are not the first owner, maybe the previous owner had the bag removed.- Leak from rear wiper has killed the motor
There are Youtube videos- 2017 Sat Nav Question
As you already have a genuine card, just back up the data, (in case there is a problem) delete or re-format the card and load the new update onto it.- oil coming out exhaust
Post a video- Tailgate doesn't open, wiper doesn't work too
- Vrs 2.0tsi stalls
Similar problem with the same code.- Octavia III randomly braking on the highway
Would my 2013 have this feature? I don't have any menu for settings. If I do have it, I've never noticed or felt it working.- New key and programming?
Very good price - Changing a s/s battery?
